Question about Woods GDC124CSS Dehumidifier
The fan doe not work - Woods GDC124CSS Dehumidifier
  • falbergaria Jul 25, 2009
    the fan's bearings are fine it goes around freelly,it seams like im missing the ground that goes to the fan .
    if i measure voltage on white wire to the groud (metal case) i get 110V ,if i measure black wire to ground(metal case) i get 110V.
  • 1,272 Answers
It seems that the bearings went out in the motor. See if power is going to the motor, and if the fan motor is trying to turn.
It seems to be a fault with the motor though.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 25, 2009
  • Anand Gupta
    Anand Gupta Jul 25, 2009
    Well then I suggest you to check the conversation as stated in the link below:
    http://forum.doityourself.com/humidifier...
    Though it might not relate to your product model, still I believe it should help you.
    Regards
    Anand
Why does my brand new wall AC unit turn on but the fan does not work?
Good Afternoon Michael,
I see that you are having trouble with your Frigidaire air conditioner, model# FRA14EHT2, and the fan not turning on, even though the compressor turns on. Being that this is an air conditioning, I suggest either calling your local authorized technician or possibly the manufacturer. One of which will be able to assist and direct you in the right direction of having your air conditioner working. Hope this is helpful.
-Best Regards-
WP
May 09, 2014 | Frigidaire FRA14EHT2 14,000 BTU...
Turns on but fan and compresser does not run
start relay on compressor fans will not work if pumps not running
Nov 16, 2013 | Winix WDH751 Dehumidifier
Delonghi Dem 10 dehumidifier has stopped working - the 'operational light' turns on, but the fan does not start up so nothing happens.
It could be that the fan / fan motor has seized or jammed. Have a look through the vents and see if you can spin the fan. If not, you will need to strip the machine. Try lubricating the bushes / bearings. Often on these type of units, the vapours dry out the bushes and then they get tight and jam the fan.
Nov 08, 2013 | DeLonghi Dehumidifiers
DeLonghi Dem 10 dehumidifier stopped working - the 'operational light' turns on but the fan does not start up.
You may need a new fan motor. If you can get to this
motor, with the power disconnected, see if the blade
is free to move. Do you hear any sound coming from
this unit?
Nov 08, 2013 | LG DH30 GoldStar Dehumidifier
Fan not working, outlet is live, product is 6 mos old, located in an indoor swimming pool (endless swim machine) Hi E Dry 100,
If the fan does not operate with the fan switch set "on", there is a problem with the power supply, internal wiring, or the fan itself.
First make sure the dehumidifier is plugged in to a working outlet.
Next unplug the dehumidifier and remove the cabinet cover. Check the internal wiring for loose connections.
Next remove the fan and check that it is able to spin freely (by hand). If it spins freely, it should be replaced. Call the manufacturer at 1-800-533-7533 for parts and instructions.
Feb 22, 2011 | Therma-Stor Hi-E Dry 100 Dehumidifier
Fan works but little water is removed
make sure your grille/radiator/filter/fan, etc is clear of dust/lint, etc. does the compressor run? if not check the thermocouple/temp sensor
Apr 03, 2010 | Kenmore 54501 Dehumidifier
Kenmore dehumidifier 54501: Fan does not work. I
Call sears see if the compressor is under warranty
Sep 01, 2009 | LG DH30 GoldStar Dehumidifier
Motor runs fan does not
you may have a stripped out fan unit, the fan motor runs, but the fan does not spin? my fan was plastic and stripped out there should be a flat spot the lines up with shafton motor ifit is round your should replace fan blade unit. i could not find one so i pushed tooth picks in between shaft an fan and glued them has worked for a couple months now
Aug 19, 2009 | Kenmore Dehumidifiers
KENMORE 70 PINT DEHUMIDIFIER
4681A20040R is the fan part #. Bought one on e-bay. Fixed the same problem.
Aug 18, 2008 | Kenmore 54701 Dehumidifier
Fan does not go on
I had the same problem with my unit. I checked the fan motor with a ohm meter and found that both low and hi speed windings were open. New fan motors can be found on ebay, but changing them involves some work.
Jul 19, 2008 | LG DH404E Dehumidifier
Woods GDC124CSS Dehumidifier Logo
27 people viewed this question
Top Woods Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Woods Dehumidifier Expert? Answer questions, earn points and help others
