Question about Craftsman Garden
Craftsman tractor lawnmower 917.25584 clutch assembly is not working. Need diagram of where to look for problems
    Loyalty:
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 1,283 Answers
PartsTreeRepairClinic may have a video
Posted on Jan 31, 2018
  • 376 Answers
SOURCE: Need a belt diagram
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=917.273638&pop=flush Enter your model # and search, scroll down to mower deck, and there ya are.It's an easy one. Straight across the back between the blade pulleys, then to the inside of both idler pulleys, then to the engine pulley. Hope this helps. Dwain
Posted on May 23, 2009
  • 376 Answers
SOURCE: need to adjust brake/clutch 14hp craftsman lawn tractor
The brake is on the right side of the transaxle. There are two mounting bolts and one 1/2 nut in the middle that is your adjustment. Tighten it 1/2 turn at a time and hold the brake down and try to roll it until it holds.
Posted on Jun 09, 2009
  • 376 Answers
SOURCE: large belt routing for crafstman lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
Posted on Jul 02, 2009
AUTODOC01
  • 216 Answers
SOURCE: Wiring diagram for 10 hp tecumseh motor.
no worries go to searsparts.com type in your model # and follow the prompts you can then print it out for free ?
Posted on Aug 28, 2009
Testimonial: "You made everything simple greeeeat.A++++++.Thanks Alot"
mowerman1857
  • 389 Answers
SOURCE: looking for wiring diagram for sears tractor
Go to www.searspartsdirect.com Enter your model number in the appropriate box, when the page loads, look on the left side of the page where it says "Browse sub-components" and click on "tractor-schematic" this will open to a total wiring diagram for you
Posted on Oct 22, 2009
Manual for 24 hp 42 craftsman - Diagram and How to change the drive belt?
Remember this,there is a belt diagram under the left foot rest. It will show you how the belt is rigged onto the pulleys. In changing this belt you will have to pull the clutch assembly,from beneath the motor. Only one bolt holds this assembly to the motor's vertical shaft.Once removed,install the belt onto the pulleys. Then slip the belt onto the clutch assembly's pulley and lift straight up,align the key way with the key and slip on the clutch assembly and replace the bolt.Torque down the bolt,i can't remember the torque pounds,but i believe it's 100-200 lbs. of torque.B. Locke
Sep 28, 2015 | Craftsman Garden
Clutch belt needs to be put on
Go to craftsman lawnmowers .com for belt installation instructions and diagrams. Hope this helps, plese post solved on fixya.com.So I get credit for a solved problem if it does. If not, check back and give me more info.
Apr 14, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a sears craftsman riding lawnmower LT2000 model #917.273751 18hp intek engine 42in deck.Engine runs fine but when I release the clutch-brake pedal engine stalls.seems like an intermitent problem...
There are other safety switches as well. The electrical diagram shows (2) of the interlock switches (part no. 16 in diagram) in the electrical system. The location of the 2nd one could be on the transmission or the clutch/brake pedal. It could also be on the PTO system (blade actuator if you will). See if you can find the other switch on your unit. I have an LT1000 and have NOT looked for them. Here is an electrical diagram on your unit.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917273751/0247/1509200/P0403265/00001?blt=06&prst=&shdMod=
Aug 13, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My husband was injured and cannot replace the main drive belt for our riding lawnmower. Is there a place to get the schematics of how to put it on? If I have a picture I can do it. Model 917271041,...
Normally the belt diagrams are in the owners manual. Seeing this is a 12 year old machine the diagram stickers are possibly gone, but the drive belt diagram is normally on the bottom side of the foot rest, and the mower belt is on the top of the mow deck. Both are typically on the left side of the tractor as you sit on it. Please vote 4 thumbs up. Thank you.
Here is the link to a typical 42" Craftsman mow deck belt:
http://www.askmehelpdesk.com/attachments/tools-power-equipment/21777d1247094945-craftsman-lawnmower-belt-diagram-aypwobrk.gif
Oct 16, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do you replace drive belt on a hydrostatic transmission craftsman riding lawnmower that has slipped off or my be broken.
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Jul 17, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
INSTALLING CLUTCH CABLE ON CRAFTSMAN
the proper threading of cable clutch for 38 in. craftsman riding lawnmower model 271150
Mar 29, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
35 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
