Question about Sennheiser Audio Players & Recorders
How to fit replacement earpads to sennheiser pxc 300
2 Suggested Answers
SOURCE: I'm after replacement ear pads for a Sennheiser
Posted on Oct 13, 2010
Why is there No sound in bypass mode?
I have found this problem on several PXC 450 headsets and it can be solved by resoldering the bypass switch pins on the circuit board. We use about 25 pairs of these headsets and although they are excellent they can suffer from dry joints mainly on the switch but I have found a surface mount resistor in one case to be the problem.
To get to this board you need to unclip earpad on side containing switch then undo a number of philips head screws to reach the circuit board under the speakers then unscrew circuit board resolder and re assemble. Good luck.
Apr 28, 2014 | Sennheiser PXC 450 Headphones
Why is there no sound even in bypass mode?
The bypass switch developes dry joints after some time. The earpad has to be removed and the speaker plate unscrewed and lifted back. The cct board connected to the switch will now be exposed so the switch legs can now be resoldered. Reassemble and you should be good to go.
I need ear pads of sennheiser hd 470 in banglore...i need it urgent pls help.......pls let me know as soon as possible
Spare parts for these headphones are available at the following website
Jul 28, 2011 | Sennheiser HD470 Headset
I need ear pads for Sennheiser hd 470 any thoughts?
Found these pads available at the url below, they are not original but they are still exceptional quality.
Jun 14, 2011 | Sennheiser HD470 Headset
Head phones pxc 350 do not respond to new battery. Switch mutes sound?
I had the same problem, until I realized that the headphones have 2 batteries. I was only replacing one.
Feb 20, 2011 | Sennheiser PXC 350 Headphones
How do i change earpads on hd270 headphones
To remove the pads on Some Sennheiser earphones you gently turn the pads about 20 degrees which releases the pad from the earphone. hope this helps.
Jan 03, 2011 | Sennheiser HD 270 Consumer Headphones
I've noticed that replacement inner foam(that covers the speakers) and earpads are available for my Sennheiser HD 570 Headphones; how do i get the old ones off? Thanks
The ear padding is attached to and held in place by a plastic ring that fits into the speaker mount. Gently pull the ear padding outward so you can see the ring, then slip a flathead screwdriver or other object in (just a bit, you don't want to poke the speaker inside). Gently pry up , sliding your pry-bar along, and the pad should pop out quite easily.
Sep 19, 2010 | Sennheiser HD 570 Consumer Headphones
Headphone wire cut can it be spliced back together sennheiser pxc
It rather depends where the break is. If it is one of the single strands, near to the headphones, you might be better replacing the entire cable. If this is the case you will need to remove the foam pads and then you should see access screws to get inside and solder the new leads on.
If lower down in the twin cable part, then you can cut it off before the break and solder a new 3.5mm plug on. The two coloured wires in the cable fit on the small lugs of the plug (you will have to work out which is left or right, by trying them on each lug. The other wires are earths, which fit together on the large metal flange. The T piece part of the large flange grips the black cable, to stop it pulling out. PS make certain you put the plastic body cover of the plug on the wire before soldering on the plug. That you just slide it back on the plug. Make certain the wires on the plug don't touch the earths and also the left and right don't short.
Once you have the plug on, you can buy an extension cable for headphones. This will make it long enough to use.
Feb 22, 2010 | Sennheiser PXC 250 Consumer Headphones
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
