Question about Arris Computers & Internet
I am using a arris 1600 modem. I need to login to this modem to change my ssid and pass word. Since in cannot remember the present p/w and Id to login. How can I factory reset my modem?
SOURCE: DCS reset
Push the reset button on the back of the camera
Posted on Feb 23, 2008
oldnovii
  • 667 Answers
SOURCE: how is Arris Telephony Modem installed?
Hi taldrich6 - You have this listed under Arris CM450. Is that what you have?
Posted on Jul 22, 2008
rhinoking1
  • 85 Answers
SOURCE: Siemens 5890 DSL Router/Modem Need factory reset.
Most routers have a defalt user/password for setup and chainges. Try "admin" "password" to gain access to router. From there you should be able to reset any passwords put on it.
Posted on Jul 06, 2010
SOURCE: Need modem reset - unable to access using original
Press RESET button for 10 seconds it is in back side of router then all settings defaults.Then you can configure it with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Posted on Oct 10, 2010
  • 643 Answers
SOURCE: need to hard reset westell 7500 modem to factory
  • Note: Resetting your router to the factory defaults not only changes your router user name and password to the factory default values, but it also deletes all your home network settings. This includes the SSID and network encryption key. After you reset your router to the factory defaults, your home network won't be accessible until you reconfigure your router and all your network devices to use the same SSID and encryption key.
To reset your VersaLink 7500 gateway to the factory settings:
  1. Hold the reset button on the back panel of the VersaLink 7500 gateway for 30 seconds.
    • All your settings will be lost including network encryption information and any SSID information you have entered.
    • The gateway user name and password will revert to the default of Admin as the user name and Password as the password.
  2. Your VersaLink 7500 gateway is now using the default settings for the network configuration. This includes the default SSID and network encryption key. You must re-configure your VersaLink gateway to match your previous settings that were assigned to all other devices on your wireless network. Otherwise, no other network devices will be recognized.
Posted on Dec 28, 2011
My modem had to be replaced now It won,t accept the pass word I had used for the old modem my ssid # is now 190. so I have no connection. what do I do
You'll have to go into the modem/router software and change the password and SSID settings. Since you didn't say what model or brand you have, you'll have to google the set up.
Typically the connect to the device, open a browser window and type 192.168.1.1. in the address bar. (could be another number depending on what you have. like .1.2 or .2.1) It should bring you to a login screen where it needs a user ID and Password... possibly <none> and admin. Some units have ID and PSWD on a sticker on the bottom. Other units have a CD with the set up on it.
By not knowing what you have I can only give a partial answer. Contact your ISP (internet service provider) the guy you pay for internet, for help.
Dec 09, 2016 | Computers & Internet
How do I change access password
http://arris.force.com/consumers/articles/General_FAQs/SBG6580-Admin-Login-Setup
Oct 24, 2015 | Arris SURFboard SBG6580 eXtreme Wireless...
Where to find the password
http://arris.force.com/consumers/articles/General_FAQs/SBG6782-Admin-Login-Setup
if you have not changed the default password and user name !
it is listed on the web page on the above link
Go to wireless tab at top of screen and look up WPA Key or WEP key and make a note of what it is on 2.4 GHz frequencies as I think this will be dual band with 5 GHz as well but Ipad will run on 2.4 GHz only as it will be 802.11n as opposed to 802.11AC
Note if you changed the user name password or user name you will have to reset the router back to factory defaults but be aware everything defaults so ISP cable settings reset (would need ISP to tell you what they are and help set them back up)
(wireless settings change so you need ethernet cable directly into router to set up wireless)
Hopefully your still set up on the router on the default user name and password !
Jul 02, 2015 | Arris Surfboard Extreme Docsis 3.0...
How do I change the "Pass code" on my wireless Motorola surfboard modem ???
If you mean the wireless pass code or Passphrase you need to log onto your modems web page which normally sits at IP address: 192.168.100.1. In the wireless section there is the pass code update field.
Dec 30, 2014 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Cant connect modem to new wireless brother printer
It is best you contact Arris support. Mark Motorola Mobility Support ARRIS
Jun 17, 2014 | Motorola Computers & Internet
Error 80710102
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Apr 16, 2014 | D-Link DIR-300 Wireless Router
I need the wep security code for my sons dsi to download games on it from the internet. router name arris model # cm450a
When you did the initial setup for your router, you should have configured the wireless adapter in the router:
* set a SSID -- the "name" of the network
* set an encryption-level -- hint: use 'WPA' or 'WPA2'
* set a password for your network
It's that SSID/password that you need to enter on the DSI, to make a wireless connection to your router.
Apr 21, 2011 | Arris Touchstone 450a (CM450) Modem
I want to put a password on the wireless connection
Access your router login page by entering 192.168.1.1 on the URL address bar, go to security and find PSPK code, that is a pre shared pass key, enter the password there and restart, now your wireless connection requires the password. Hope this will solve the problem
Sep 23, 2009 | Dynalink (V1456VQH) Modem
How to secure my d-link wireless adapter with my Arris 550a modem
To make your wireless router secure you need to use your browser and type in the router's IP configuration address.
Then you need to change the default Admin password,
change SSID and turn off SSID broadcast,
setup the encryption (use WAP or WAP2 if your wireless card supports WAP) if not use WEP 128 bit encryption
and for added protection use MAC address filtering.
Apr 15, 2009 | Arris Touchstone 450a (CM450) Modem
Configure D-Link Wireless N Router DIR-615 for 2wire 2071-A modem
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
login ADMIN and pass is blamk
Apr 04, 2009 | D-Link 802.11g 54Mbs Cable/DSL...
Computers & Internet Logo
37 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
