Question about Samsung Cell Phones
How to fix Samsung Bluetooth Gear circle? - Samsung Cell Phones
Can i connect to a windows labtop
As long as that laptop has bluetooth capabilities, which most newer laptops do, you can connect. What kind of laptop is it, model number?
Jan 03, 2016 | Samsung Gear Circle Bluetooth Headset
I am having problem getting my bluetooth headset 4pr909 to pair with my phone5
Well you have to sync it once it gets discoverable. I will include a link showing you how to do that. However I would suggest moving to a simpler and easier headset to pair with like a Samsung. Instructions for Wireless Gear Bluetooth Headset eHow
Feb 09, 2015 | Radio Communications
Nexus si9020 bluetooth & wi-fi not working
Try turn off cell remove back and remove battery and sim card if you have a sim. If the Samsung cell company wont help you fix the problem go directly to the Samsung company for a fix , if that don't fix ya call the attorney general of your location and request that they help with the cell. I had a galaxy and it kept shutting OFF by its self 4 of them as a matter of fact and the company I got it from would not fix the cell or replace the cell with a new one, they kept sending me someone elses reject.
Aug 17, 2013 | Samsung Cell Phones
Have a new motorola bluetooth h17. it pairs with the ps3 but wont connect, just error 8001000c. i even changed the audio settings to match the device and still wont connect
pairing motorola h17 with Ps3. Go to settings then to manage bluetooth scan find bluetooth (enter passcode 0000) hit triangle connect.(only first part keep reading) Now go to audio devices section under settings and change imputs to the motorola h17. If you don't go to audio devices the bluetooth wont stay connected. It will connect for like a second and stop.This drove me crazy for a day until I discover the fix. now go back to manage bluetooth and connect bluetooth and it should stay connected > you will see blue circle.
Aug 15, 2010 | Sony Playstation 3 (PS3) Console
How to connect samsung tocco mobile to another samsung tocco mobile using bluetooth?
Turn on the Bluetooth wireless feature.
To turn on the Bluetooth follow the below steps,
1. In Menu mode, select Applications > Bluetooth.
2.. Select the circle in the center to turn on the Bluetooth wireless feature.
3.. To allow other devices to locate your phone, select Settings > On under My phone’s visibility > Save.
To connect other device to your mobile
1. In Menu mode, select Applications Bluetooth Search.
2. Select and drag a device icon into the centre.
3. Enter a PIN for the Bluetooth wireless feature or the other device’s Bluetooth PIN, if it has one, and select OK.
When the owner of the other device enters the same PIN or accepts the connection, pairing is complete.
After connecting you can start sending the files from one mobile to another mobile.
To send files follow the below steps.
1. Select the file or item from one of your phone’s applications that you want to send.
2. Select Send via or Send URL via Bluetooth, or select More Send via Bluetooth
Thank You
Aug 12, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
If samsung bluetooth x820 do not work
hi there
this is a common problem with the x820, as it is so thin and bends slightly. the bluetooth component is underneath the thin LCD screen, so over time it has a tendency break.
The only solution is to actually get that component fixed, or just to live without bluetooth.
Jan 19, 2009 | Samsung X820 Cellular Phone
Just want to know which gear is the right gear.
the d with the circle around it is overdrive. the d without the circle is drive. overdrive is designed with highway use in mind. ideally, overdrive is for the highway and drive is for the city.... as far as i understand it.
Sep 09, 2008 | 1999 Chevrolet Lumina
Cell phone
look for the button that has a red circle with a dot in the middle of it that is your power switch
hold it down until you get a response.
If that gives you nothing you might need to charge the battery
Nov 16, 2007 | Samsung SGH-t629 Cellular Phone
Cell Phones Logo
37 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
