Question about Garden
Carburetor is leaking gas - Garden
2 Suggested Answers
  • 4 Answers
SOURCE: gas leak out or the carburetor
Thiis usually caused by a failure of either the float valve or the float itself.
Bad float needle valve: If some dirt or other particle gets stuck on the needle valve or seat, the valve will not be able to completely close and fuel will continue to flow into the bowl and eventually overflow. A new needle valve and seat are < $5.00 on-line.
Bad float: If the circular float gets a hole in it, fuel will get inside and the "float" will get heavy and no longer float on top of the fuel in the bowl. Because it doesn't float it will not rise high enough to push the needle up into the seat and keep extra fuel from entering the bowl. A new circular float is < $10 on-line.
Posted on Oct 22, 2012
Solution for gas overflow
Hi, Anonymous and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day.
Carburetor Troubleshooting Guide
Carburetor is leaking gas out of overflow tube need help
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY...
Carburetor float needle and seat trick
Mar 23, 2016 | GAS Motorcycles
Why is gas tank leaking?
you either have a hole in tank or a hose is bad, take some silicome and patch
Jan 04, 2016 | Garden
I have gas in my oil
I am going to assume that this is a model built before 2007 and has a carburetor. The only way gas could get into your oil that I can think of is through the carburetor. It seems you may have a slow leak from a bad carburetor float valve. It must be leaking from the carburetor to the piston area and then seeping by the piston rings to the crank case. The only way to correctly fix this (if that is the case) is to repair the leak by usually rebuilding the carburetor. In the interim, after you have changed your oil, make sure that you turn your gas off whenever you park the bike to prevent the gas flow and only turn it on when you are going to ride it and when you stop to park (no matter how short a time) turn it off.
Feb 01, 2014 | Harley Davidson XL 1200 C Sportster Custom...
Gentron 10000w generator has a leaking carburator
Your carburetor float valve may be stuck open. You'll have to remove the carburetor, remove the sediment bowl at the bottom of the carburetor (where the float is), and check the float. Is it filled with gas? Replace the float if it is. If the float is dry inside, then remove the float and clean the needle valve & seat. (be careful to note how the float pin, linkage, spring, etc. are positioned so you properly reassemble. After cleaning & reassembling, turn the carburetor upside down & try blowing into the gas line connection on the carburetor. You shouldn't be able to blow air. Turn the carburetor right side up & repeat. If you can blow air into the carburetor's gas line connection, the float valve & seat are properly working. Reinstall the carburetor. You should be good to go.
Dec 03, 2013 | Gentron 10,000W Generator with Electric...
Gas leaking from Ariens 42" 93603700
sounds like the carburetor Needle valve is sticking. A good Carburetor cleaning will fix that ...The easiest way to semi fix the problem is to buy a Small Shut off valve (about $6) and put it in the gas line between the gas tank and the carburetor. Then shut that valve off every time you finish mowing. This Ethanol gas that we are forced to use is a carburetor killer..
Aug 15, 2013 | Ariens Garden
Gas going out of tank when sitting up not running
Is the gas leaking out of the tank? Is the gas leaking from the carburetor? Where is the gas going? There have been issues related to the brass seat in some of the carburetors. The fuel leaks internaly in the carb. and "spills" over into the crankcase. This is noticeable by gas in the oil when you remove the dipstick. If this is what is happening, you would need to have the needle and seat replaced in the carburetor or replace the carburetor itself whichever is easiest. Hope this helps in some way.
Mar 03, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 7 year Craftsman 17.5 HP 42 in. lawn tractor. It starts to leak gas recently and stops frequently after running over 30-40 minutes. I can not identified where is the gas leak from but I saw gas on...
I have a Craftsman mower. Last year I had a similar problem with the mower stopping after running awhile. I noticed that the plastic gas tank was collapsing. The next time it began to stall, I immediately loosened the gas cap and it didn't stall. The vent holes in the cap had plugged up. Check this out.
I can't help you locate the fuel leak, although it sounds like the carburetor float is not stopping gas from flowing into the carburetor.
Dec 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
