Question about Pool Pump Pool & Spa
Why does my pool pump not have enough pressure l
  • 25 Answers
Usually, the filter needs cleaning. But it could also be air getting into the system.
Posted on May 21, 2017
How do I increase inlet pressure on my pump?
is this a self priming pump or a pool pump??? pool pump you might have a break in the pvc pipe that is allowing air to enter the system or the pump is too small or length of pipe run could be to long and in that case you need a larger pump..
Aug 17, 2015 | Pool & Spa
What does it mean if the psi drops 5 to 10 psi on the pool filter
Restriction before pump impeller or clogged impeller. Check:
Dirty skimmer basket, not enough water in pool, stuck weir gate in up position, plugged pipe coming into pump, if in ground pool, then yes,the pipe underground. It is not a restriction after the pump like dirty filter. If it was, pressure will rise!
Feb 11, 2015 | Pool & Spa
I have a polaris pool pump which is 5 yrs old and dead. Since general pool pumps of the same horsepower are much cheaper I would like to know if you can substitute a normal pool pump in place of th polaris...
I don't see why not, unless your trying to get above 40psi. I would focus on the pumps flow rate, that will give you a better stance on how closely the pumps relate.
Apr 11, 2013 | Polaris 280 In - Ground Pool Cleaner with...
I have a pb4 polaris booster pump that doesn't seem to put out enough pressure to run the pool sweep.
Check your in line screen and wall fitting to make sure they are right. Sometimes the over pressure button on the wall fitting will blow out.
Also, your local pool store should have a pressure stick they will lend you. It connects the end of the hose where the Polaris would be. You should be getting a least 28 psi. If you are getting less, you may have a clog in the booster pump's impeller. If you have that or more, the problem is internal to the Polaris. Verify that the backup valve is working properly as well.
Mar 21, 2013 | Polaris Pb4 - 60 Booster Pump
Water not coming at full force from pool into pump basket
It sounds like your pool pump is either not primed or is not strong enough to provide adequate suction. Check to make sure the pump is properly primed. Check for cracks in the lines that might also cause loss of pressure in pool pumps.
Jul 01, 2010 | Sta Rite 1 Hp Above Ground Pump Ne641
Pressure is running very high just cleaned fingers with acid and did not help we just had new liner put in pool is filled and have salt water system so there are no chemicals in pool yet because generator...
Depending where you live and how high your minerals run in the water. If it is old enough to change the liner it is probally old enough to get new socks for the fingers.
Jun 25, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Jet pressure
please change the impellar in your pump thank you
RATE ME
Apr 20, 2009 | Hayward 1.5 Hp Northstar High Performance...
Pool & Spa Logo
37 people viewed this question
Top Pool Pump Pool & Spa Experts
Lawrence Oravetz
john h
Steve Buck
Level 1 Expert
Are you a Pool Pump Pool and Spa Expert? Answer questions, earn points and help others
