Question about Royal Vacuums
I have a Royal vacuum cleaner; canister model SR30020, the power head/carpet cleaner "pulses/shuts off for a second before resuming" seemingly under "load", the head light also goes off at that point
  • 184 Answers
SOURCE: Losing power to stick/floor vacuum
if you have an extension wand, the replacement will cost about $100.00. there is a way to repair both the pwr-cord on the brush assemble and the wand, but it depends on how much damage there is. also you need to check the contacts where the wand connects with the handle,and the prongs on the handle.
let me know if you still need help
Posted on Feb 07, 2008
SOURCE: No power to head of Kenmore Progressive canister vac
The extension wands are defective and have trouble with their plug connectors on each end. The power head has a reset button on top right but no lights mean no power which means the wand isn't connecting the power to anything.
Sears has a new replacement -- too bad it isn't recalled so you could get it for free ($106.59 + tax + shipping). 2nd sweeper -- same problem.
1st sweeper: I just took needlenose pliers and pulled connectors out a little further (Too bad I can't seem to make the 2nd sweeper work with this easily. It might be one of the connectors or the wiring harness inbetween with a break.) Can't buy the wiring harness for this or connectors, just the wand.
If anyone has a working wand you want to sell me email me at hiwhatsnew@hotmail.com. Thanks!
Posted on Jun 12, 2008
advacak
  • 125 Answers
SOURCE: what bags do I use for Royal canister vacuum #3004
uses a royal or dirt devil type R bag
Posted on Dec 08, 2008
  • 1214 Answers
SOURCE: Royal 3050 power head does not run
The sounds like powerhead motor either burned up, or the belt broke and got tangled in the turning motor shaft. Pull the bottom off the power head and look for a curled up rubber band. If you find one, it's the belt.
If it's the motor, you won't hear it running when you turn the powerhead on.
Posted on Jan 23, 2009
  • 231 Answers
SOURCE: I have a Kenmore canister vacuum cleaner. The
check the reset button or the wire that goes into the powermate sometimes it frays and breaks
Posted on Jan 04, 2010
I need a manual for Royal 4600 cannister vacuum
I have a PDF from Royal for you.I would be happy to email it unless it is possible to post it here..?
Jun 08, 2014 | Royal Metal Canister Vacuum Cleaner Upper...
Dc 39 canister carpet brush will not turn
on the head there is a round filter type part if that is pushed in the the brushes won't turn. try pulling it out slightly.
Apr 07, 2014 | Dyson DC39 Animal canister vacuum cleaner
Why wont the brushes spin
check the belt is ok and the brushes are switched on
Jan 18, 2013 | Royal Lexon S20 SR30020 Canister Vacuum...
My dyson vacuum cleaner doesn't seem to have the same suction power it used to. I have cleaned out the canister and have taken apart the vacuum head (for cleaning carpets) and it doesn't seem to be...
Hello, this is Ava with Think Crucial.
Most of the time the reason why the vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this.
You can purchase a wide variety of high-quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 08, 2011 | Vacuums
Dec 29, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Auto-matic suction shut-off didn't resume once tank was emptied
look on the bottom of the tank and there should be a fitting on there take it off and clean..there should be some hind of float inside the tank.turn it right side up and tap on the tank the float might be stuck
Apr 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Jan 23, 2009 | Royal Procision 3050 Bagged Canister...
Carpet power head will not stay attached to telescoping wand
to answer your last statement, if you do not have a receipt, the warranty will go by the date ofyour serial number. the first 4 digits are the month and year. this model usually has a 1 year wty. the wand button may not be protruding as far due to dirt under the metal band. however you may still have an issue with the neck on the powerhead which will require shop service.
Jan 18, 2009 | Hoover S3765-040 WindTunnel Bagless...
Jan 11, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuums Logo
29 people viewed this question
Top Royal Vacuums Experts
Electroboy
Electroboy
Are you a Royal Vacuum Expert? Answer questions, earn points and help others
