After replacing the actuator, the machine goes through a complete wash and spin cycle. Then it goes back to sensing and wants to start over again.
We did order a door lock switch which has not been opened or returned. Is this a possibility?
Master_Tech
  • 770 Answers
SOURCE: Washing Machine Door won't open
did that work?? you may have a bad or stuck door lock
Posted on Jan 24, 2008
cerikitten
SOURCE: door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Posted on Feb 24, 2009
jumptrout51
  • 3361 Answers
SOURCE: My washing machine wont start. The door lock
You will have to replace the door lock wax motor.
Posted on May 21, 2010
SOURCE: Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Posted on Jul 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: Servis Easi Logic 1500(M6050) Washing Machine doesn't wash & spin
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 17, 2010
Why won't my washing machine stop cycling?
Sounds as if somehow machine got placed in continuous wash mode you have an F5E4 code tells me you know how to enter diagnostics go to diagnostic turn the knob till wash, rinse, and done are lit press the start button washer should not start and lights should go out unplug washer and wait 10 seconds plug back up should not start if not then you are done if so repeat process
Jan 14, 2015 | Admiral 3.4 cu. ft. Top Load Washer in...
Washer completes cycle 100% but then it restarts and starts filling all over again/ rewashes in essence
Dear William, I guess first you have to check if the start switch is shorted. When you turn on the machine, does it automatically go into cycle? If yes, then your start switch is faulty. Otherwise, you may have to replace your timer/sequencer.
Jan 16, 2014 | Washing Machines
Continues to go out of balance
The stainless steel bowl has lost its ballast water & goes out of balance,Replace faulty bowl.
Oct 03, 2012 | Fisher Paykel Fisher & Paykel AquaSmart...
Whirlpool cabrio wtw5600xw0 will not spin
There is a spin sensor that is part of the shifter if this is wet it wont sense the spinning, hence wont spin, and if it is wet you mat need to replace the tub seal http://www.appliancepartspros.com/gearcase-motor-pump-parts-for-whirlpool-wtw5600xw0.html
May 29, 2012 | Whirlpool Cabrio Washing Machines
Machine does not complete washing cycles.
the lid switch must be working properly for it to spin.this is the area on most top loaders where theres a small hole and the actuator on the lid goes thru it and activates the lid switch .inspect this area for wear or damage
Dec 31, 2008 | Hotpoint Washing Machines
Will not complete cycle
hi. i would check the lid switch fill the tub to low level let it start to wash stop the washer now put it to the spin cycle pull out knob close the lid slowly if it does not pump replace the lid switch now push on the lid. if it goes now .replace the lid switch .thanks te appliance doc. rate me please
Aug 22, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
