Question about Kitchen Ranges
How do I get the control panel to cancel or reset back to showing the clock function.
aborcass
  • 2651 Answers
SOURCE: control panel quit
you have somehow gotten the machine into a sabbath mode SAB. consult your user manual to tell how to exit mode.(try holding clock button in for 3-5 secs if not please get me entire model and serial ill research for you
Posted on Mar 04, 2008
Powerman
  • 68 Answers
SOURCE: Time flashes ...No other electronic button function
You may have the dreaded F7 problem. Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
Please let me know if this works for you. I have shared this fix with over 1600 folks and most report success. You can email me at hutchipop@yahoo.com
Regards,
Charlie Popeck, P.E.
Consulting Engineer
Posted on Mar 10, 2008
SOURCE: KUDS25SHWH1 Kitchenaid Dishwasher Control Panel Only CANCEL light on
I bought a control board for $127.00 figuring that was the problem but it wasn't. I called an appliance guy who came out and said its the touchpad that needs to be replaced. I ordered the touchpad ($325) since I already have to much invested in this dishwasher. I paid $1200 for it 8 years ago and its really a great dishwasher. My appliance confirmed that if it was the fuse-ling that you would not have any lights on.
Posted on Sep 03, 2008
SOURCE: can not cancel HOLD function to activate controls
There is a "Hold" switch on the back of the unit. Just move the switch to the other position.
Posted on Oct 22, 2008
taran_2005
  • 10515 Answers
SOURCE: Jenn-air electric double control does not work - clock is on
Disconnect the Power Supply for few minutes, say 30 minutes and then Turn the Oven ON.
Do you see any Error Message?
How old the Unit is?
Do you have any Experience to Fix this?
Do you have all the tools?
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 30, 2010
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Fi keeps beeping yet control still operates everything normally on my ge xl44 gas range model JGBP26GEN..it started last nite. Ive tried resetting the circuit breaker and pressing the keys in many...
The F1 code can be 1 of 2 things. Try disconnecting the ribbon cable from the touch pad to the clock. Then reconnect power and if the code comes back with 32 seconds the eoc is bad. If it doesn't the touch pad is bad.
Jun 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Display shows E0 F2 after pressing start and cancel at same time. No other buttons work. Stovetop still works.
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 14, 2010 | Whirlpool GY398LXPS Electric Kitchen Range
When you press bake it reads function not avaiable press help. the oven will not turn on but the display panel seems to be working
Unplug the oven or turn off the circuit breaker for 30 minutes. .When it comes back on press cancel,then set the clock and try again.
If it still fails to work you will have to replace the EOC electronic control(clock).
Jan 03, 2010 | Jenn-Air Ovens
Ewave panel is on lock
As per the owner's manual:
The oven operation can be locked to prevent the microwave from accidentally being turned on. All oven functions can be locked.
To Set: Touch and hold the CANCEL/OFF Pad for three seconds. The Display shows “LOCKED” and the oven beeps.
To Cancel: Touch and hold the CANCEL/OFF Pad for three seconds. “LOCKED” disappears from the Display and the oven beeps.
If this does not work, then try a hard reset: Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, you probably have a problem with the controller.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee. It may cost a little more if you need parts, such as a new keypad.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 26, 2009 | Frigidaire Microwave Microwave Oven
Kenmore range
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&!!
Jul 11, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven not working Message E0-F2- showing
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
Apr 20, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Oven won't work - its a timer problem how do I reset the timer?
I believe the control's child lock function is enabled. To disable it, press and hold the cancel key (will have small padlock icon under the word "cancel"). That should clear the condition.
Dec 24, 2008 | Whirlpool RBS305PDS Electric Single Oven
Thermador 30" Dual-Fuel Range 0FF error
Make sure there is proper electrical power going to range. Then check your kitcen circuit breakers or fuse box in your house, then reset the oven controls.
LOL look what i found, a CHILD LOCKOUT FUNCTION-- check this out
TO SET CHILD LOCKOUT
Press and hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF appears in the
display (approximately 6 seconds).
TO CANCEL THE CHILD LOCKOUT
Press and Hold the COOK MIN/HR and STOP TIME buttons until indicator word OFF disappears
from the display (approximately 6 seconds). Mode selections will now be available on the control panel.
looks like someones could have been playing with the buttons and locked you out..
Let me know what happen.........................please rate this
Oct 15, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Kitchen Ranges Logo
21 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
