Question about Whirlpool Washing Machines
I have a Whirlpool duet sport dryer, model wed8300sw1. What is the correct part # for the control board? Already ordered the wrong one.
dmftrucker
  • 1922 Answers
SOURCE: whirlpool duet sport displays f-22 code model
its an open exhaust temp thermistor
Posted on Nov 05, 2009
Daniel S
  • 4323 Answers
SOURCE: My Whirlpool Duet Sport washer with model
Hi
The part number for User Interface(part# 3 in image) is PS992556 and part# for Electronic Control (part#6 in image) unit is PS2362897. Please check the image for details--
Hope this helps....
Daniel
Posted on Aug 20, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Sport f-01 even after replacing CCU
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
ZJLimited
  • 17970 Answers
SOURCE: Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Posted on Jun 27, 2011
SOURCE: Whirlpool Duet Sport Dryer -model WED8300SW2 Dryer
Has anyone found the answer to this
Posted on Jul 17, 2011
Just replaced a control unit in my whirlpool duet sport dryer and now all lights on the front are lit. what is the fix?
What was the original problem? If this issue is different than the original, I would ensure that all connections were made correctly. If this is an OEM control board that may work in more than one type of dryer it's possible that there are some jumpers on the board that need to be moved. These jumpers connect small pins sticking up on the board that cause it to behave differently for different models. Look at the old board and compare it to the new board and move the jumpers accordingly.
Dec 01, 2014 | Whirlpool Dryers
Whirlpool duet dryer wont heat model wed8300sw1
check for 220 volts at dryer it will not heat on only halfe breaker, check heater for continuity and all the thermostats and sensors
May 07, 2014 | Whirlpool Dryers
Why my whirlpool duet dryer wont heat model wed8300sw1
Are the thermal fuses ok? If you're in the back of the machine clean out all the oose, lint, fluff or whatever that causes the heat build up.
Why wont whirlpool duet dryer model WED8300SW1 heat?
Is the dryer gas or electric? But you can also try cleaning the vent tube the pipe that goes outside also the pipe that goes into the dryer it's a good chance it's full of lint.
-Check your power source. make sure is not over load.
-Or disconnect main power and open back panel to visual check
all wire and connector. Possibly shock some where.
Good luck
Mai
Dec 20, 2013 | Dryers
Why won't the dryer heat
the heater element and/or the stats may need replacing
cheap on ebay.........
cheers
Jul 28, 2017 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool duet dryer stuck on control lock mode
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
I have a whirlpool duet front end loaded washer that has a controlled locked light that is illuminated. what is wrong and what should I do
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
