Need to find a replacement slide-out motor for a 2005 Carriage Compass 35KS3
How to change blower motor resister 2010 jeep compass
its under your glove box it may be your whole blower motor that has to be replaced. it also might be right next to your blower motor. you just need to remove the bolts and disconnect the wires. if they give you new wires i would replace them too. they tend to get a high resistance so that the blower motor doesnt get enough power
Jun 17, 2015 | 2010 Jeep Compass
Replacing the service station
Switch off the printer and remove the power cable
1. Remove the Right Cover
2. Disconnect the two lower connectors from the PrintMech PCA.
3. Unroute the two cables disconnected in step 2 from the two cable clamps below the PrintMech PCA.
4. Remove the grounding cable attachment screw from the PrintMech PCA.
5. Disconnect the Aerosol Fan Assembly inline connector.
6. Disconnect connector from the Drop Detector Motor and Drop Detector Sensor.
7. Unroute the cables disconnected in steps 4 and 6 from the two cable clamps.
8. Loosen the T-10 uncapping screw sufficiently so you can manually move the Carriage.
9. Push the Carriage Assembly into the print path to gain access to two T-15 screws that secure the Service Station to the Carriage Rail.
10. Remove the two allen screws that secure the Service Station to the Carriage Rail.
If you are uncapping a 44 inch printer, you will need to use either a very long or very short
screwdriver to loosen the uncapping screw.
In this way, you can loosen the screw and pass the rewinder motor.
Support the Service Station so it does not fall when you remove the attachment screws.
11. Unclip the clip to release the Service Station from the printer.
12. Lower the Service Station until you can slide it carefully from the printer.
13. Carefully slide the Service Station from the printer.
When you finish installing or replacing this component, you must perform the
necessary Service Calibrations.
Aug 28, 2013 | HP Designjet T610 InkJet Printer
How do you replace a rear window wiper motor on a 2005 Grand Caravan
No. Remove Interior trim panel on the gate door and you will see the wiper motor. Need tool to slide under trim edge and pop fasteners that hold trim in place.
Apr 11, 2012 | 2005 Dodge Caravan
My old Maytag washing machine (over 20yrs) doesn't fully spin "dry" a larger load of laundry.
The things to check on that old and reliable washer are obviously the belts and the motor slides..the motor slides one way to tension the belt on spin and the other way to tension the belts even tighter during the spin.
If your motor carriage is rusty the entire carriage could be replaced and keep that older washer going for a long time to come
The part numbers for the belts is 12112425
motor rollers kit 205999
Check out this page for a real good diagram of how they fit http://www.the-appliance-clinic.com/mytgmtrrollers.html
The parts can be purchased at your local appliance parts store on online at
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
partselect.com
I hope i have been able to help you fix your washer,
GENE
Aug 27, 2011 | Maytag Washing Machines
I have an epson 4880 with an error reading "service req. 0001001d" How can I fix this
Service Request errors in the range 00010004 - 000101D are related to a carriage movement problem. In some instances like paper jams, the carriage locking tab may be partially pushed in, causing the carriage locking mechanism to put a drag on the carriage or lock the carriage completely. This will cause a carriage error. Make sure the carriage locking tab is pulled to the left. Then turn the printer's power off and release the carriage by pushing down on the cutter blade. Slide the carriage to the left and look for any paper that also may be restricting the carriage from moving freely.
00010004 CR Motor encoder check error 00010005 CR Motor out of step 00010006 CR Motor over current 00010007 CR Motor in-position time-out 0001000A CR axis detection error 0001000F CR Motor PWM output faulty 0001001D CR servo parameter error
The T-Fence may also be dirty or out of the carriage encoder. Check to make sure it is clean and in the center of the encoder. Contact Epson for additional assistance.
May 09, 2011 | Epson 4880 Stylus Pro InkJet Printer
Compass calibration Hummer H2 2005. Compass shows "CAL" sign and the standard procedure described in Owner Manual doesn't help. What else? Thanks!
There is an offset that is used. I need to know what area of the world you live in. Then there is a digit that you set the compass to. and it is then CLOSER to actual.
Sep 01, 2009 | 2005 Hummer H2
Carriage belt replacement
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Aug 10, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
CANON IMAGE PRO W6400
This error code is a Carriage motor error. Below is the outline for what to check and what to repair/replace. Good luck.
Cause
This is displayed when a jam or other physical problem puts an excessive load on the carriage motor so that the carriage could not operate.
This is displayed when the carriage motor could not reach the prescribed speed within the prescribed time.
Probable problem locations
Foreign object in carriage movement path, carriage rail, carriage belt, linear scale, linear encoder, carriage motor, engine controller, system controller
Remedy
1. Carriage movement path check
Remove any foreign objects (jammed sheet) in the carriage movement path.
2. Carriage rail
Use rail cleaner to clean the carriage rails if a visual check reveals that they are dirty.
3. Carriage belt
If a visual check reveals slack in the carriage belt, remount the belt.
4. Replace the linear scale.
5. Replace the linear encoder.
6. Replace the carriage motor.
7. Cable connection check
Replace the cable between the carriage motor and engine controller if the connection is not functioning normally.
8. Replace the engine controller.
9. Replace the system controller.
Feb 12, 2008 | Office Equipment & Supplies
15 people viewed this question
k24674
jasbo
jasbo
