Question about Welding Tools
Chicago plasma 19136 not starting arcs when touches metal be nothing more.
4 Suggested Answers
  • 225 Answers
SOURCE: no full arc
the spark that you see when you touch work peice is high frequency,recheck connections like good ground (tight and clean)on the unit and work peice.no ground no fire.
Posted on Jun 28, 2009
luxur4
  • 92 Answers
SOURCE: Have an old craftsman mig welder, the wire arcs
unfortunatly many low cost MIG systems have live torches, check the instructions to confirm.
Posted on Jan 27, 2010
justjordy33
SOURCE: can't fine a operate-parts manual for a chicago arc 180 welder
I would go ahead and contact someone with <a href="http://www.suburbanweldingandsteel.com">chicago welding</a> they really know will be great.
Posted on Aug 02, 2012
When I turn the key on, everything comes on - fuel pump lights, etc. I push the start button and nothing, not even a click. Checked the ignition fuse and its ok. What else could be wrong?
HAVE YOU TESTED THE STARTER?WITH THE KEY ON OR OFF TRY BYPASSING THE BUTTON AND GROUND OUT THE STARTER..IF IT DOES NOTHING STARTERS BAD..TOUCH A PEACE OF METAL WHERE THE WIRE HOOKS TO THE STARTER THAN TOUCH THE OUTER END TO THE BODY OR NOSE CONE OF THE STARTER THIS SHOULD KICK IT OVER..PLIERS WORK WELL FOR THIS TEST.ONLY SHORT BURSTS..CAUSE IT WILL ARC INSIDE THE STARTER IF HELD TO LONG..BASICALLY WELD TOGETHER.. STARTER DOES NOT HAVE TO BE REMOVED FOR THIS TEST..
Feb 21, 2015 | 2002 Victory V 92 C
My tig welder wont arc unless I touch the metal with it
my guess would be the type of welding machine you have.usually there is extra switch which says start control also continious cycle , sometimes smaller machines dont have these switches to allow a wider variety of tweeking the welder ,also its ok if you have to touch the base metal cause thats what starts the contact with the work peice ,keep a arc after touching about 1/4 inch away from work peice ,also a good steady hand rest will make a good welder in any situation this should allow the arc to remaim stable with a comntinious weld arc puddle. happy welding
May 22, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
No full arc
Jun 03, 2009 | Welding Tools
Can't fine a operate-parts manual for a chicago arc 180 welder
Apr 09, 2009 | Welding Tools
Plasma cutters Question
There are a few things about plasma cutting safety that are different from general welding safety tips This short list of plasma cutter safety tips is geared toward light duty plasma cutting using compressed air not large industrial units that use gas mixtures and water cutting tables. Electric Shock Can Kill - Operating a plasma cutter completes an electric circuit between the torch and the workpiece. The workpiece and anything touching the workpiece are part of the electrical circuit. - Never touch the torch body, workpiece or the water in a water table when the plasma system is operating. Voltages & Currents - Plasma cutter output voltages are much greater than welding voltages, usually 100-200 volts. Precautionary Measures - Do not pick up the workpiece, including the waste cutoff, while you cut. Leave the workpiece in place on the workbench with the work cable attached during the cutting process. - During plasma cutting operations do not move the work clamp. Wear insulated gloves and boots, and keep your body and clothing dry. - Do not stand, sit or lie on or otherwise touch any wet surface when using the plasma cutter system. - Insulate yourself from work and ground using dry insulating mats or covers big enough to prevent any physical contact with the work or ground. If you must work in or near a damp area, use extreme caution. Work Cable - Ensure metal-to-metal contact between work cable and workpiece or work table. - Work cable clamp should make contact with clean metal free of rust, dirt, painted surfaces, etc. - Do not attach work cable to the piece that will fall away when the cut is complete Plasma cutter Arc Rays Plasma cutter arc rays produce intense visible and invisible (ultraviolet and infrared) rays that can burn eyes and skin. Protective Clothing - Guantlet gloves, safety shoes and hat. - Flame-retardant clothing to cover all exposed areas. - Cuffless trousers to prevent entry of sparks and slag. - Remove combustibles, such as a butane lighter or matches, from your pockets before cutting. Noise Levels of Plasma Arc Cutting - Plasma arc cutting systems can generate noise levels in excess of 120 dB during high-amperage cutting operations. - Ear protection should be used when operating or working near plasma arc cutting operations. Toxic Fumes & Gases Plasma arc cutting can produce toxic fumes and gases that deplete oxygen and cause serious injury. - Keep the cutting area well ventilated or use an approved air-supplied respirator. - Do not cut in locations near degreasing, cleaning or spraying operations. The vapors from certain chlorinated solvents decompose to form phosgene gas when exposed to ultraviolet radiation. Pacemakers & Hearing Aids - Pacemaker and hearing aid operation can be affected by magnetic fields from high currents. Pacemaker and hearing aid wearers should consult a doctor before going near any plasma arc cutting and gouging operations Overall Plasma Safety - The plasma arc cutting process can be very safe. - By paying attention to safety standards and correctly setting up and operating the system, plasma arc cutting poses no more a threat than most welding processes.
Aug 27, 2008 | Miller Spectrum 375 Cutmate Plasma Cutter...
Plasma cutters problem
Depending upon the design of the torch (e.g., orifice diameter), electrode design, gas type and velocities, and the current levels, several variations of the plasma process are achievable, including: * Plasma Arc Welding (PAW) * Plasma Arc Cutting (PAC) * Plasma Arc Gouging * Plasma Arc Surfacing * Plasma Arc Spraying
Aug 27, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
Plasma Cutters support
In this process, an inert gas (in some units, compressed air) is blown at high speed out of a nozzle; at the same time an electrical arc is formed through that gas from the nozzle to the surface being cut, turning some of that gas to plasma. The plasma is sufficiently hot to melt the metal being cut and moves sufficiently fast to blow molten metal away from the
Aug 27, 2008 | MILLER 192049 SWIRL RING PLASMA CUTTER
Pioneer Plamsa CMX 43"
pioneer customer service: 800-228-7221
C-Dog
Feb 10, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Welding Tools Logo
61 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
