Question about Sony Audio Players & Recorders
My sony Z5-H10CP boombox turns off when i turn it on why
Sony cfd 8 2
you need a new belt its not easy im sure thats your problem fixed a ton in my day
Mar 08, 2014 | Audio Players & Recorders
Sony stereo protect mode
If "PROTECT" appears on the display: Immediately unplug the power cord, and check if anything blocking the ventilation holes on the back of the system after "PROTECT" disappears. After you have checked the ventilation holes and found to be all right, reconnect the power cord, and turn on the system. If the issue persists, contact your nearest Sony dealer.
The above is from the manual at
May 24, 2013 | Sony Mhcec909ip Mhc-ec909ip Mini Hi-fi...
Can you help me unlock Sony CMD Z5?
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Sep 28, 2012 | Sony Ericsson CMD-Z5
I can't unlock Sony CMD Z5
It's locked to network ...You cannot unlock it?What methods have you tried to unlock it..?
You can get the correct unlock code for SONY CMD Z5(SONY Z5) model Phone at and unlock it easily..If its locked to security code you can try default code to unlock it.
Aug 01, 2012 | Sony Ericsson CMD-Z5
Sony boom box
There are a couple of things that come to mind, poor solder connections on the main board, or the audio output ic has a thermal related issue causing it to break down under load, a tricky problem to prove.
Apr 02, 2012 | Sony ZS-H10CP Radio/CD Boombox
It does not read my audio cds keeps saying no disc
its either you do have a defective pick-up lens assembly or spindle motor.
Aug 04, 2009 | Sony ZS-H10CP Radio/CD Boombox
Not powering on
More than likely.. unscrew the back cover and check near the power supply. Be sure to replace with the same rated fuse..
Jul 12, 2009 | Sony ZS-H10CP Radio/CD Boombox
46 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
