Question about John Deere Garden
I have a john deere sst18 lawnmower it will not steer going forward but will steer in reverse I have changed steering filters with no result
  • John Deere Master
  • 7,515 Answers
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
John Deere Spin Steer SST15 SST16 SST18 Service Repair Manual
Posted on May 15, 2017
Haudraulick problems on John Deere 3350
Try disconnecting a hose from the steer cylinder. Place the hose end in a 5 gal. bucket and see if you have flow from steer motor. turn steering wheel to the opposite direction of open hose fitting to check for steer cylinder piston leakage. Piston leakage will pressurize both directions of steer cylinder at the same time resulting in no steer. Be careful not to overflow your bucket. Reuse your oil if bucket is clean
May 21, 2017 | Cars & Trucks
John deere 425 transmission pushing fluid out of vent on top of transmission. PUmp making a whining noise
You have a fluid overheat condition here, so something is wrong inside the transmission that is causing this.
Feb 22, 2017 | John Deere Garden
Johns Deere 725 front mount lawnmower won't raise deck or steer. But does move.
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Oct 03, 2016 | John Deere Garden
Wiring diagram for a john deere sst18 lawn tractor
Russell if you truly want to figure out this problem you need to look at the wires and ware they connect .And what they connect to then drew your own wiring diagram its not that difficult if you break down and do a few tests with an OHM meter to see what is connected and what happens when you through a switch or run a jumper wire to a ground .
If you think about its not really that complex .
Jun 08, 2016 | John Starter Deere Sst18 Spin Steer Deere...
Why won't my john deere sst16 spin steer not steer in reverse?
I copied this right out of the operators manual for this machine, and it is a zero turn machine as well
" NOTE: Operating the mower while backing up is strongly discouraged. The Reverse Implement Option should be used only when operating another attachment or when the operator deems it necessary to reposition the machine with the mower engaged. "
an educated guess says they deactivated the steering in reverse
also I hope you have a supply of air filters for your steering valves for this model as ive replaced a few already for folks that have these
Nov 13, 2015 | John Deere Garden
John Deere Riding Mower won't steer after a rollover accident. How do we fix? Or even know what to fix?
not sure but if it is mechanical steering I would look for a bent tie rod on either side and from the steering gear under the hood ..
Oct 16, 2015 | John Starter Deere Sst18 Spin Steer Deere...
Why does my steering not working atfer my john deere 400 run awhile
bad check valve going to steering chang hydrostat fluid and filter
Sep 04, 2014 | John Deere Garden
My John Deere SST18 tractor will not turn left or right once I engage the PTO on the mower deck. As soon as I turn the PTO off, the tractor turns just fine. Any ideas/suggestions that I might try to fix...
Some more details would help. Your tractor has a combined electronic and vacuum controlled steering mechanism. Some people have reported your issue just because of a low voltage issue, and replacing the battery fixed it. In other cases there are two micro controller switches under the fender deck on the right side. These switches should both be able to be depressed and "click" and retract with a healthy solid feel. If not replace the switch. There are also 2 vacuum 'pots' and a vacuum system associated with your steering control. A vacuum leak may also be a culprit (although in my head that might be more constant). Does the steering work in reverse?
Oct 01, 2013 | John Deere Garden
Why would my sst18 john deere zero turn steer in
there is a servo under the main body on the right side win sitting in seat thats broken from the_w4ezv@yahoo.com
Apr 18, 2009 | Garden
Garden Logo
223 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
