Question about Tablets & eReaders
My fist question I forgot something. You can not make calls from this tablet and there is no place for a dime card inside.
Forgot my Apple password how can I down load kik with out it
Apple has a feature which allows you to say that you forgot your password. It is called iForgot. If you try to download something on your computer, it should bring up that option beneath the password and username bars.
Apr 18, 2016 | Apple iPad 32 GB WiFi Tablet PC
I forgot my password so now my iPad is disabled
Bad news. Call Apple suppport and have your changer card. They can get it unlocked. sometime's they will do it for free
Jun 11, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My screen is cracked and i can't type my password in
There is a place in Kitchener where they will fix any sreen... but i forgot what that store is called, sorry.
Mar 30, 2014 | Proscan PLT7035 7" 4 GB Wi-Fi Black Tablet...
Forgot my password for my sony s tablet
Hello Let me clarify you question. When you say forgot password do you mean that you put a protective password to sign into your tablet and that is the one you forgot? If so there is no way to get back in without it unless you do a factory data reset on your device.. This will erase everything including your personal data unless you have backed it up somewhere and any apps that you have personally placed on the device as well but you can get those back as long as you use the same google account.
Before doing anything if you have a sd card in side you want to take that out or everything that you have on that card will be erased as well.
1.Press and hold the volume up button and then the power button until you see a black screen with blue lettering
2. To get to factory reset use your volume up and down button
3 Use the power button to select it.
4.Then you are going to want to do the same thing again to get to reset tablet
5.Using the volume up or down to get to Reset Tablet and then use the power button to select it.
6.You will be prompted asking you if your sure you want to reset the tablet just click on Erase Everything. Your tablet will begin the resetting process
7. When your tablet comes back up it will be up at the activation screen ie the setup process.
Hope this helps.
Feb 20, 2014 | Sony Tablet S
Forgot password for Craig CMP741e tablet. tried to reset factory settings (holding on button with volume button) but wouldn't do anything
The only way to fix this is by restoring the firmware. There are two different firmware loads for that tablet, depending on the manufacture date. You can download the firmware for the older CM741E from the web site, but the newer firmware you can to get provided by Craig.
You will either need to make a bootable MicroSD card using Phoenixcard, or use a special software called LiveSuit to push the firmware into the tablet.
Oct 06, 2013 | Tablets & eReaders
How to save video onto sd card
In the settings of the camera app it should have something called 'default save location' or 'Memory in use' set it to "Ext. SD" card. Most tablets have an internal SD so it is important that you select EXT SD card (external SD card).
If you have already found that setting, and 'Ext SD card' is not listed as an option, you need to format that SD in the tablet itself so it builds the folders it needs. Put it into a PC first though to copy off anything you need because formatting it will delete all data.
Jun 04, 2013 | Mach Speed Trio DROID-7C Android 2.3...
How do i unlock tablet if a forgot the code
You should go to the place that you got it at.
Jan 05, 2013 | Visual Land Connect 7" Tablet
Forgot my password to get into my android table MID M729 the pattern on the top of the tablet
Normally, with Android devices, if you enter the wrong pattern five times in a row, the device will give you an option to enter your Google account information (e-mail address and password). Once you have done this, it will let you reset your security pattern.
If this doesn't work, the next best thing to try would be a firemware The firmware update process will wipe the root of the device (but leave your SD card and books intact), basically resetting it to factory settings, before you even set a security pattern.
Should this fail to work, contact Velocity Micro Support by calling +94756523353
Dec 28, 2012 | mid Archos M729B Android Tablet
The place where i enter my charger has broken inside the tablet
That you would need to go either to where you purchased it to be repaired, or they will have to send it out to the manufacturer to be repaired. That is not something you can fix yourself. At least, I would not recommend you trying.
Feb 17, 2012 | PANDIGITAL SuperNova
The sim card is stuck, jammed I to my galaxy tab; how do I get it out?
Cut up a plastic card like a coffee loyalty card or something that is the same thickness as the sim, and make it the same width as the sim
Before gluing the tip of this card, push it in the slot to engage the release mechanism inside.
Your trying to get the mechanism on the removal cycle where the sim will be closer to coming out.
once that is done put glue on the plastic card tip.
Wipe all excess glue from the flat surfaces. you don't need much glue at all. if you bought strong grade super glue it tends fuse to sim and plastic together. so less is actually more.
let it dry well past the curing time as its better to be safe than sorry, lets face it, the sims not going anywhere and l doubt you need to make an emergency phone call.
then if your plastic card is close to the thickness of the sim card as mine was, it will depress all the sim contacts and come
out with suprisingly little effort. it felt on mine like you should have been able to tap it out in the first place.
Apr 11, 2011 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
27 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
