Question about Baby Gear
The back wheels keep falling off. How do I get them to stay on ?
How to fix cutting unit which falls down on one side
There is a star wheel on the back side of the unit this wheel raises and lowers deck to make level. There is a lock bolt that keeps it in place, they often loosen and the deck falls. Loosen lock bolt adjust deck to same height on both sides.
May 03, 2014 | Yard Man Garden
Problem with heating up and staying heated.
Thermostat is sticking or heater core is not keep running it or it is going to ruin the engine. It is running hot regardless if is blowing cool or hot air. Do not keep using the car.
Apr 16, 2017 | 1997 Oldsmobile Bravada
My Bugaboo Frog's back wheels keep falling off! Whats the solution please?!
There are spring clips in the rear axle just behind the rear wheels. Yours are either no engaging properly or missing completely! Check page 20 of the manual. By the way you are my 500th solution!
Nov 19, 2011 | Bugaboo Frog Stroller
When pushing my quinny the back wheel starts to come of byitself
Hi Lisa - It could be that if there is dirt and debris on the wheel axel or inside the connection it would prevent the wheel clicking in properly. Remove both back wheels and give a wash in warm soapy water then dry thoroughly before putting back into place. Does the same side wheel fall off even if you swap the back wheels over? If this is the case it would indicate a chassis problem rather than a wheel problem. If it is the same wheel that always falls off it would suggest a wheel problem. Contact customer services on 01284 413 141 Mon-Fri 8.30-4.30 or e-mail to for further advice
Nov 14, 2011 | Quinny Buzz 3 Stroller
Chain keeps fallin off!
Does the rear wheel go on such that you can adjust it to take any play out of the chain? If so, turn the bike upside down or put it on a bike stand. Loosen the back wheel and pull it so that the chain is tighter and then tighten the wheel. There are other possible causes but I suspect this since you recently removed the wheel. Also I'm not sure how often the chain falls off. If this doesn't work, ask again and let us know how often its coming off. Good luck!
Mar 15, 2010 | Schwinn Windwood 26 Women s Cruiser...
Toro self propelled mower rear wheel keeps falling off
Are these regular bolt on wheels? Have you changed the nut?
I would expectc to find a "Stover" nut on such an appllication. Stover nuts are similar to "NY-Lock" but without the nylon lock. Rather, Stover (and you have to ask for them at the hardware or auto parts place), are not round and/or have had a certain side portion punched to make the nut hard to put on. Some well meaning back yard mechanics (read me) have 'fixed' the Stover by running a tap through them maning them easier to get onto the threads ... but alas, it didnt stay. That was how I learned about Stover.
Let me know if this helps.
Sep 21, 2009 | Toro Lawn Mower With Toro Power Tools
Seat on pushchair, wont stay up, keeps falling back into recline position - graco cleo air
Hi, i had this problem. If you put you hand down the back of the seat there is a strap with a 'holder' on it. If you tighten this as far as it will go this should hold it up. To lie it back again just release the 'holder'. Sound funny but once you look at the rear strap you will see what i mean.
May 24, 2009 | Graco Cleo 6D00TRF3 Truffle Travel System
Wheels keep falling off
Yes. Using a drill press if possible, drill a 1/8" hole across the axle, install a washer on the axle after the wheel and insert a cotter pin through the new hole.
Apr 28, 2009 | Heavy Machinery
Baby Gear Logo
22 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
