Question about Soleus Mini Split 12000 BTU A/C Air Conditioner
The squirrel cage in my A/C unit is noisey
I need to replace the squirrel cage according to a repairman, I agree. Can I do it myself or is it too complicated?
Thanks! Chip
    President:
  • 1,273 Answers
Not a problem. Disconnect the lecjucity (electricity) and replace in kind.
Posted on Jul 25, 2009
How to replace blower wheel on Friedrich SL28M30 AC unit
follow this steps and fix it. God bless you
    • 1
      Turn the electricity to the air conditioning unit off at the
      service disconnect box. Follow the wires from the AC unit to the
      disconnect box, usually located next to the unit. Open the disconnect
      box and, depending on the type, either pull the buss-bar or flip the
      disconnect switch.
    • 2
      Open the air handler\'s access panels with the correct size of nut driver, usually 5/16- or 1/4-inch. Save the screws.
    • Remove the control panel\'s cover, if equipped, with a nut
      driver. Some models have a flat metal cover over the electronic
      controls, and some control panels butt up to the unit\'s access cover.
      Save the screws and access cover.
    • 4
      Follow the wires from the blower motor. Two wires will go to
      a capacitor located on the blower\'s housing. The rest of the wires will
      go to the control panel.
    • 5
      Cut the wires leading into the control panel with wire cutters. Leave the cut wires connected inside of the control panel.
    • 6
      Remove the retaining bolts with either a nut driver, usually
      3/8-inch, or an adjustable wrench. The retaining bolts, found on the
      mounting brackets that the blower\'s housing slides on, keep the blower\'s
      housing locked into position. Save the bolts.
    • 7
      Slide the blower motor\'s housing out of the AC unit. The housing will slide straight out along the mounting brackets.
    • 8
      Disconnect the two wires going to the capacitor. They will pull straight off the capacitor\'s terminals.
    • 9
      Unscrew the squirrel cage\'s locking-screw with an adjustable
      wrench. The squirrel cage, the bladed wheel, connects to the blower
      motor\'s shaft inside of the housing. The locking screw holds the
      squirrel cage to the shaft.
    • 10
      Unscrew the blower motor\'s mounting screws with either a nut
      driver, usually 3/8-inch, or an adjustable wrench. These screws hold
      the motor to the housing and are found on the opposite side of the
      squirrel cage, the same side that the wires leave the motor.
    • 11
      Pull the motor from the housing. A drop of oil on the shaft
      will aid in removal. If the squirrel cage sticks to the shaft, then hold
      the shaft still with an adjustable wrench while spinning the squirrel
      cage on the shaft.
    • 12
      Slide the new blower motor into the housing. The blower motor\'s shaft will slide into the squirrel cage\'s hole.
    • 13
      Tighten the blower motor\'s mounting screws.
    • 14
      Spin the blower motor\'s shaft until the flat part of the
      shaft lines up with the squirrel cage\'s locking screw. Move the squirrel
      cage in or out until it does not touch the housing or the blower motor.
      Tighten the locking screw.
    • 15
      Connect the blower motor\'s capacitor wires, usually brown or
      brown with white stripes, to the capacitor. Direct replacement motors
      use the same color-coded wires as the original.
    • 16
      Slide the blower motor\'s housing into the AC unit along the mounting brackets. Install the mounting bracket\'s retaining bolts.
    • 17
      Connect the new blower motor\'s wires in the control panel
      one at a time. Disconnect one old wire in the control panel. Determine
      its color and connect the new wire, of the same color, to its place. Do
      this for all wires.
    • 18
      Replace the control panel\'s cover, if equipped, and the
      unit\'s access cover. Turn on the power to the unit at the disconnect box
      and test the blower motor.
Jul 17, 2013 | Friedrich Kuhl Series SL28M30 230 Volt,...
I have a New air 1400H and the blower fan has broke, can you tell me where to find replacement parts for this unit? I understand it has been discontinued for almost 5 years. Thanks for your help.Cont
You may have to remove the complete blower assembly, remove any dead squirrels, and take it around to various appliance parts suppliers to obtain a suitable replacement. You may need only a replacement motor if the squirrel cage is intact
Apr 30, 2013 | NewAir AC14000H Air Conditioner
Why does my ac freeze up
Hello, air conditioners will freeze either due to low airflow.....such as dirty filter, dirty evaporator coil, weak or not running blower motor. Also, a low refrigerant charge can cause the unit to freeze up.
Jul 09, 2012 | Danby Heating & Cooling
Shaft is stuck in the squirrel cage in swamp cooler how do i get it out?
If you are planning to replace the shaft;
if your able to loosen the 2 square headed bolts( which must be done to allow for shaft movement) do so, then after bearings and pulley are off emerycloth (smooth no burrs or rust) the shafts 2 ends and get grinder and cut thru the shaft on the inside of squirrel cage area as close to the edge of cage as possible drive the shortened pieces of the shaft inward( oil this pieces to help ease movement thru blower wheel) until they are removed replace shaft with new shaft and re-install parts and or replace as needed bearings and blower wheel. I am getting ready to do this very job myself ( take measurements of shaft on each side to ensure your back where you started when done)
May 28, 2012 | Mastercool 67680 Evaporative Cooler Air...
Centrifugal Switch Closed is what my Furnace is telling me and it will not kick on i have a Coleman Evcon heating and cooling unit
Hello, I had the same problem and replaced the Centrifugal motor which still did not fix the problem. It turned out to be the squirrel cage that the Centrifugal motor turns. It was sticking on the rubber gasket between the motor and the squirrel cage/housing assembly. I loosened the set screw that holds the cage on the shaft and moved the cage up 1/8th of an inch and it solved the problem.
Jan 13, 2011 | Heating & Cooling
When I turn on the A/C or the heater in my my 1995 Regal a sound is made like the fan blades are brushing against something. I believe something fell against the fan. Any idea how to access the fan?
The fan cage(blades) are bad,you will have to replace the squirrel cage,and you may have to buy it as a whole unit to get the squirrel cage.If this was at all helpful,please rate thank you.
Aug 20, 2010 | 1998 Buick Regal
The squirl cage on the dryer of my model LSE7806
Howdy,
Absolutely should be positively "locked" to the motor shaft. There should be a set screw in the collar of the squirrel cage mount. Either it is missing of has loosened. Please tighten (or replace) this set screw. Also, it is very IMPORTANT to make sure that if there is a flat machined surface on the motor shaft, that you align the squirrel cage (and set screw) so that the set screw will seat firmly and squarely against this flat surface. This design ensures that once properly aligned and set, that the squirrel cage will follow the motor shaft faithfully. Also, it is recommmended to apply some thread sealant (Locktite) to the threads of the set screw so this will not happen in the future. Vibration can be the cause of this.
Good luck,
J
Oct 20, 2009 | Maytag LSE7806A Top Load Stacked...
How does the squirrel cage come off of the blower motor shaft, I am replacing the motor it,s shot.
Most units are one unit. Motor and squirel cage. A machine is used to press the cage onto shaft. Otherwise shaft bolt should have hexagontal nut end if it is removable.
Oct 02, 2009 | 1991 Toyota Pickup
Running not blowing air
sounds as if fan isnt attached to motor shaft. There is a set screw on the fan cage that if it loosens the shaft will turn inside of the fan not turning the fan( also known as a squirrel cage) You need to get access to the fan motor and see first if its shaft is rotating, if it is see if the squirrel cage is turning if not the set screw located on the inner collar of the squirrel cage needs to be tightened. Thie set screw is more than likly an allen set screw.
Jul 07, 2009 | Heating & Cooling
Defective squirrel cage fan
Upon searching further, I found parts for the unit. www.appliancefactoryparts.com
Part CRCFD5303-010 Fan - $19.99
Part CRCFD3000-030 Motor - $49.99
Aug 03, 2008 | Maytag M7DH45B2A Dehumidifier
Heating & Cooling Logo
229 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
