Question about Canon Office Equipment & Supplies
My canon selphy cp710 cannot find mind usb port
Canon selphy 710 printing only bottom half of photo. how to correct this?
Hiya Jeannie it sounds like you may have overwinded your ink sheet as that makes it impossible to print to all the paper....hope that helps.
Mar 08, 2015 | Canon SELPHY CP710 Dye Sublimation Printer...
Repairs to Cannon selphy cp710
Canon Selphy is a very low cost consumer product. If it is not under warranty (for new replacement), you can expect no support for it even here in the U.S.
Feb 08, 2013 | Canon SELPHY CP710 Thermal Photo Printer
Problem in setting the printer spooling of my two cp800
1-800-243-0019 Call on our Toll Free Printer Support Number and we providing best service for resolve all printer spooling of my two cp800 issues.
Apr 14, 2017 | Canon SELPHY CP800 White Compact Photo...
Just bought a canon selphy cp 710 compact photo printer (pc) there is no manual with it nor is there disk to help get started. can any one help.
http://www.retrevo.com/support/Canon-CP710-Printers-manual/id/259ag515/t/2/
Please visit the site above and click the download icon for your manual.
Thanks
May 31, 2011 | Office Equipment & Supplies
I have a Selphy 710 that I've seldom used. Now when I insert a new ink cartridge, it cycles to the end and error box says "Ink cassette is empty and must be replaced." I've replaced the...
I'm having the same exact problem with my CP730. The paper size and ink cartridge are the same size. I've tried two new ink cartridges, same result. Frustrating and expensive.
Mar 09, 2011 | Canon SELPHY CP710 Thermal Photo Printer
Canon Selphy 710. The rollers don't grab the paper. Can this be fixed or do I have to buy a new printer? The drivers are up to date.
Had the same problem after not using the printer for many months. Removed the feed tray and blew into the printer. Then printed something but gently pushed the paper a few mm until the printer took it. Obviously top of the paper tray has to be removed for this. Expected to have to do this every time, but after four prints (which incidentally were perfect) it now works like a dream, taking the paper without attention.
Dec 15, 2010 | Canon SELPHY CP710 Thermal Photo Printer
Canon selphy cp760 photo printer will not print on my computer
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | Canon SELPHY CP760 PHOTO Thermal PRINTER
Cannot print from my PC
totally unload the driver and software. Then go to printer/faxes - install new printer and when the new hardware prompt comes up - ignore the CD prompt and select from list instead. select Canon select Model- then try come back with the result.
Sep 18, 2007 | Canon SELPHY ES1 Thermal Photo Printer
27 people viewed this question
old marine
old marine
