Question about Stanley Tools & Hardware - Others
Stanley stapler TR100 spring won't reload.
I put staples in and the gun fired once. Now the lever is loose like the spring didn't reload.
  • 32 Answers
SOURCE: Hi can't seem to reload stapler
All you do is open the end peice and slide the staples in on the two rails, point down. You should be able to see in the end to make sure nothing is blocking the rail with a flashlight. You probably have the wrong size staples. You can only use # 214, 215, 276.
Posted on Nov 26, 2008
SOURCE: refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Posted on Dec 05, 2008
  • 40 Answers
I would agree with rowdy that the make and model number are essential to getting the right parts - If you have that information, just find a dealer that supports your brand. That being said, air leaking out the trigger area is likely to be an O-Ring or Seal problem. Pneumatic staplers have O-rings and Seals that need to be replaced periodically. Most have rebuild kits available that contain all the O-Rings and Seals that need to be replaced. Many staplers have O-rings and/or Seals on or near the trigger shaft that can wear and allow air to leak out
Posted on Mar 14, 2009
SOURCE: Stanley TR 250 Staple Gun Staple cartridge problem
very simple to fix it 1 pull the trigger all the way out 2 there is a little piece of metal, pull it all the way out (detach the piece out from the gun) an connect one side of the spring 3 push the piece back on the gun. 4 on the other side of the spring tide a little fishing line 5 pass the fishing line over a small rounded piece and pull it hard 6 finally connect the side of the spring onto a little hock on the base of the trigger
Posted on Apr 21, 2011
SOURCE: There is a Stanley bostitch model B2000 stapler in
The person that asked this is probably long gone, but in case anyone else comes across this... I had the exact same problem when I dropped this same stapler today and the spring came out. After examining it for a bit, I realized where the spring had to go and fixed it.
Open the stapler the same way you would as if you were replacing the staples and look at the top piece, towards the back. There will be an elongated black hook here to attach one end of the spring. The trick is where you route the spring after that... look towards the front end of the same top piece, and you'll see 2 holes in the metal. You need to push the spring up through the first hole, then pull it back down through the second hole (you may want to use a straightened paper clip to snag the spring so you can pull it through that second one), and only then do you attach the other end of the spring to the hook in the sliding metal piece that advances the staples in the staple holder.
And that's it!
Posted on Dec 10, 2011
How to load staples
Staples newly purchased will always be attached when purchased and that answers your question...wherever the device u are loading has a horizontal channel, there will be a loading window at the end. Take it apart by realeasing the cap or spring at the bottom and sliding the train of staples into the channel inside. Replace cap or spring lever to original position and secure. Stapler is now loaded.
Dec 12, 2015 | Electric Stanley Tre500 Staple Gun /...
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
Where can I get a spring for a stanley tr100 staple gun
Have you tried contacting Stanley directly? They are about the only source for parts for their
Sep 06, 2014 | Stanley Tools & Hardware - Others
Pneumatic Hardwood floor stapler from Bostitch is misfiring
Put a little gun oil on the staples the spring that helps feed them might be catching
Dec 19, 2013 | Stanley Hand Tools
I have a stanley heavy duty stapler TC110. When I put my staples in, they don't seem to be catching. There is some black part sticking out of the end where the staples should come out. It looks like...
The staples load on the underside of the stapler.
Step 1 Push down and retract the stapler pushup mechanism.
Step 2 Position the stapler so that the moving hammer handle is down
and the staple exit is up
Step 3 Load the staples into the chamber on the bottom with the points up.
Step 4 Push the pushup mechanism into the locked position until it latches, you will feel the spring resistance as the staples are pushed into place.
Sep 04, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
Stanley stapler/nailer gun spits out more than one staple at a time
Sometimes a gun will double fire, quickly fires twice and is caused by worn trigger valve or safety foot. However, two staples driven with one shot indicates that the staples could be the wrong gauge for the gun or the driver is damaged. The driver of a nailer has a taper on one side of the blade to prevent the driver from hitting two staples. The taper will push the remaining staples back into the rails. Make sure that the taper is facing the staples and that the staples are correct for the gun.
Aug 25, 2011 | Stanley Carrying Case Bostitch Brad...
I have a stanley TR150HL staplegun and am trying to refill it with staples. How do I do this?
If you use the picture that is posted as a reference, the staples are put into the gun by removing the bottom right- hand ( black insert)spring loaded slider. To describe it another way ..... when you hold the stapler in your hand , the staples go in the shoe bottom at the very rear of the gun. This is shown as the black indent at the back and bottom of gun. It is keyed in and is spring loaded ( to feed the staples) so don't be afraid to wiggle until you see how it is kept in the load trough. Good luck....hope this helped.
Apr 12, 2011 | Stanley Proto Stanley TR150HL SharpShooter...
Refilling the staple gun
Oct 10, 2008 | Arrow 8000 Power Shot Pro Staple & Nail...
Tools & Hardware - Others Logo
88 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
