Artemide Tizio lamp has trouble lighting. Canged the bulb but it doesn't stay on. It flickers and turns off.
  • 78 Answers
SOURCE: Dashboard Lights - "brake lamp" light stays lit/ dashboard bulb for gas gauge burned out
you can remove the cluster and buy the bulb separate as far as the brake light it is either the float is bad in the master cyl. or you have low frt brake pads
Posted on Nov 24, 2008
  • 1075 Answers
SOURCE: Headlamps flicker when hitting bumps. Notice it
yes i agree, what you have done is what i would have been telling you to check so well done for saving you and me time.first its either one of what you say but its my guiss the headlamp housing is loose after what you have all ready done i think you will find the culpuit quick,TIP,if you find the housing loose try using cable ties they work a treat without haveing to use screws ,any problems dont be afraid to come back to me,adrian,,,,,,,,
Posted on Aug 20, 2010
news775
  • 699 Answers
SOURCE: JUST PUT NEW BULB IN
Your new bulb is not lighting.
Check the connections are correct.
Have you also tried putting back old bulb to see if it works.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 18, 2011
  • 36 Answers
SOURCE: The light on a fan
Try changing or testing the batteries in the remote or take the remote out of the fans range. See if this stops the flickering. It can also be the individual bulb. Sometimes the monofillament wires become loosened. It won't hurt the fan to use a broken bulb but it will shorten the life of the bulb. They do get the daylights shook out of them! If all the bulbs flicker it can be the twist connects. These are located under the ceiling plate cover. To check, shut off the fan or turn off the braker switch to make sure you don't get a shock (but I really doubt it). Remove the face plate ceiling screws to expose the wiring. There should be a black and a red cap that holds wires together. Black is ground red is power. One at a time hold the wires of the black cap with one hand and give the cap a gentle clockwise twist with your other hand to see if they need tightening. Repeat with the other colored cap. Push the wires back up inside the housing if needed and replace the cover.
These are the simpelist things to try before calling an expert. I hope this helps?
Posted on Sep 22, 2011
  • 657 Answers
SOURCE: Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Posted on Aug 15, 2015
Is it possible to fix the on off switch on a Tolomeo lamp? If yes, how?
Buy a new switch from Artemide and install it. https://homesteady.com/how-8005950-replace-tolomeo-switch.html
https://www.light11.eu/artemide/spare-parts-for-tolomeo-tavolo-and-tolomeo-terra-alu.html
Aug 30, 2015 | Artemide Tolomeo Mega Floor Lamp -...
Tip
BMW 650 Tail Light Problem
If you find that your BMW 650 CS/GS/Dakar tail light doesn’t work at all or flickers when riding, chances are the metal power terminals inside the bulb socket are no longer making a good connection with the metal bumps on the tail light bulb. This is a very common problem with the BMW 650 of all makes, models, and years. Fortunately, there is a very easy fix.
Due to excessive vibration, temperature changes, and replacing light bulbs, the two metal power terminal tabs inside the tail light socket deform and get pushed too far back inside the tail light chassis. This prevents the tail light bulb from making good contact with the power terminals and the smallest vibrations can cause the electric connection to break temporarily or indefinitely.
To fix the problem, all you need to do is pry the two metal power tabs forward just a little so that they make a better connection with the metal bumps on the tail light bulb. If you look at the back of the bike, the red tail light casing on the 650 CS/GS/Dakar is held in place with two screws. If you remove these screws the red tail light casing comes off and you have access to the light bulb inside. At this point, turn the ignition on, but you don’t need to start the bike. Remove the light bulb by pushing in and twisting clockwise about 1/8 turn. If the bulb flickered while removing it, then the bent power terminals are most likely the cause.
Looking at the tail light bulb you should see two metal bumps. These bumps need to make a good connection with the two metal power terminals inside the tail light casing. Turn the ignition off and find a small tool that you can use to pry the power terminals forward just a bit. Make sure the bike is off and you don’t want the power terminals tabs inside the tail light casing to touch.
After you have made the adjustment, turn the ignition back to “on” and re-insert the taillight bulb. If the bulb is lit, then you are done. If it still flickers a bit and doesn’t stay lit, then you will need to continue prying the tabs forward until a good connection is made.
on Dec 18, 2009 | BMW 650 Cars & Trucks
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Is it the ballast or the bulb which is faulty?
Put a new bulb in, if it works, the bulb was a problem, if it still flickers, the ballast is a problem.
Apr 10, 2014 | Ott Light OttLite Truecolor Table Lamp
Ceiling fan lights flicker in bedroom with 23watt cfl bulbs
Sounds like an older unit that has either a dimmer or electronic switch. You need to use dimmable CFL lamps.
Nov 07, 2013 | Hunter Dryers
Brake light on 2000 ford windstar doesn't work
bad earth the wire that goes to the car body could be lose
Apr 16, 2013 | Ford Cars & Trucks
The bulb is flickering. I have replaced it but the new one also flickers
replace the ballast I can send you one cheaper than you could purchase it I have 100s of them in storage always a ballast if they flicker
Apr 10, 2013 | Verilux Modern Deluxe Natural Spectrum...
I have a hampton bay ceiling fan. I put cfl bulbs in the lights and when i turn the lights off using the remote the bulbs continue to flicker. when i turn the wall switch off the bulbs stop flickering. the...
The problem is that the CFL lamps, once they are lit, will stay energized by a very low level of current, and the remote obviously is not what we would call a positive off device .. if you use the wall switch and then go back to the remote in the off position , do the lights come on flickering again? You could try another brand of remote.
May 19, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Tv went grayscreen, flickering. turned off, then
When you had gray screen and flickering you had only one problem - color wheel. After "putting everything together" you have totally different problem, caused by multiple possibilities like: forgotten connectors, cut/jammed cables/wires, lamp not being inserted properly, lamp door not being set properly, disconnected color wheel, etc. Try to open rear cover and redo what you have done. Remove optical block, check everything visually and slowly put everything back. If still no luck - then only skilled TV repairman may (or may not) help.
Mar 10, 2010 | Samsung Televison & Video
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
