Where does the fabric softener go? I haven't used it in so long I don't remember. I though it went in the big white agitator but it leaks right out on the clothes right when I pour it in. Thanks
Whirlpool WTW5310VQO bought at Costco. Hope this helps.
  • 78 Answers
I think we need a bit more information, like maybe the make & model of your washing machine...
Posted on May 13, 2017
Fabric softner cap keeps coming off during cycle
Push the fabric softener cup down and turn it to lock it into place
Dec 28, 2013 | GE WBSR3140DW Top Load Washer
Strange yellowish circle appearing on white shirts
i believe the stains are actually semi burn marks. If you are drying your whites try a lower heat setting. i had this problem with my kenmore dryer before too. Got bad especially with towels. Make sure your vent is not clogged and your filter is cleaned regularly to let the heat flow better. should help.
Sep 17, 2007 | Whirlpool LER8648L Electric Dryer
GE washer model # WHDRR418E4WW : Having trouble removing the plastic cap under the fabric softener dispenser, so I can access the agitator bolt.. There appears to be no simple way to remove it. There are...
that's right just put your fingers under agitator and pull up,under the agitator is a coupler that has a screw in it,whirlpool has the nut in there,if you have a problem with the agitator not moving the clothes around that coupler wears out and has to be replaced.
Oct 07, 2017 | Washing Machines
Fabric softener ends up around rim of washer.
When you say you've cleaned both parts - have you poured hot water in and seen it actually drain out of the top peice while it was removed from the agitator? Have you poured hot water into the agitator with the top peice removed and seen it drain out of the holes? If not, repeated flushing (of the agitator) and soaking (of the top peice) with hot water as needed until is drains may be required. Until you can get water to drain out of both peices alone, it will work automatically. Once you have the water draining try again with a regular load of laundry and fabric softener. If it still doesn't work...
Since you've cleaned both parts (the non-removable and removeable top portion) of the agitator - it would suggest that the fabric softener dispenser's actuator inside the agitator is not functioning properly. The fabric softener isn't being released in the rinse (or at all really) and as a result of the centrifugal forces during the high speed spin cycle - it is causes the fabric softener to move up the sides of the dispenser and spray out of the top of the agitator onto the rim. This may be caused a mechanical or electrical failure in the washer or washer control. It will continue to work like this until it is fixed - so I suggest that you do not use the dispenser.
You will likely need to have the washer professionally serviced to have it begin working again. You can save the repair costs and either add the fabric softener yourself during the rinse cycle - or use "dryer sheets" in the dryer instead.
Feb 05, 2013 | Washing Machines
I have an older Maytag washer without a user manual and was wondering if the cup in the top of the agitator was for adding fabric softener? If it is when do I add it and how much do I add? The model number... I thinking you are referring to item 7 which is listed as a dispensing cup. If I remember right it just sits on the agitator as a means to take off and use to measure soap, fabric softener. Since there is not a water flush line to it, I wouldn't use it to try to dispense the fabric softner. But it probably would do any harm to try it and see how much was actually left in the cup.
Jun 21, 2011 | Washing Machines
Gently remove the fabric softener cup off of the top of the agitator
Using a ratchet, an extension and socket; then remove the retaining bolt under the fabric softener cup.
The agitator will lift off after the bolt is removed.
Installation is:
Drop the agitator in place. Install bolt.... tighten bolt with ratchet, extension and socket. Install the fabric softener cup.
Fabric softener cup is item 14 this link:
The bolt you need to remove is item 4 of the above link.
Thanks for choosing FixYa,
Feb 05, 2011 | Maytag MAV6457 Top Load Washer
The fabric softener drawer keeps clogging what can i doit aslo gets mouldy and won't drain
Thanks for using FixYa. Check down the edge of the door seal, see if there is a lot of "gunk" there, this would cause grey marks on laundry. If it is a front load washer then try these steps--
You'll have to do a few maintenance washes to clear it out of the tub. Try these steps to remove the dirt, debris and odor from the washer—
  1. Set your machine to 60 degree wash.
  2. Now add 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it.
  3. Your drain will sparkle, and it will remove all the debris, lint & mold growth from the drain pump and drain filter. Also the mold from the door seal will be cleared
  4. Add 1 desert spoonful of Washing Soda to every wash... I sprinkle it along the crease in the door seal.
  5. Clean the fabric softener cup with a rag first, (bleach will not break up fabric softener as it is introduced in the rinse cycle with the fabric softener.
  6. Also check the drain hose, it should not be clogged.
This will clean your machine and get rid of the odor.
And, if it’s a top load washer then try these steps—
Remove the dispenser and spray with white vinegar. Then spray the agitator with it too. You can pretty much wipe it right out. Vinegar dissolves softener very quickly. The dispenser just wash out with warm water after the vinegar sits on it for a minute, and you hardly have to wipe at it at all. try adding bleach to the dispenser and clean it with a small brush.
The dispenser will pull off from the agitator and you can run hot water in it from the sink. The agitator is not as easy but has a 1/2" bolt holding it to the shaft. Remove the bolt and pull up. But you can clean the whole washer with a cup of bleach and that will also clean the agitator. Now run a full tub of hot water and then add a cup of bleach with no soap. After the washer has filled up, then add another gallon of hot water and that will help to rinse out the residues that cause odors. Then after that don’t use too much soap and you wont have residue build up. Only use the smallest amount of soap that the cup has marked in it.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Nov 10, 2009 | Bosch Washing Machines
Don't remember how to remove the agitator
withte palm of your hand youllneed to remove the fabric softener dispensor(a solid bump) will dislodge it, after that youlll gain acess to the center shaft of agitaotr, remove small white cover and underr youll see a 7/16 bolt head, remove the bolt and the agitaotr will pulll right up and then reinstall the same way
Jan 06, 2009 | KitchenAid KAWS850L Top Load Washer
Does the agitator in our machine have a fabric softener dispenser?
softner only ..liguid bleach goes in dispenser on right front corner
Sep 07, 2008 | Whirlpool Washing Machines
Whirlpool Imperial
With the machine off and empty, fill the softner bin with water only. Does the water level go down or stay the same.
Nov 28, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Top Washing Machines Experts
