Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Location of IC's
What are ic's and where are they located on the 60 inch Phillips projection tv
    Problem Solver:
  • 6 Answers
Re: Location of IC's
If you do not know what IC is i do not think you should be in a high voltage TV. IC is integrated circuit "CHIPS" and are all through the TV. What IC's are you looking for?
Posted on Dec 01, 2007
0 characters
3 Points
Where can I buy an STR-4525 transistor for my Toshiba Rear Projection tv?
That is a drawing number for the IC itself. I will need the model of the TV and the location number for that IC to be able to look up the Toshiba part number. The location number will be silk screened onto the pc board where it came from.
Dec 02, 2009 | Toshiba TP55G60 55" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips Magnavox 60" model ptv835
Recently had same issue and after EXTENSIVE SEARCHING found all three ICs and replaced them. TV works perfectly, also, replaced convergence ICs at same time. The one 16-pin IC for the regulation ckt. is $49.95 the other 16-pin IC is $19.95 and the 8-pin opto is about $10. This price is for a minimum qty. and must have a business for quote.
Aug 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergence IC
Andrews Electronics have an ETA of 9-6-8 on the part or you can contact I would either replace both IC`s or get a tech to do it, you can get them by calling this number 800-575-9833, they only sell the good ones,
Aug 19, 2008 | Philips 60PP9202 60" Rear Projection...
I have a phillips 60 inch projection tv double picture
Yes its the convergence ICs. You will need ywo STK392-120 ICs and about six of the 6.8 ohm 1watt metal resistors to repair the issue. You can get replacement ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can easially do the repair yourself and save about 400.00. Here is the link.
Jul 10, 2008 | Philips 60PP9202 60" Rear Projection...
Your Ics are bad and you prob have a resistor or two that have gone out too. If you are good with a soldering iron and have an hour to give up you can fix it. They are at location 7044 and 7045 on your board. They are STK 392-120's and the part number is 932212344682 good luck with you repair.
Feb 06, 2008 | Philips 60PP9352 60" Rear Projection...
Convergance adjustment
convergance amp ic bad
Dec 15, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
90 people viewed this question
Top Philips Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Projection Television Expert? Answer questions, earn points and help others
