Question about Microwave Ovens
I have a Gaggenau oven EB984 I think it has blown its internal fuse - was working perfectly now no functions at all
4 Suggested Answers
appliancguy
  • 86 Answers
SOURCE: Internal fuse blown , replaced
There are three to four switches that monitor that microwave. If any of them are bad it won't work. More then likely it's the monitor switch. There's a primary and a secondary switch. Take the cover off and look for the tech sheet it will show you which ones they are. They are around the door latch area...good luck.
Posted on Oct 20, 2010
  • 472 Answers
SOURCE: Oven suddenly stop working, think
if you have a radio shack around they normally carry these fuses....i am in texas and out guys working on appliances go to home depot to purchase ....
a company called
www.repairclinic may be able to help
or www.apdepot.com you can try
hope this is some help to you.....
Posted on Jan 05, 2011
heatman101
  • 43501 Answers
SOURCE: Microwave not heating!!!!! Probably Magnetron
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 22, 2011
Worked perfect now wont turn on changed fuse in plug still nothing, only had it a year It looks brand new inside and out
It is likely an internal fuse has blown also. Most ovens have one on the power supply board. then another in the magnetron supply. Don't mess with it yourself internally unless you know how to safely discharge the HV capacitor, which is lethal even when the oven is unplugged.
Jul 10, 2015 | Microwave Ovens
Microwave oven will not work
Power supply circuit may have failed, if your home experienced an electrical surge, it may be as simple as a blown low voltage fuse replacement, unplug and remove the cover, inspect closely with a good flashlight.
Dec 22, 2013 | Hamilton Beach Digital Microwave Oven
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
When I woke up this morning, the carousel microwave oven light was on, and won't go off. And, none of the start buttons work. Can set time, power level, other settings, but not start!
Thinkind about it, if you open the door, the light is on and you canset time etc but no start function.
Check/replace the door interlock switches as I think there will be a faulty one or the small internal fuse has blown if it has two fuses.
Hope this helps.
Jan 03, 2011 | Sharp R-510HW Microwave Oven
No power or functions of any kind.
Check the external fuse / circuit breaker first.
IF that is OK, then it's possible an internal fuse has blown. These can be replaced but it should only be attempted if you are confident enough to be able to discharge and ground the main capacitor before working on the device.
Mar 23, 2010 | Whirlpool GH4155XP Microwave Oven
The power blew while it was on with the dryer
check the hv capacitor for a short and fuse, if thats not the problem call electrician, sounds like a bad breaker
Feb 04, 2010 | Magic Chef CMV1000B Microwave Oven
Do not heats up , every think works but do not get hot, I notice that on the power level display something funny like -1-20, what this means and how can i fix it
Fuses
Door switch
Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Jun 30, 2009 | Magic Chef Microwave Ovens
Unit dead Unit is dead - suspect blown fuse
The reason for this is that if you do not have any experience and training with microwaves, you can get a SEVERE shock, even if the oven is unplugged. THAT being said, if you still want to know where the fuse is get back to me. good luck.
ALSO, as you may know, a small microwave these days is under fifty bucks at walmart.
May 20, 2009 | Sharp R-1880LS 850 Watts Microwave Oven
Frigidere PLMV169
the internal fuse has blown, if your capable undo the screws on the casing and the check all the fuses
Jan 31, 2009 | Frigidaire PLMV169DC Microwave Oven
Microwave oven not working but light is on
Door switch
Good luck and kind regards. Thank you for using FixYa.
Nov 12, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
