Question about Electrical Supplies
Got a Swiss Kraft SK1800 2000w generator/inverter used for first time, started an ran three times for approx 1 hr each, then no longer possible to start. Any idea what to do??
Funny nobody has got an idea about how to fix a problem like this. Well now I reassembled the generator, checked all connections, blew through all fuel lines including the carburator with compressed air, assemled and it started at once!!! Might be a tip for someone else........
CarlGehrke
  • 169 Answers
SOURCE: Generac Guardian 17.5KW Generator dies
If this is one of the big "taco cart" portables you need to check that the vent on the gas cap is open when you're running the engine. In the center of the gage on the gas cap is a little knurled knob, turn it counter clockwise (lefty loosey), about a half turn or so and run the generator.
If that doesn't solve your problem add to it here, otherwise please give me a rating I'm trying to build a little credibility here and could use the help.
Carl
Posted on Dec 02, 2008
  • 10865 Answers
SOURCE: Stale Fuel in gas tank
go to any auto parts store and get one of the products they have to remove the gum in the carburator and line. Some of the products are simply poured into the gas tank along with some fresh gas. good luck.
Posted on Jan 18, 2009
  • 496 Answers
SOURCE: Lights are on...nobody home.
It could be the transmission range switch is bad. Try starting in neutral instead of park. Jiggle the shift lever in park and/or neutral while trying to start. If this works, you'll want to change out the switch. If not, note that the transmission range switch allows power to operate a coil in the starter cut out relay which latches contacts closed thus sending power to the starter solenoid. The starter cut out relay could be bad--its located on the backside of the driver's kick panel fuse block. You could check the relay coil with your ohm meter.
Posted on Jan 27, 2009
  • 5 Answers
SOURCE: engine not starting grinding noise / i found the problem / timing marks assembley
the best advise i could give you is don't ride a yamaha be a real man ride a harley!!!!
Posted on May 19, 2009
  • 93 Answers
SOURCE: I have a 2001 Dodge Ram 1500 5.2L,
The plenum problem should not affect compression tests. It allows oil to get sucked into the intake and will cause carbon buildup, plug fouling, and pinging. If you have zero compression on a cylinder, it is usually a valve problem. Even a burned piston will make some compression, unless it has a big hole in the middle.
Sorry, but if your compression results are to be trusted (and it seems they are), then you have to tear a head off to find the problem, or at least get a borescope in it.
Posted on May 20, 2009
Wenger model 097.0699 has a 3rd hand that relates to a series of numbers 1-24 on a inner circle what is this for?
dual time. You can set the inner hand with 24 hr markings for other time zone. So regular hands for your local time and inner hand for other country or time zone.
May 13, 2014 | Swiss Army Wenger Sportedge Bracelet Watch
My onan emerald 1 genset is not transfering charge to the battery
Assuming your generator has the battery charger option?
Measure the battery voltage at the battery lead in the generator, without the unit running, or the motorhome ignition on. It should read approx 12V after the unit has been sitting a while. Then start the generator, it should rise to approx 13.8 with a good battery. If it does not then the stator windings and charge rectifier in the generator should be checked. If the voltage is 13.8 approx with the generator then you problem lies further upstream, and possibly with an isolation solenoid. If you generator does not have a battery charge winding/option then charging comes from the line voltage via a motorhomes inverter, check the inverter.
Sep 08, 2012 | Onan RV QG, 2500W GenSet, LP Gas
My Yamaha Ef2400iS inverter shuts off when I use my 3/8th electric drill. This problem started last fall. I could use the drill and portable saw, not at the same time, since the inverter was new three...
yes, the problem is that electronic/electrical components age with use. especially voltage regulators and switching transistors. as they age they can no longer sustain the current you are demandiing from the unit. the units are designed to run in the middle zone, not at full maximum load all the time, if you do that you will weat it out quicker. Always buy a power supply that is double your intended wattage and it will last many years. Hope this answers your question
Mar 21, 2011 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Yamaha Portable Generator EF 1000 iS won't start. Last time I ran the generator (several months ago) I let it run until it was out of gas. Yesterday I filled the tank and started the generator. It...
Try cleaning the carb out,(hog wash carb cleaner I use) the float may be stuck or the needle & seat.You may need a rebuild kit for the carb,about 12 bucks.hope this helps
Jan 09, 2011 | Yamaha 2500 Watt Industrial Inverter...
Wiring the 1750 watt eliminator direct to the main panel
DO NOT DO THIS! If I understand you correctly you want to have three ways to have 110 power in your motor home--- (1)Vehicle 12V to inverter to main panel. (2)Generator to main panel. (3)plug the main panel into 110V. If any two of these are connected at the same time and they are both live, somethings going to blow. That's because with AC, the two sources must be synchronized in their cycles very precisely. The utility company connects their power plants together on the grid only with the aid of precise controls. But the really serious problem is the same reason they invented transfers switches for home generators -- if you were connected to (3) and the power went out, and you connected (1) or (2) without disconnecting the dead (3), you will backfeed power to the line outside and you just might kill the lineman who is trying to fix the power outage.
May 20, 2010 | Eliminator MotoMaster Mobile Power...
Hello.. 2oo8 triumph bike just shut down at the worst time
Need to check and measure the generator's stator for correct current supply and install new regulator/rectifier and battery.
Jun 18, 2009 | 2004 Triumph Daytona 955i
Westinghouse lcd w32701
This sounds like bad inverter board.
Every time LCD goes from Standby to ON state - Inverter Board resets it’s self for approx. ~1 sec, during which time you should see blue screen.
Problem is that board detects problem with voltage/current on one of the seven transformers and shuts down automatically...
As to the costs:
- BestBuy repair service approx.. $600.00
- Buy new Inverter Board & repair LCD your self approx. $200.00
- Another option is to repair Inverter Board, but parts are sometimes hard to get...
Now for the DON"T TRY THIS AT HOME or AT YOUR OWN RISK solution:
-The cheapest method is to bypass protection circuit, by transferring good signal from working transformer (using 10nF/250V capacitor) to detection circuit at the faulty transformer.
Then watch movies on your LCD unlit BAD transformer totally BURNS-OUT.
This will be obvious by dark stripe about 1"-2" tall across your display.
Hopefully the only damage will be to the transformer and not CCFL (light behind your LCD), but when you are faced with a choice of using it for a while longer or throwing your LCD to garbage right now... to me this choice was simple.
Good LUCK.
Dec 15, 2007 | Westinghouse W32701 27 in. LCD HDTV
How long can I record using a DVD-RAM disc?
• Extra Fine mode (3-9Mbps record speed): Approx. 20 min. minimum per side. • Fine mode (6Mbps record speed): Approx. 30 min. per side (1 hour total). • Standard mode (3Mbps record speed): Approx. 1 hr. per side (2 hours total).
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Electrical Supplies Logo
63 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
