How to cut box on without remote - Televison & Video
I have a Blu ray player with no remote how can I operate it without a remote
Some blu-ray players cut costs by eliminating operations from the console directly and it sounds like you have one of those. What I would do is to get a cable box remote and they are usually universal remotes. Then go through the programming of the remote to control other devices in addition to your cable box, and select the DVD option so you can use that remote to control it. G
Mar 29, 2015 | Televison & Video
Remote broke, how can I bypass alarm to start
trace alarm wiring back to box then find immobiliser wires and join back together again where they were cut in the first place
Oct 03, 2014 | Vehicle Parts & Accessories
Emerson TV cutting off top and bottom of display
Its picture settings should be adjusted. Now it is set to 'wide' format I assumes. If you want to get full screen, the display format should be chaged. Without a remote control, it is not possible.
May 24, 2013 | Televison & Video
How to turn on curtis freeview box without remote my dog chewed
reset the code go to www.fitness.manualsonline.com or www. remotecodelist.com
God bless you
Jul 01, 2012 | Televison & Video
Factory alarm disabled starter, How do I reset it without remote
it probably isnt a factory alartm it most likly a dealer installed after market alarm or one of those chip type starter locks.look under dash for a little connector looking thing with wiers going to it NOT THE TRAPAZOIDAL CONNECTOR if it has that one you will have to reconnct the start wire that was cut to allow the thing to work [add on thing has failed] or look for wires that are not in neat order with splices to various things and a plastic box usually zip tied somewere under there. repair cut during installation start wire.
if it were a factory alrm simply lock and unlock door with key try all doors in case lock cyliner switch is bad on drivers door, also remote should do it to
Mar 19, 2010 | 1998 Volkswagen Passat
Lost my alarm remote 97GrandAm can't get car start without it.hlp
thier is away but u have to cut some wires around the fuses box..... or have it towed!
Mar 01, 2009 | 2004 Dodge Neon
Wide screen
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
The name of the button on the remote is called format.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Jan 18, 2008 | RCA F27650 27" TV
Picture size
For example:
Hope this helps.
Jan 05, 2008 | Toshiba 50H82 50" Rear Projection...
Picture partially cropped at bottom of screen
For example:
Hope this helps.
Dec 24, 2007 | JVC AV-27230 27" TV
Picture too large
For example:
Some Motorola Cable receivers need to be set up in the menu to go to a wide screen or zoom mode when an analog signal is detected. There may be a format button on the remote.
Hope this helps.
Oct 14, 2007 | LG 32LX1 32 in. HD-Ready LCD Television
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
