Question about LG Washing Machines
My LG WM1832CW has no error codes it will agitate but won't spin or pump water,so far I changed the sensor assembly and rotor assembly
    Habit-Forming:
    Scholar:
  • LG Expert
  • 167 Answers
Why did you change the sensor & rotor assembly? Did you test them first and found them to be faulty or are you just randomly guessing. If it doesn't pump the water out it will not spin. It has to be empty before spinning can start. So you probably have a drain pump fault. Start by checking if there is a blockage in the pump or hoses.
Posted on May 21, 2017
Washer no longer spins
if what you can provide what is the error code,,,?
Apr 02, 2014 | LG Washing Machines
Annoying LG Tromm wm2277hw "LE error" won't go away.
Might be "tE" error code. Thermistor error. A $6 parts and pretty common and causes the symptoms you described.
Mar 02, 2017 | LG 4775er2002a Door Hinges for Wm2277hb...
My fisher and paykel smartdrive wont agitate or spin but it pumps the water out it , when i spin the drum there is a bumping sound. can i get into the drum part to see if anything has gotten inside?
That is fault code 130
130.(10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
Jul 31, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel GWL 15 Rotor Position Sensor
Does It just shake bowl left & right, it will soon give you fault code 56.
Well its a board problem you will need to get technician to fix this board, three resistors(R129,R130,R131) need to be changed for a 1MegOhm resistor.
Jul 08, 2012 | Fisher and Paykel GWL11 Top Load Washer
I have an lg wm-2277HW that won't spin. i removed the back metal plate and found a bolt with a lock washer and flat washer on the bottom. i screwed it into the back of the tub where the rotor was...
Remove the top panel by unscrewing the 2-3 screws along the back side and then slide the panel towards the rear of the machine and take the top panel off the unit completely. You would then look down the back side of the machine this is the diagram to the tub area of your unit http://c.searspartsdirect.com/lis_png/PLDM/K0810345-00002.png your unit is controled by a stator assembly which has a stator sensor also known as an rps sensor. These are what are directly responsible to how your unit spins and turns without this sensor your unit would not go into any type of spin or agitate function at all. Did the screw look as if it came out of the center of the stator assembly? Also did you move the stator assembly or the sensor at all? Even the slightest movement to the sensor would stop the unit from going into any type of spin function. Your issue is in between parts 351, 350, and 360 on the diagram shown above if the stator assembly does not spin freely inside of the rotor then this would be one reason of why your unit is not functioning properly as well as if the sensor has been moved at all this could be another reason as well or if the sensor has malfunctioned at all this could also be another reason to the issue at hand as well. Does you unit give you any type of error code at all? In my opinion you may have to replace the sensor as with most rps sensor they go bad very easily and show a fault situation even easier. If you have any further questions message me back I await your reply Thanks Rick
Jun 28, 2011 | LG WM-2277HW Front Load Washer
Hi, I have an LG 1412RD washer dryer. I received the DE error message so opened the front to access the door lock and plugged in the electric socket which seemed loose. Now I am getting the OE message...
http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Owners manual above. LG washing machine error code – OEThe LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Apr 10, 2010 | Washing Machines
Washer will not spin LG Washer WM1832CW
1. Open back of the washing machine and control panel. Locate two wire harness coming out of main motor and main board. Check the wires for any cuts and harnesses for any corrosion. Fix the cuts and sand the corrosion to fix the issue.
2. Check the windings on the motor by pulling 3-wire connector from main board. Check resistance between each of 3 pairs using multi meter. The resistance should be 8-15 ohms. If one or more pair has no resistance reading then the winding is burned. Replace the rotor winding.
Rotor windings can be ordered from here: http://www.repairclinic.com/SSPartDetail.aspx?s=t-wm1832cw-%3d%3di1266809&PartID=1266809
3. If windings are fine then the hall sensor or speed sensor or motor sensor or sensor assembly needs to be replaced. The hall sensor sits on the inside of the rotor winding. Hall sensor has 4 wire connector attached. To remove the hall sensor: Open the outrunner or magnetic rotor from the motor first. Remove a big bolt at the center of the motor by holding the magnetic rotor. Once bolt is removed, the magnetic rotor can be removed by simply pulling it straight out. You may have to wiggle it a bit. Now remove a screw holding a wire going to hall sensor towrds bottom left of the winding. Now remove six inside bolts holding rotor windings to the drum body. The rotor windings are heavy so be careful while removing the bolts. Remove two wire connectors from the rotor windings and pull out the windings. Lay the rotor windings flat facing connector side up. Remove the hall sensor by praying out tabs.
Hall sensor can be ordered from here: http://www.repairclinic.com/SSPartDetail.aspx?s=t-wm1832cw-%3d%3di1268238&PartID=1268238
Jul 14, 2009 | Washing Machines
Need code/s for LG WM1832CW to have washer do a spin/drain only
1. press POWER button to turn om.
2. press SPIN SPEED button only.
3. press START/PAUSE button/
May 02, 2009 | LG WM-1832C Front Load Washer
LG Washing Machine Model # WM1832CW, Error LE shows up
Trouble shooting steps for LE error on WM1832CW:
Nov 11, 2008 | LG WM-1832C Front Load Washer
Washing Machines Logo
41 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
