Question about Elna Sewing Machines
Elna 540 Roll stitch - how to ddo it? - Elna Sewing Machines
Finding a manual foe Elba 540
Might try here:
ELNA eXperience 540 Manuals
Elna United States Machine Manuals
FWIW, Elna manuals are seldom free, so asking your Elna dealer may be a possibility.
Jan 19, 2018 | Sewing Machines
Overlocker elna 792d roll hem set up, please show how? To set settings?
3-thread rolled hem:
Remove left needle.
Settings as follows:
Upper looper 3-5
Lower looper 7-9
Right needle 3-5
Stitch length 1-1.5
Cutting width 3-5
Differential N
Jul 18, 2017 | Elna Sewing Machines
ELNA 540 Experience how do i use the foot marked with an R? What is the settings for a rollstitch?
The foot labeled R is the buttonhole foot. Raise the machine needle and put the foot on the machine. Pull the button holder to the back of the machine and place the button for the garment in holder. Push the button holder to close it against the button. For thick buttons, you may want a slightly larger space for the button. Just pull back the holder a fraction. Push the button hole lever down as far as it will go. (The lever is on the side of the foot near the button holder.) Place a corner of the fabric under the foot and press the up/down needle button twice. Pull the thread to the back of the fabric. Then position the fabric at the starting point where the button hole is to be sewn. Make sure that there is no gap between the slider and the stopper on the foot. Select the button hole style (06 regular, 07 oval, 08 keyhole). Then set the machine to sew. This is shown in the manual on pages 53-63 (pages 59-70 in the PDF).
For a rolled hem on a lightweight fabric, use stitch 10 and set the stitch width to 3.5 and the stitch length to 0.8. Use the Satin Stitch pressure foot (labeled F). Lay the edge of the fabric in the center of the foot. (Make sure that there is a clean cut to the edge with no dangling threads.) See page 48 of the manual (page 54 of the PDF).
Elna has the manual for the Experience 540 here on their manuals page: http://www.elnausa.com/en-us/pages.php?page=107 . The Experience 540 is listed on the left in the section labeled Top-loading 7 mm Max Stitch Width Machines. The direct link to the manual is http://www.elnausa.com/data/files/2_users/55/Inst-book-EL540%28EFG%29.pdf .
I hope this helps.
May 13, 2017 | Elna Sewing Machines
What are the correct settings for basteing on an elna excellence 730
Here's a manual for your machine:
ELNA eXcellence 730 Instruction Manual
If your machine does not have a "basting" stitch selection, you make your own basting stitch by:
* Setting the stitch length to the maximum
* Loosen the upper tension so the bobbin thread lies flat under the fabric
Then to gather or remove the basting stitch, it is easy to pull on the bobbin thread.
Mar 12, 2017 | Elna Sewing Machines
Which is the stretch stitch on my elna club 500
Here's a copy of your owner's manual:
ELNA 500 ELECTRONIC Manual Page 16
Although it does not show a "stretch" stitch per se, there are several that can work. Machines without any stretch stitch can simply use a zig-zag.
Jun 10, 2016 | Elna Sewing Machines
Set zig zag stitch on Elna Elina 40
I have looked but can't see a manual, but looks like push button stitch selection on front of machine, often it will be same as straight stitch, but need to take stitch width from 0 to 4
Feb 27, 2015 | Elna Sewing Machines
Elna 600 manual
I'm not sure about your machine but I've used an Elna that had a leaver for stitch length and when you pushed the leaver up all the way it would activate reverse stitching.
Apr 22, 2013 | Elna Sewing Machines
I am experiencing skipped stitched when sewing on a single knit. New needle and appropriate thread are used. Any other ideas.
Are yoiu using an anti static needle? failing that use a sofe toilet roll on your lap and feed the paper on to of the fabric then peel off afterwards and use a stitch length of about 4
Aug 28, 2011 | Elna 1010
My elna has cams to upgrade the number of stitches it can do but I am unable to get them to work. I believe I have installed them correctly but cannot activate them.
Throughout the Swiss Elna range there were several of their top of line models that have the black cams for additional stitches and they all have an "Elnagraph" device in the top of the machine case where you insert the cams.
There are single cams where the needle just moves ffrom side to side while the fabric moves forward. And double cams where the needle moves from side to side while the feed dogs move the fabric forward and backwards to get a combination stitch. The trick is to get the Elnagraph to engage so the arm in it can "read" off the disc.
There are a couple of other knobs that you need to adjust to get the cam stitch though.
Star Series: (white machine with blue top) you need to put the stitch selector inside the elnagraph flap to "A" on the Star series and then stitch width to 4 and stitch length to the red A zone.
Air Electronic SU or Carina: you have 3 knobs from left to right - stitch selector (put it on 7) , stitch width (put it on 4, orange area) and stitch length (turn it around to the orange zone for the automatic stitches).
And on the early Supermatic the adjustments are a little different again.
And ALWAYS turn the stitch width and length dials back to zero, before you change the stitch selector, or pop out a cam.
I hope this helps you get your Elna stitching from the cam, there is a great Yahoo group called Elna Heirlooms too where there are lots of knowledgeable Elna owners and some files listing all the cam stitches.
Apr 10, 2011 | Elna Sewing Machines
Sewing Machines Logo
32 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
