Question about JVC Car Audio & Video
How to turn off flashing lights on my jvc kw-910bt pandora stereo with bluetooth that is not connected
  • 655 Answers
SOURCE: Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
Posted on Jun 06, 2009
  • 30 Answers
SOURCE: what i need to activate the bluetooth on my jvc kw
To activate your bluetooth phone you'll need to connect the KS-BTA200 adapter I have the same radio with the adapter and love it. You pair the phone with the radio so when you get a call it mutes the unit the phone number shows on the video screen you tap the number on the screen to accept the call, you mount the mic on the visor and talk .
Posted on Jun 09, 2009
  • 22306 Answers
SOURCE: I am installing a JVC
on any after market radio their is two 12v feeds one permanant for the memory and one switchable via the ignition switch ,so use a meter to find the permanant feed and then the switchable feed from the ignition switch ,the radio will earth out down the aerial outer coax ,iam sure this is your only problem you just dont have the correct feeds .Now speaker wires you can test by using a small 9v battery on teh cables till you hear a blip,now these speaker wires normaly have say a white and a white with a stripe in ,these two go together ,then another colour and so on ,the 12v feed wires often have an inline fuse in the cable or a rf winding choke coil ,but the newer ones have a universal wiring kit that you buy to plug into the loom for a specific model
Posted on Sep 06, 2010
  • 8832 Answers
SOURCE: need wire diagram for 2001
Hi, here are your factory wire colors/functions. Aftermarket stereos have a common set of colors, which should be in your installation diagram. The process is simplified if you purchase a wiring adapter for your vehicle. These are available for under $10 at most WALMARTs and auto parts stores or about any place that sells car stereos. In either case, I recommend you solder the connections or at least use crimp terminals. If you have any more questions, please let me know--I've done a lot of stereo installations.
2001 Toyota Tacoma Car Stereo Installation Guide
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Posted on Jan 07, 2011
  • 10421 Answers
SOURCE: KW-AVX810 Car DVD Player: how to change the region code of JVC KW AVX-820...
Please get the code here :
Best Regards, Jay__8ifr4
Posted on Feb 27, 2011
JVC KW-R920BTS. Clock is set to correct time. When connected to BlueTooth, clock jumps ahead one hour.
So the device connected via Bluetooth is advising the unit of the time because the device is calling the shots. One device is set for local time and the other is summer time. Change the setting on the Bluetooth phone or whatever to local.
Non one else has encountered this problem according to my search.
JVC KW R920BTS jumps ahead one hour when connected to bluetooth device...
Nov 28, 2016 | JVC Car Audio & Video
Whenever I apply my left signal turn, my screen flashes on my JVC kw av 60bt deck ,message -check for safety behind with your eyes
Did the vehicle come from the factory with a jvc stereo or did someone install it ?If the stereo was not installed by the factory whoever installed it hoooked up the power wire to the blinker power wire and if the factory did install it i would buy a new blinker relay .
Oct 19, 2012 | Cars & Trucks
I have a JVC KW-AV60BT, pandora loads & displays but no sound comes through
Just got this unit and had a similar issue, but mine was getting the iphone to play at all. On advice of the sales rep I bought the kit required to view movies with your iphone. The kit plug into the back of your radio using rca jacks and then utilizes the usb port. I can now use my iphone to play audio, movies and utilize i heart radio.
Jun 23, 2012 | JVC Kw-av60bt 6.1" Touchscreen In-dash...
Problem with JVC KW-NX7000 Car bluetooth and gps messeage.
The bluetooth headset may not be compatible for the GPS reciever.. Check for the configurations for bluetooth.. and then install..
Apr 01, 2012 | JVC KW-NX7000 Car GPS Receiver
How do I use the bluetooth on my jvc kw-avx810
When i turn on my headunit the Bluetooth keeps saying please wait then it disappears . This problem is really annoying me can anyone please help me with an answer?
Nov 02, 2010 | JVC KW-AVX810 Car DVD Player
How do i connect my blackberry curve to the sony mex 2500. Bought of ebay,no operators manuel. Regards
1.) Turn off Stereo with the upper left button.
2.) Press and hold the EQ button just below it. the BT symbol will turn off, keep holding it, it will turn on, and then flash. when it flashes it is in pairing mode.
3.) go to connections/ Bluetooth on your phone and search for it. it will show up as XPLOD.
4.) the pairing code is "0000" enter and it will tell you connected xplod
to listen to music make sure it is in BT Audio, Also call quality is not that great, but it is an awesome unit to listen to some slacker/pandora over Bluetooth!!
Jan 05, 2010 | Sony MEX-BT2500 CD Player
JVC KW-NT1 GPS not working in UK
Have you tried re-flashing the unit with the latest EU firmware update available from the JVC website? Should overide the current firmware then allow you to use UK maps. If it doesn't work you can always reflash it with the USA update.
Nov 28, 2009 | JVC KW-NT1 Car GPS Receiver
HTC Bluetooth Connectivity with JVC AVX800
can't connect my htc phone(3450) with bluetooth earphone
Sep 16, 2008 | JVC KW-AVX800 CD Player
Car Audio & Video Logo
44 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
