Question about AEG Dishwashers
MY AEG DISHWASHER WHICH IS NOT 2 YEARS OLD HAS JUST STARTED SHOWING !50 very aNNOYING AS SERVICE MAN HAS NOT ANSWERED THE MESSAGE i LEFT ON HIS PHONE
heralddriver
SOURCE: DISHWASHER AEG 80860
Just fixed a similar problem on an AEG F3A by following other advice on this site. Simply tip the machine forwards on to its door (best empty it of crockery first!!!).and then put it upright again when water has stopped dripping out of it. You wil get quite a bit of water on your floor which I reduced by pumping the water out of the salt resevoir first - but if you don't have a pump just have several towels handy
Posted on Oct 25, 2008
SOURCE: AEG 60830 Leak prevention system
Just pulled machine right out, tipped it over on the side, couldn't see anything obvious or a way "in", so re-positioned it - switched on - error message gone and all working fine !!?!
Posted on Feb 18, 2009
SOURCE: AEG Dishwasher FAVORIT 3A Error Message C3
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
Posted on Mar 05, 2009
mgprice
  • 744 Answers
SOURCE: Replacement of control board for Electrolux Icon 30''
Hello, I am going to go out on a limb here and risk a bad feedback score but I have seen this many times in the past few years and have even made the mistake of replacing the EOC (Electronic oven control) when the EOC was not the problem, Reading between the lines with no model number I'm going to assume you got the error code for a bad EOC which is why the repair guy changed it. Well the second one could be bad too but I seriously doubt it. To me after changing the EOC and it still don't work the problem is going to be with the touch pad if it has one (be mindfull I dont have model number so I don't know other then electrolux which oven this is). The way to test this diagnosis is to turn the power off...Remove the ribbon/cable harness from the touchpad to the EOC. Switch power back on and wait 24 hours. If Error code does not return it's the touch pad, if within the 24 hour period the error comes back it's the EOC. Can't be any easyier then that to figure which it is and any tech worth his salt would know that. Hope this helps some, Maybe you can try it while you are waiting for the new part. Good Luck!! if you have any further questions or concerns please feel free to comment again. Mike
Posted on Jul 20, 2009
joe_lishman
  • 192 Answers
SOURCE: aeg favorit 86070 vi fully integrated dishwasher
This is typical of the anti-flood circuit that opperates once it detects water on the base of the machiene and is a polystireen float that activates a micro switch. This puts the machiene in pump out mode only. You need to determine if the water at the base of machiene is caused by a small leak or is it a customer spillage. Clearing the water (tip to side) or dry with paper towel and inspect for leaks. Rectify the leak and this should solve the problem.
Posted on Jan 19, 2010
AEG OKO FAVORITE 4070 - AFter not using for a week dishwasher is flashing dry & end together, will not switch off unless turn it off at the power point, there is no water left in the machine.
If the END or DRYING indicator on the programme progress display is flashing, you can probably rectify the fault yourself.
After rectifying an END or DRYING fault, press the button for the wash programme that has been started.
The wash programme continues. If the fault is displayed again, than check water leakage in the battom of dishwasher.
Malfunction: END and DRYING on the programme progress display are flashing simultaneously.
Possible causes: The leak prevention system has been triggered.
Remedy: Try to find and repair water leakage otherwise close the tap and call customer service.
Dado
Mar 16, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Problems disconnecting the wastepipe on an AEG Dishwasher
Pour some bleach into the stinky backwash. I know that this is not good for the environment but it will take the stench away while you get a new dishwasher. Sorry but you have plumbing problems out of my range.
Oct 25, 2012 | AEG 24 in. Favorit 80800 Free-standing...
AEG Electrolux FAV80870 dishwasher does not dry. After the cleaning the interior is not warm at all like before. Please can you suggest what could be wrong. Appliance is 3 years old. Thanks for the help.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Jul 28, 2010 | AEG 23 in. Favorit 88070IM Built-in...
My AEG Favorit Sensorlogic Turbodry dishwasher is making 3 short continuous beeps which I understand means the leak prevention system has kicked in. Is there something I can do to reset or must I call a...
Open the left metal panel, if the white plastic tank is black at the bottom or is not clean: remove it, open it, clean it (make sure the water flows through properly) and put it back in.
Mar 04, 2010 | AEG 24 in. Favorit 80860iW Built-in...
Feb 17, 2009 | AEG 24 in. Favorit 60830 Free-standing...
AEG 16810 UPGRADE WASHER DRYER E10 ERROR
This is worth posting in case anyone else has the problem. The mechanic was stumped and then around 3 days later a Zanussi gave the same problem - steam emitting from the drum. He changed the valve - the entire unit. Problem solved. Zanussi and AEG have identical internals. He changed our valve - problem solved.
Jul 22, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Oct 24, 2007 | AEG Dishwashers
Dishwashers Logo
Top AEG Dishwashers Experts
paulcarew
Kolbrun...
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
