Question about Hardware & Accessories
Guide for installing a Grasslin anologue talento111 timer switch
2 Suggested Answers
SOURCE: I have a Grasslin talento 371 easy timer (digital)...
Try this link 6.7_talento_371+372_(V97_1_2digixx)_ls1_xx.pdf
Posted on Sep 23, 2010
Problem with Grasslin Towerchron QE2
1) Contact Grasslin UK for warranty coverage:
2) Reset timer and reprogram.
Move slide switch to to right 'set own program'
Then when times are programmed, move slide switch fully right to 'run own program'
3) Test that unit is receiving at least 80% rated voltage 240V x 80% = 192V
4) Buy another unit
Jan 29, 2013 | Hardware & Accessories
Grasslin ecosave timer not working
Add a comment and say if the timer worked before and stopped working, or if this is new installation that does not work correctly.
Otherwise the timer expert is guess that the problem is incorrect wiring, defective timer, tripped circuit breaker, or if the clock motor has gotten weak over time, and stopped working.
Or, Contact Grasslin UK:
Aug 25, 2012 | Hardware & Accessories
I do have and Intermatic ET724 timer and it has stopped working. I don't think it works with battery as it is attached to our bathroom light switch . any luck to fix it? or it is time for a new one??
That's a good old timer.
Grasslin ET724 in-wall timer is no longer available.
There are several programmable timers on the market.
Intermatic EJ500 is simple to install and program. Works on battery but is for incandescent light only, not for fans.
GE 15071 from Home Deport is inexpensive replacement and works with fans, lights.
Needs no battery. Uses electric circuit to operate clock.
More timers:
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 20, 2011 | Intermatic ET724-A-CS - 24Hr. and/or 7-Day...
Grasslin timer instructions
Grasslin timers and manuals
Click timer-categories on left to see drop-down menus
Grasslin electronic time switch
Click on model number and drop-down menu shows manuals
Oct 11, 2010 | V, Inc. 12v Dc Timergeneratortransfer...
How to set the time and which is on out or in
pins IN = timer ON
pins OUT = timer OFF
Slide-switch must be pushed to right for timer to work
If dial is not rotating, wiring is incorrect (see below for wiring)
Grasslin and Paragon both offer multiple-gang timers.
Grasslin manual says:
" For example, to turn lights ON at 5:00pm and OFF at
11:00pm, leave inward the 18 trippers between 5 and
11 on the "pm" side of the dial.
Link to Grasslin manual
Wiring timer:
Timer black goes to Hot wire
Timer red (or blue) goes to Load
Timer white goes to Neutral (if no neutral, then connect to bare ground)
If timer dial does not rotate, black and red wires are reversed
Oct 08, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Hardware & Accessories Logo
51 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
