Question about Sewing Machines
Can't get thread to meet from bobbin - Sewing Machines
4 Suggested Answers
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
  • 30 Answers
SOURCE: I own a husqvarna emerald 116 sewing machine, and
is the bobbin thread in correctly( meaning is the bobbin thread in the lower tension) if it is and the top thread is in correctly and make sure the feeddogs are in the up position if all of these factors are alright then it will have to go to a local dealer to get taken care of
Posted on Oct 28, 2009
  • 980 Answers
SOURCE: I have a sewist 525s and the bobbin thread keeps
make sure you have the machine threaded properly especially the bobbin which should turn anti clockwise
Posted on Mar 07, 2010
I have a Elma 6003 the top stitch is working fine but bobbin is running straight line on bottom could be timing? Adjusted tension already
If the bobbin thread is tight, then its tension needs to be loosened. It should be flexible enough that the top thread can pull the bobbin thread up halfway into the fabric. The ideal tension is when both top and bobbin threads meet in the middle of the fabric.
Aug 12, 2017 | Sewing Machines
I cant get my bobbin to meet the needle thread
Be sure to install a brand new needle. Check that it is threaded correctly (top and bobbin).
If it still will not pick up the bobbin thread, it may have a timing issue, ie the needle is arriving at the bobbin at the wrong time in order to intercept the bobbin thread. You can search the internet for web sites and videos dealing with sewing machine timing or take it for service.
Oct 26, 2016 | Sewing Machines
I'm having trouble properly threading my Elna 1010. Could you please help? The bobbin thread keeps bunching up and breaking
bunching of thread under the material is an indication of insufficient tension of the needle thread
increase the needle tension until the threads meet at the center of the materialbeing sewn
Jul 26, 2016 | Elna Sewing Machines
How the bobbin loads and works with the top thread.
Turn the machine wheel slowly to watch the depth that the threaded needle travels so that it meets the approaching hook-point of the bobbin holder. Point should almost touch the needle side and grab the thread just above the eye and wrap it all the way around the bobbin and holder. If the needle extends too far, it will jam. Not far enough and it doesn't reach the turning hook.
May 02, 2016 | Kenmore Sewing Machines
Bobbin thread shows on top
Upper tension is too tight. Loosen upper tension and the bobbin thread should go back down. Correct tension is when upper thread and bobbin thread meet in the middle of the fabric.
Mar 27, 2016 | Sewing Machines
How do you set the bottom tension and/or where is the thread clamp
Be very careful adjusting the tension on the bobbin case. Generally, most tension issues are regulated using the upper tension adjustment unless the bobbin case is broken or someone has attempted to adjust it incorrectly. In any event, adjustments to the bobbin case should be made ONLY 1/8 of a turn at a time--then do a test stitch. Before making any changes, mark with a permanent marker where the screwdriver slot meets the bobbin case in the event you have to return it to the original position.
If the top thread is looping or knotting under the fabric (bird nesting), the upper thread is too loose or it is threaded incorrectly.
If the top thread is pulling the bobbin thread to the top of the fabric, the upper tension is too tight.
Tension is ideal when both threads meeting in the middle of the fabric.
Dec 11, 2015 | Sewing Machines
Bottom thread too loose; tried rethreading top thread, cleaning bobbin case, refilling bobbin, changing needle, adjusting top tension
Check for correct bottom thread tension.
It's provided by a flat spring on the bobbin holder.
When the bobbin is correctly installed, pulling on the thread
should meet with slight resistance, and the bobbin should spin without
trying to jump out of the bobbin holder.
Dec 18, 2010 | SINGER 7470 Sewing Machine
Needle will not sew thread into material
Sounds like the timing is off. Take the bobbin out of the bobbin case and lower the needle into the needle plate. As the needle starts on the upswing, the hook should meet the needle just above the needle eye on most machines. If it isn't meeting at that point then your hook timing will need to be adjusted.
Mar 13, 2010 | Singer Tiny Tailor TT700
Jul 29, 2008 | Singer Inspiration 4210 Mechanical Sewing...
Sewing Machines Logo
18 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
