Question about Casio Office Equipment & Supplies
How to do matrix multiplication in Casio fx-991EX
SOURCE: Weather casio FX-115ES can solve 5*5 matrix
According to the manual for the Casio FX115ES, the largest matrix it solves is a 3x3.
Posted on Sep 11, 2008
  • 8016 Answers
SOURCE: how to calculate inverse of a 3x3 matrix in casio
Here is the solution for th FX-991ES.
The error may be due to the key you used to signifie inverse. It says in the manual that you should use the key x^-1 not the one used to input general powers.
Here is screen capture from the Appendix to the manual. The picture shows the sequence of keys to press to obtain the inverse of a 2x2 matrix. It is taken from page 41 of Appendix
The matrix used in the exemple is
a_11=2 a_12=1 a_21=1 a_22=2
Here is the link to download the manual and the appendix
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
The link is for FX991ES. Look there foe you manual.
Hope it helps
Posted on Sep 07, 2009
  • 8016 Answers
SOURCE: How to do matrix multiplication on Casio 115ES?
Hello
First you must set Matrix calculation
[MODE][6:Matrix]. Then By entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix
(mxn]. Once finished entering the matrix you clear the screen.
The operations on matrices are available by pressing [Shift][Matrix]
[1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
[2:Data] enter values in a matrix
[3:MatA] access Matrix A
[4:Matb] access Matrix B
[5:MatC] access matrix C
[6:MatAns] access the Answer Matrix (the last matrix calculated)
[7:det] Calculate the determinant of a matrix already defined
[8:Trn] The transpose of a matrix already defined
To add matrices MatA+MatB
To subtract MatA-MatB
To multiply MatAxMatB
To raise a matrixe to a power 2 [x2], cube [x3]
To obtain inverse of MatA already defined MatA[x-1] [x-1] is the x to the power -1 key
Dimensions of matrices involved in operations must match (see you textbook for the rules)
Read the appendix to your user manual, there are several exemples.
Hope helps
Posted on Sep 12, 2009
  • 8016 Answers
SOURCE: how do i do a matrix problem in my casio fx 115
Hello
Hope helps
Posted on Oct 12, 2009
  • 8016 Answers
SOURCE: when i press the MODE button in my CASIO fx - 911ES
Just in case : Press [SHIFT][CLR] (9) [3: ALL] to reset the calculator and try [MODE] again.
If that does not work, your calculator may be defective or a fake (not the genuine article). If at all possible, return it to where you bought it and get a refund.
Here is a picture of the FX-115ES, its face looks like the 991ES. Hope I am mistaken.
Posted on Oct 18, 2009
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
How do i put my casio fx -100ms in matrix mode and how do i solve
Create a square matrix at mots 3X3. Then you can multiply it by a scalar, or scare it, or calculate its determinant, and inverse. With two matrices that have the same dimensions you can perform .additions/subtractions or multiplications.
Nov 01, 2015 | Casio Office Equipment & Supplies
Casio fx 191es
Use the Matrix Computational mode.
Select a Matrix label A, B or C Press EXE
Select the dimension (mXn)
A template opens to allow you to enter the coefficients.
You need to read about what kind of operations you can perform on matrices (addition, multiplication, raising to a power, etc.)
Nov 29, 2013 | Office Equipment & Supplies
How to multiply the matrices using fx-991ms calculator
The following was written for the Casio FX-991 ES. If matrix calculations are available on your calculator you will perform them as described below. ( I have no time to verify that the FX-991ms can perform matrix calculations).
Let me explain how to create matrices. (If you know how to do it, skip to the operations on matricies, at the end.)
Dimensions of matrices involved in operations must match.
Here is a short summary
The multiplication of structured mathematical entities (vectors, complex numbers, matrices, etc.) is different from the multiplication of unstructured (scalar) mathematical entities (regular umbers). As you well know matrix multiplication is not commutative> This has to do with the dimensions.
An mXn matrix has m rows and n columns. To perform multiplication of an kXl matrice by an mXn matrix you multiply each element in one row of the first matrix by a specific element in a column of the second matrix. This imposes a condition, namely that the number of columns of the first matrix be equal to the number of rows of the second.
Thus, to be able to multiply a kXl matrix by am mXn matrix, the number of columns of the first (l) must be equal to the number of rows of the second (m).
So MatA(kXl) * MatB(mXn) is possible only if l=m
MatA(kX3) * Mat(3Xn) is possible and meaningful, but
Mat(kX3) * Mat(nX3) may not be possible.
To get back to your calculation, make sure that the number of columns of the first matrix is equal to the number of rows of the second. If this condition is not satisfied, the calculator returns a dimension error. The order of the matrices in the multiplication is, shall we say, vital.
Nov 06, 2012 | Casio FX991MS Scientific Calculator
Help - I have lost the instruction manual for my FX-991EX Plus, can I download a copy?
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Jun 30, 2011 | Casio FX991ES Scientific Calculator
How to do multiplication of two matrixes in casio fx 115es
This post is rather exhaustive as regards the matrix capabilities of the calculator. So if the post recalls things you already know, please skip them. Matrix multiplication is at the end.
Let me explain how to create matrices. (If you know how to do it, skip to the operations on matrices, at the end.)
To add matrices MatA+MatB (MUST have identical dimensions same m and same n, m and n do not have to be the same)
To subtract MatA-MatB. (MUST have identical dimensions, see above)
To multiply MatAxMatB (See below for conditions on dimensions)
To raise a matrix to a power 2 [x2], cube [x3]
To obtain inverse of a SQUARE MatA already defined MatA[x-1]. The key [x-1] is the x to the power -1 key. If the determinant of a matrix is zero, the matrix is singular and its inverse does not exit.
Dimensions of matrices involved in operations must match. Here is a short summary
The multiplication of structured mathematical entities (vectors, complex numbers, matrices, etc.) is different from the multiplication of unstructured (scalar) mathematical entities (regular numbers). As you well know matrix multiplication is not commutative> This has to do with the dimensions.
An mXn matrix has m rows and n columns. To perform multiplication of an kXl matrix by an mXn matrix you multiply each element in one row of the first matrix by a specific element in a column of the second matrix. This imposes a condition, namely that the number of columns of the first matrix be equal to the number of rows of the second.
Apr 24, 2011 | Casio FX-115ES Scientific Calculator
I put my MatA and MatB but when I multiply them it displays a dimension erreor
I know this is a long time ago, but i am sure someone might ask eventually this same question.For the Casio fx-115es here are the instructions:go to mode, matrix, and pick the matrix you want to you.. you only have 3 options.create your matrix and press AC.Here is the tricky part, DO NOT go to mode again, that will reset your matrices that you have entered. Instead, press shift and the number 4 key, which is also matrix, go to press 1 (DIM), chose the other matrix to enter, and you can start mult, adding, etc.Any time you want to use the entered matrices, go through the matrix function, not the mode function.
Dec 12, 2009 | Casio FX-115ES Scientific Calculator
Hello
Hope helps
Sep 10, 2009 | Casio FX-115ES Scientific Calculator
Sep 06, 2008 | Casio FX-115ES Scientific Calculator
306 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
