Question about The Computers & Internet
Where is the reset button and she will not turn on I tried changing the battery but still no can someone pls help me
I have been charging my nook for 3 days straight and it doesn't turn on I've held all the buttons trying to get the little battery thing to come up indicating that it's dead but nothing happens and I can't...
Remove the battery for half an hour. Then replace battery and try to charge. Should have to hard reset it and let sit for a few hours on charger. If screen does not change then try replacing the battery with a new one.
Nov 09, 2014 | Audio Players & Recorders
HP Ipaq 4700 won't switch on -
try to remove the battery for a while. or reset the unit.
Sep 17, 2008 | HP Computers & Internet
IRiver X20 MP3 player won't even turn on. dead as a doornail.
try changing the batteries if it does not turn on when attach it to charger or computer your batteries are dead...buy replacement
Aug 23, 2008 | iRiver X20 MP3 Player
My samsung galaxy s4 is not charging it says "charging paused battery temperature too high " ive tried putting a new battery still no change tried to reset it also but no luck pls help
Power down the phone. Take the battery out for 20+ seconds. Plug in the charger. Put the battery back in. Turn the phone back on.
Sep 02, 2013 | Cell Phones
Nokia e51 wont turns on only notification light always turns on when we attach battery in mobile pls help me retrieve out data over there in mobile
Hey veevec try to remove the carbon from battery and the copper which is present in the mobile where battery is touched
If there is no carbon
-> Is the battery fine (like no fatness , leakage or too much old or uncharged) * then change the battery
-> Is the mobile show a light on the screen * then try to format is by using
* + 3 + call + on/off button
And please reply me if my solution helped you please ....
Sep 14, 2009 | Nokia E51 Smartphone
Change language settings htc diamond
my phone is in danish languages how can i changes it to english?pls help me plsssssssss
Mar 25, 2009 | HTC Touch Diamond Smartphone
I'm locked out of my phone, I forgot my password and there is no way for me to get my numbers or anything out. What should I do?
u can try factory reset the device like this but all data will be wiped off pls active sync ur device and backup ur data then try this
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see a message on the screen for the confirmation
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
if it doesnt help then u can upgrade ur ROM from www.HTC.com and it will also solve ur problem
pls rate me FIXYA
Mar 08, 2009 | HTC Touch Diamond Smartphone
How to reprogram 1999 mercedes s320 key remote?
just insert the key to the ignition swich and leave it for one minute, it will work for sure.
Adel
Jan 15, 2009 | 1999 Mercedes-Benz S-Class
My radio turns off automatically as soon as I hit the talk button.
Appreciate the direct "Ask Me".
Initially, I would assume that you have a pair and that the problem is with just one.
Based on this, I would suggest switching the NimH batteries. This is to eliminate the possibility that is is a battery/charging issue. Additionally, pls try to verify that the battery contacts both on the radio and the batteries themselves are clean. You may need to scrape them off to assure positive contact. Further on the radio's battery terminals, you may need to slightly bend them (or stretch if spring type) to provide more pressure in the contacts.
Incidentally, removing the battery for an extended period of time is enough to perform a reset.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 26, 2008 | Uniden GMR638-2CK (22 Channels) 2-Way...
Pls help me for power on fail
If your Treo loops or freezes during a soft reset, a system reset may help. Performing a system reset allows you to get out of an endless loop in order to uninstall a third-party application causing the looping: 1. Press the Battery Door Release button and slide the battery door downward to remove it from your Treo. 2. While pressing and holding Up , use the tip of the stylus to gently press the reset button on the back of your Treo. 3. When the Palm Powered logo appears, release Up . 4. Delete the third-party application that you suspect is causing the problem. 5. Perform a soft reset. The wireless features of your phone are not available until you complete this step. Good luck!
Nov 23, 2005 | Palm Treo 650 Handheld
Computers & Internet Logo
Top The Computers & Internet Experts
d3yavu3
kimblebear
Level 1 Expert
baklogic
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
