Question about Refrigerators
Have a side by side refrigerator model GS5SHAXNT00. I heard a small pop and the bulb went out. When I replaced the bulb it did not work and the temperature control display went dark. both bulbs work
  • 213 Answers
SOURCE: magic chef #rb19k-4a refrigerator: bulb replacement
unplug refrigerator look inside light socket youll see a tab in the bottom of the socket bend tab up alittle bit then screw light bulb back in. if this doesnt help then the door switch is bad
Posted on Nov 21, 2007
  • 3130 Answers
What you need is the owners manual my friend. In here it will show you where to get to the lamp and how to change the lamp. Go to
to get a free copy of the OWNERS manual. Page 16 tells you how to do this. Good Luck
Posted on Jan 14, 2008
SOURCE: Sub-zero 550 series
I had this problem in the fridge portion last year and replaced the switch at the top of the door. Problem solved. There should be two switches: one for the lights and one to turn off the compressor when the door is open. I don't remember which one was which. Try the link below for the part, but double check to make sure it's the right one. They have an 800 number to call as well. Good luck
Posted on Jul 22, 2008
SOURCE: whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Posted on Jul 30, 2008
  • 3361 Answers
SOURCE: Can't find replacement light bulb:refrigerator model ET18DKXWW00.
Your problem may be in the bulb receptacle or the light switch.
If you have a voltmeter, let me know and I will tell you how to check it.
Posted on Mar 04, 2009
I have a Mitsubishi TV model WD-65C9 and yesterday I heard a pop sound and the screen went black but there is still sound. Is this just a lamp bulb issue?
That pop noise was a so called "CAP" capacitor letting (they actually blow up) go on a circuit board, open the TV cabinet up and look carefully for a burned spot on the circuit boards, it will be small, when you locate that board it may fix the TV is you replace the damaged board.
Mar 23, 2017 | Mitsubishi Televison & Video
Replaced bulbs in my Viking DFS423B and still not coming on.
That was a DEAD Electrical short. If your talking about all the bulbs, it's probably at a fuse box. Start by checking all the fuses (under the hood too) Ck all the fuses anyway and that's the circuit where the trouble started if you find a bad fuse. More than one or two fuses your best bet is pro help unless you have wiring diagrams, test light & multimeter. Also look for burn marks on the wiring where you heard the POP.
Sep 24, 2015 | Cars & Trucks
Refrig light is out when i open the door it mkes a clicking sound and bulb flickers. if i hold the door switch in it stops changed bulbs still same result.when the bulbs are put in the temp control...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Aug 24, 2010 | Whirlpool Refrigerators
Need part no of board for refrigertor gs5shaxnt00, lights in refrig section are out. replaced light and door switch
Here is my part # AP3182782 . You can also enter your model 3 for diagrams and illustrations for your model. All parts come with installation instructions.
Mar 31, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Light and temperature indicator on refregirator do no operate. Wife heard a pop when she opened refrig. door.
If the refrig light AND the temp adjustment knob lights , went out , you need to replace the electronic board . Pt # W10135090 . This part is located behind the refrig , at the bottom left , with 2 screws , inside a white box . The board runs about $ 80.00 , and is easily replaceable .
Nov 22, 2009 | Whirlpool GS6SHEXNS Side by Side...
I had this problem with my GE ice maker not working and it was an unbelievably easy fix. If you have the same ice maker then you will see a green light by the power switch. Below the ice maker is a "paddle" ice sensor. The paddle is attached to the ice maker and there is a coil type tension spring. If your paddle is loose, make sure the end of the spring (the pointy wire end) is inserted into a small hole. You probably can't see the hole but move the wire end until it pops into the small hole. You should now have tension on the paddle. At this point I had heard that the freezer light bulb may be drawing too much current for the ice makers motherboard. I removed the bulb and, UNBELIEVABLY, the ice maker began making ice! Try removing or replacing the LIGHT BULB first!
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice/water dispenser "shorted" out
You will have to get dispenser control outvto see what wires and switches may be burnt.
Nov 03, 2017 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
Read replace lamp then afew weeks later heard pop noise and now black screen
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Oct 17, 2008 | Panasonic PT-60LCX64 Television
Tv black, no sound
is there any led or small lights on front panel ... red green or flashing
Aug 08, 2008 | Toshiba 46H84 46" Rear Projection...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
