Canon pixma mp730 alarm light suddenly went on, and LCD says "check printer press resume button." I've already tried: 1) Owner's manual says "turn off printer, unplug, wait 15 seconds, then restart....if problem persists call our Customer Care Center" (useless!) 2) pressing resume 3) pressing cancel. 4) opening the printer top; notably, the print head carriage doesn't move into view, as is normal (a clue?) help!
  • Tom Robert Jul 25, 2009
    Following your instructions, I reached in to try pulling the the print head/cartridge carriage toward the center. It's very hard on this model to get much of a grip on it, but in any event it doesn't budge -- it doesn't "fight" me (I know what that feels like -- where you can move it a bit but it immediately pulls back). It just won't budge.
    I really want to keep this printer because it's worked so well for years -- and the new ones require Canon brand cartridges that cost 10 x as much.
    But I know that "bringing it in" (where?) probably means throwing it away bc the cost of repair is usually > cost of replacement.
    Any other suggestions for diagnosis and home treatment?
    Thanks
    Tom
  • Tom Robert Jul 26, 2009
    I can't see why the driver would have anything to do with it. The problem has nothing to do with the connection with the computer. Even if I disconnect the computer and use it simply as a copier, it exhibits the same symptoms?
    Is there no other way to diagnose the problem other than to "try to move the print cartridge", shake the machine or look for loose wires?
    I was hoping for something a little more sophisticated....
    "take it to a shop" would be a complete waste of time, because the cost of repair is virtually certain to exceed the cost of replacement.
    The reason I want to try to save this old printer is a) it was working fine until it suddenly stopped, and b) the newer Canon printers only work with Canon ink, which costs roughly 10 times what I have paid, for years, for refilled cartridges.
  • 1,555 Answers
At this point I'd like to sugget you to take a vaccum cleaner. Put it on medium blower and blow your printer with it from backside so whatever paper bits and dust is inside comes out from the front then blow it from the front also. But before that don't forget to remove the power cord and data cable. While moving the cartridge carrier if you would have removed the power cord you won't have faced that much problem. Now do the same this time also move the cartridge carrier left and right and clean the iron road with a cloth. Take out your printers CD and take your printer to a different PC install your driver on that PC and connect your printer over there and try to take a print out. In future never do anything inside your printer with hands till you have removed power cable.
Posted on Jul 26, 2009
  • 3,037 Answers
Since the print cartridge isn't moving then try the following with the top open. With the power on, gently push against the carriage in either direction. If it doesn't fight with you, the belt may be either off a pulley or torn. If it does fight, then either you have a stuck gear, a bad motor, or even a bad signal from the board issue, hopefully a little wiggling will free this up and get it working again so give it a good run for your money. Look for any broken or torn wires and parts at this time if it still isn't working. If you still don't find anything wrong and it isn't working, then it may be time to take it to a shop or replace it. Let me know how this turns out.
Benjamin
Posted on Jul 25, 2009
  • Benjamin Patri
    Benjamin Patri Jul 25, 2009
    Since you are running out of options, in case it is a software problem, you could try uninstalling the driver, and then reinstalling it. I would also try downloading any updates off of the canon website. After all of that, in case something is loose, just give the printer a good shake side to side. Then you could look up a local printer repair shop and see what they will say about looking at it. Let me know how this turns out. I'm sorry if it ends up that you have to get a new one.
My Canon MX310 alarm light is on - ink reservoir is almost full. I cleaned the reservoir and have tried the above procedure to clear the alarm but it hasn't worked. How do I clear the alarm?
Dear
You can reset the waste ink tank counter yourself. Be aware that this doesn't actually empty the waste ink tank itself but it does allow you to continue printing.
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
Thanks.
Feb 22, 2015 | Canon Pixma MX310 All in One
My Canon Pixma IP400 is not working and the orange light is flashing 5 times
How to reset waste ink / blinking printer canon ip4200
With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
While holding the Power button, release theresume/Cancel button. (DO NOT release the Power
button.)
While holding the Power button, press the Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
When the Power LED lights in green, press the Resume/Cancel button the specified number of
time(s) setting).
After pressing the Resume/Cancel button the required number of times -you must press the On/Off button to perform the task. For Example Pressing Resume/Cancel 1 time, then press On/Off - does a Service Test Print
Time(s) LED indication Function Remarks 0 times Green (Power) Power off When the print head is not installed, the carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings After entering the destination settings mode, press the Resume/Cancel button the specified number of time(s) to select the destination. For detail, see "Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used in servicing.
15 times Orange (Alarm) Return to the menu selection.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 23, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My canon pixma ip4200 flashes orane 5 times
While holding the Power button, release the resume/Cancel button. (DO NOT release the Power
button.)
time(s) setting).
Thanks, Joe
Dec 23, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
ALARM light is on, and not able to print I already
Try this reset on the printer
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click "Power" button. green led should be on
  3. hold the Power button, release Resume Button.
  4. Without releasing the Power Button, double click "Resume" button and then release Both Buttons.
  5. Click "Resume" for four times then click "Power" button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 01, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
4 times----Green (Power)------Waste ink counter resetting
Apr 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Cannon MP830 Printer purchased in July, 2007. Was working fine until yesterday. suddenly when printing from PC get "Service Error 5C10 and printer alarm light begins blinking". When trying copy -...
It is one of two things.
a bad ink cartridge (the chip located on the gold part of it)
or
bad USB cable.
IF you have a spare cable simply change them out.
If you are refilling your cartridges, it is time to replace them.
Oct 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon ip 4200
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
4) When the Power LED lights in green, press the Resume/Cancel button 4 times, the green (power) led should be lit to reset ink absorbers.
5)At the end of the service mode, press the Power button
Jan 10, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Waste absorber is full in canon iP4200?
Follow this instruction:
4) When the Power LED lights in green, press the Resume/Cancel button 4 of times.
5) Then press the Power button, then press it one more for turning off printer.Restart the printer and it will printing again.
Check printer & alarm flashing.I cannot get it to reset.
Electric connection terminals scratched? Maybe short circuit. Use warranty from purchase for repair.
Sep 29, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Alarm light flashing, please wait message
Can only try
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 10, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
