What battery does a sky emperor scud use an how long does it need charge 4
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
Scud on inside drum goes into washing tried
Try a stronger acid like The Works Toilet Bowl Cleaner in a strong solution so it gets totally clean -- let the solution sit in there for awhile then let it finish cycle. It sounds like you have very hard water -- the best way to avoid getting the crud in there is to have a softening system or use filters. You can try using the vinegar wash after each washing session so it doesn't build up.
Dec 04, 2010 | LG Washing Machines
My Garmin 45 has not been used for several years. I replaced the batteries but it will not find satellites and I cannot mark a position. It remembers waypoints etc but does not show current position. Any...
The almanac will need to be rebuilt or whatever it does. This can take ages even with a good sky view. Leave it with a wide sky view on a roof with external power ideally for at least 30 minutes.
The special memory battery inside may also be dead and not charge up again - it relies on minute trickle charge from the AA batteries. The memory battery can be replaced - it's a vandium pentoxide by Panasonic, type VL1220.
Aug 27, 2009 | Garmin GPS
Canon IXUS 960IS
This happens when the battery try recharging them...
Oct 04, 2008 | Canon IXUS 960 IS Digital Camera
Need a mic wiring diagram for a emperor ts-5010 rk 56 mic
EMPEROR
TS-5010
Stock Mic Standard Hookup
1 - Audio
2 - Shield
3 - Transmit
4 - Chnl UP
5 - Chnl DOWN
For Turner RK56 mic
1 - White
2 - Shield & Red
3 - Blue
4 - N/C
5 - N/C
Black - N/C
Yellow - N/C
Hope this gets you talking on your new mic. Reply back or email me rollincbmods@yahoo.com if you need more assistance
Dean Pitts
Rollin CBs
Mt. Vernon, TX
Jun 03, 2008 | Radio Communications
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
