I have a hitachi 50 inch plasma with stand by power red on when i hit the reset button at the bottom of the set the blue power light comes on.but no picture.
Model number P50h401. serial no V7J047094 OCTOBER/2007 282 W chassis no DW3A
  • 8457 Answers
SOURCE: I have the same problem blue power light blinks 3 times
Ur power board inverter is dead.
U need a new board.
Posted on Aug 20, 2009
SOURCE: Problem with Hitachi P50H401 Plasma TV - Will not
I have the same model, P50H401 and it developed the same problem two days ago. This set is 2 1/2 years old in service, being purchased in December 2007. The original manufacture date was October 2007.
The set was turned on and operating at the time and then promptly shut down by itself. The front blue LED power indicator began flashing four times in a loop or cycle.
The flashing LED sequence in this instance points to a problem with one of the following boards: PSU, X-Sus, Y-Sus or SDRs (there are two SDR boards, SDR-U and SDR-D, both are connected off of the Y-Sus board on the left hand side of the frame when rear facing). The set shuts down to prevent further damage to other boards or components.
I could power cycle the set but it would shut down after after a few seconds. Power LED would stay solid, I could hear the PS relays switching, and audio would output through the speakers. Then as the screen was just about to illuminate, the entire set would just shutdown. The blue LED would again go into the 4X flashing sequence.
I could not visually detect any signs of severe component damage on the main PS board. The two large electrolytic capacitors which have been mentioned as problematic in other threads seems fine. The where slightly raised on the top surface, but not blistered or completely blown open.
The only indication of component damage that I could detect visually was on one of the small surface mounted ICs on the SDR-U board.
Through reading other posts on this site, I learned that I was able to remove the suspect SDR-U board and then re-power the set. Doing this proved that the PS, X and Y Sus, and the SDR-D boards where o.k. The PS held, and the lower half of the screen illuminated. (I would only do this for as brief a period as required to determine if the the other boards would function and the screen would illuminate. Do not pro-long operation in this state so as to not cause further damage.)
It was somewhat difficult to locate the correct SDR-U board. My local service rep did not have one in stock, and the Canadian parts distributor was also out of stock. They estimated 10 - 14 business days to order one up from the U.S.A. (Hitachi closed their consumer electronics division in Canada back in 2009.)
By chance, I checked with another service rep in an adjacent town. He had a board for the P55. We did a visual comparison on the two boards and determined that it would be compatable.
The easy part was removing the defective SDR-U board and installing the replacement. The hard part was re-alinging the three ribbon tabs into the respective connectors on the SDR board. Be careful with these ribbons. The other end of each is fused to the plasma panel screen, so if you damage them, your screen is rendered useless.
I initially had the same problems as others have posted with having black or gray lines on the screen when the SDR-U was replaced. After gently adjusting the position of the ribbons as they are seated in the connectors, the lines disappeared. This was a slow and frustrating procedure, but it worked, Be patient.
Posted on Jul 03, 2010
  • 33 Answers
SOURCE: I have a Hitachi P50H401 plasma TV ,when you hit
unplug the unit for a while like one hour or so.
Posted on Sep 03, 2010
  • 33 Answers
SOURCE: My Hitachi P50H401 50 inch Plama TV stopped
very common issue. if your hand you can repair it yourself.
for more info on this set please check out http://www.hometheatershack.com/forums/hitachi/38229-hitachi-p50h401-led-flashes-3-times.html
if will tell you how to trouble shoot this tv. these tv's are known for two caps in the power supply to go bad and they need replaced then you have to test the sdr boards if they are bad you need replacement boards or you can send them off to be repaired. the link for the repair guy is on the page. this guy also sells the repair on ebay but if you contact him directly i beleave the price is lower. just tell him you were send over by home theater shack.
Posted on Feb 22, 2011
thanhlengoch
SOURCE: hitachi tv please help
i have hitachi p50h401 blue light on no picture and sound
Posted on Sep 13, 2014
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
My 50 inch Hitachi plasma 1080 tv has a blinking blue light and screen is blank when powered on.
my hatachi hd/1080 tv has a solid blue light on and it wont turn on i push the reset button on the bottom right and it still wont turn on
Mar 27, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi Plasma 50 inch H4011 series just went off and red light blinked 4 times. Won't come back on even after unplugging and waiting 30 seconds and plugging back in per Troubleshooting guide in owner's...
Power supply board is dead.Replaced the power supply board,Ur tv will get the power back.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for replacement.
Feb 21, 2010 | Hitachi P50H401 50 in. Plasma HDTV
U need a new board.
Jul 17, 2009 | Hitachi P50H401 50 in. Plasma HDTV
Power makes a sound but does not power up
SAME PROBLEM AS YOU ROBERT! Same TV and same problem after pluggin in something else in another outlet. Did you ever solve this issue?
Please e-mail me at yanalou at aol dot com.
Big Screen Blues II
LOU
Dec 02, 2008 | Hitachi 46F510 46" Projection HDTV
Hitachi tv please help
I write the same in other consult
Jul 09, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Haier 50 inch plasma not turning on properly
try changing to other inputs and move the connection along with it
Apr 08, 2008 | Televison & Video
Hitachi HD 1080 has blue power light on but no picture
Press the reset button...it's on the bottom to the right (underneath the TV). Same thing happened to me.
Feb 07, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Dec 24, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
