Question about Boating
Minnkota edrive the power go off and it show in the console neutral and prop sign
2 Suggested Answers
philwalker78
  • 608 Answers
SOURCE: I have a minnkota riptide 55 sc. I have fishing
The prop slides off with a shear pin behind it. Regards Phil
Posted on Apr 11, 2011
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    My prop turns when in neutral. Is there an adjustment for this
    put your hand against it and if there seems like power it might need a linkage adjustment if not then leave it along .
    Dec 18, 2014 | Boating
    Minnkota endura c-50 shear pin size
    You can get the appropriate pins in the prop not kits sold by minn Kota or thru major retailers.
    Trolling Motor Replacement Props Minn Kota Motors
    You will find prop nut kits here just follow the link.
    Sep 28, 2014 | Minn Kota MinnKota MK110P Marine Portable...
    I want to mount my endurac2 on the back of my boat but the handle an the prop are in the same direction is it possible to turn one or the other
    Not entirely sure with your model but it is possible to take the head off (where the handle is) and spin that 180 degrees. You may also check an aftermarket prop that has opposite blade direction. So where normally it's on the front of the boat, pulling through water it's now pushing the water when moving to back of boat. Shouldn't be hard to locate
    Apr 04, 2013 | Minn Kota MinnKota ENDURA C2 30 30"...
    Minnkota trolling motor prop removal
    remove the nut and the prop will come right off. Just be careful not to loose the shear pin.
    Apr 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Need a prop for a minn kota 35 17lb thurst.
    www.youngprops.com/minnkota.htm
    Apr 06, 2009 | Boating
    Replacement of motorguide trolling motor prop
    Motor Guide hubs come in two different sizes - 3" and 3.5". The 3" size is more for older and lower thrust models. Newer units use the 3.5. The size differences are between manufacturers too. MinnKota's are a little bigger. If you order a new prop, the only issue may be the depth of the prop. I had to use a longer prop nut wrench to tighten the Hydrilla Hacker I purchased.
    Triton72
    Mar 26, 2009 | Boating
    Boating Logo
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
