Question about LG Televison & Video
I Have LG TV Model 32LE4500 , it start normally till 3 to 5 min from cold start then it start flickering till it go completely dark.
When i start it from Cold, it start Normally for around 3 to 5 min then the back white LED lights start flickering till it go completely off(i can see that from some of the hols at the back of the metal chassis in the back of TV)and while those lights flickering at Back the screen from front dimming, it keep doing that till it go completely black, but when i use external torch in dark room i can see that there is something in the screen where i point the torch to a certain point, any idea ? , i already changed a set (Most) of Capacitors from the Power Board even they look good, but still the same problem !!! Thank you in Advance for help.
  • 45 Answers
SOURCE: zenith console tv model sentry 2 27 inch
Resolder the vertical deflection section. Change pump up capacitor if it has one...100uf is a typical value. Is the vertical output some flavor of LA783x ?? May need to replace. A model # would help.
Posted on Nov 04, 2007
SOURCE: RCA D52W20 cold start issue?
i am looking for an owners manual for the d52w20, can anyone help me out here.
Posted on Jan 18, 2008
  • 156 Answers
SOURCE: Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Posted on Feb 27, 2008
  • 4234 Answers
SOURCE: screen black - power to tv is good.
Since the set is only 8months old, it should still be under warranty. Please contact the manufacturer for directions on how and where to get this serviced. This should be fixed at no cost to you.
Posted on Jul 10, 2009
  • 566 Answers
SOURCE: Working on a friend's LG
Hi syzonker
Before you replace the power supply , check for swollen(rounded top)capacitors.
Also check and replace C126 47mfds/50 volts
And C520 1000mfds/16 volts
good luck and let me know if you need further help
Posted on Feb 16, 2010
Testimonial: "Was getting somewhere with barbu51 when suddenly couldn't reply to him anymore. FixYa said one of his solutions was rated low - BUT NOT BY ME!"
37lg5000 tv picture starts to flicker and goes dark.
that is cause by a loose connectors or a cold solder joints of parts the repair of this kind requires opening the cover .re solder all connectors terminal and re insrt all socket connectors ..
Sep 30, 2011 | LG 37LG5000 37 in. HDTV-Ready LCD TV
Flickering screen
Two models of the 46 inch Sony Bravia have a screen flicker problem. On my 2008 model, starting from cold, it lasts for 5-10 min, on LHS of screen. The Telefix tech who visited said this is common with these models (46in only), a new panel is needed. Sony provides warranty on this fault for 3 yrs, so you do not need extended warranty to claim. Discuss your case with Sony or Telefix.
Jan 03, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sparkling on LG flatpanel tv
ok, phoned a technician today and he has diagnosed the y/suss board as gone and 150 to fix but cant guarantee it will fix it for good, another board may go pop z/suss . so its the local refuse collection point for it.
Jan 02, 2010 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Taking 5 min to warm up
if the monitors tub is old or cold its take sevaral minutes to warm up
Oct 02, 2009 | LG Studioworks 700S 17" CRT Monitor
The screen on my dell inspiron nootbook started flickering last month, two weeks ago it started to turn completely dark at times and today 3 min after i turned it on a blue screen popped up and it told me...
windows dose not control any flickering unless the driver is being updated if thats not the case your flourecent bulb might be getting old inside the lcd!
Aug 29, 2009 | Dell Inspiron 1525 Laptop
My tv picture is dark and flickers
is there any spar, u observed inside the tv when it do like this.
Jul 05, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Looking for manual of a chefmate bread machine
I have a manual for CM 725 if someone still needs it.
Sep 20, 2007 | Kitchen Appliances - Others
Flickers on cold startup after 5 min then goes away in 2-3 min.
I had same problem. Tech's said the power was noisy. I cleaned up the power but the TV still did exactly as you describe. Problem will progressively get worse with longer bouts of flickering. I was under warrenty and sent the TV back. After 3 months I am still waiting for a repalcement.
Jan 12, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Televison & Video Logo
Computer Repairing
Computer Repairing
