Question about Garden
Putting my yard king 8/27 snowblower away for the summer. Should I remove the gas and oil. If yes, how?
  • 1,830 Answers
I do not live up north or where there is so much snow, but I think you should drain the gas and oil from your machine.
Do you still have your owner's manual? Check it for directions.
Posted on May 13, 2017
I have a Ariens snowblower deluxe 30 which is a year old. Starts fine and will run. Unfortunatley it is running way to low. I have replace the gas with fresh gas ran it through completely
It is very possible the carbureator needs a cleaning. Moisture can corrode the inner parts of them if left all summer. I find that the fuel usually does not go bad over the summer. I always start my snowblower once a month over the summer and then have no problems when the snow flies again. There was a time when mine was losing power and quitting also. There is a screw on the bottom of my carbureator that needed adjusting. If you are lucky that may be all you need. By turning mine in and out a bit I found the spot where the gas was correct and it worked fine again.
Jan 08, 2017 | Ariens Garden
I didn't realize that my Ariens 522 2 cycle snowblower is a oil/gas mix. I filled my tank full with just gas and no oil. Can i just add in oil and manually mix it?
Yes, you can. I thought it was a chain saw, but you can shake a snowblower :>) Put the oil in stir vigorously with a spoon.
I changed the category.
Dec 12, 2016 | Garden
Ran perfect last yr , gas was stale drained carb bowl and replaced gas it started up right away then cuople mins later it started blowing oil out of the oil over flow tube
Sounds like the Needle valve in the carburetor is stuck 'down' letting gas continually run from gas tank into carb. When the valve can't go up (Close) gas will run past the carburetor and into the crank case I bet your oil is full of gas. Check oil level see if it is overfull
Jan 22, 2014 | Tecumseh Snowblower Snow Blower Starter...
Craftsman snowblower will not kick over
Old gas? Did you pull out the spark plug and see if you have a spark? If the gas is old, drain the tank and line to the carburator, then put in fresh gas. Never put it up for the summer with gas in it. Run it until the engines runs out of fuel, then put it away.
If there's no spark, then you have a coil issue.
Nov 21, 2013 | Craftsman Snow Blower / Snowblower Bottom...
What do I do before storing my Craftsman snowblower for the summer?
i run mine out of gas do to the fact the fuel we now have only lasts 30days while running mine out i add some 2 cycle fuel then run that out when it cools down place dryer sheets around the engine this will keep the mice away from the wires
Apr 13, 2012 | Garden
I have a mtd 26" 8hp snowblower that need aufer
if the bolt broke off then you need to get old part of it out before putting in a new bolt.
Dec 12, 2010 | Mtd Products Yard Machines 158CC Tiller
208 Road King would not start after changing oil filter.... Does it need oil pressure established in order to allow it to spark or start?
yes if it does not have oil pressure it won't start it is a safety device but should prime right away. try removing the filter and see if the gasket surface is dirty, if it is clean it if the gasket is bad buy a new filter. Fill the filter before installing then try it again.
Mar 23, 2010 | 2008 Harley Davidson FLHR Road king
Oil leak and stall
I have not solved the problem yet, however, at this point I am thinking it may just be a crankcase vent problem. Builds to much pressure and stalls and that is also the cause of the leak??? I used the blower again today and when I took out the dip stick there seemed to be a pressure.
I had listed my problem as a lawn mower cause the snowblower wasn't in your list of options to pick from??
Mar 25, 2009 | Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
