Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
Fridgidare leaks inside
We find water in the bottom all the time and it takes about 4 to 7 days to build up and start overflowing to the outside.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Most likely your defrost drain is clogged and it is overflowing. look on back of box. there may be a removable p- trap.
Posted on Jul 26, 2009
Water is puddeling under the left side and front of the fridge. its dry and dusty underneath. water line for ice maker has been disconnected for years. cant figure where the water is coming from
You have a side by side or a undermounted freezer? I am having the same problem with mine. Take a look into the bottom of the freezer, there is probably ice building up on the bottom of it under the bottom self or basket. It seems if the refrigerator door is opened frequently and it is moderately or very humid in your home the water vapour condences inside the freezer. There is probably a condensation tray somewhere that is overflowing into the freezer compartment. Once the ice build up on the bottom gets to a certain point the water then starts to run out the front of the fridge onto the floor. Remove the ice from the bottom of the fridge and empty the condensation tray. You may have to continually do this during humid periods. For me that is about 6 months of the year every 3 to 4 days. It's a pain but what are you going to do.
Oct 15, 2015 | Refrigerators
It looks that water is leaking from the - Culligan water softner
Look down the tube (where the float assembly is) there should only be about 10-12" of water in there. For water to reach the brine tank over flow the tank would have to be 3/4 of water. Brine tanks can develop leaks over time if they were set on uneven ground or if any rocks or debris are under it. If there is no evidence of water running down the side of the brine tank this is the most likely cause. Also if it has been leaking for some time there will salt buildup around the brine tank. Check the water softener for any leaks also. At times a small leak from the softener will find it's way over to the brine tank and collect around the bottom of it.
RJ
Jun 14, 2010 | Culligan Sediment Water Filter
I have a unit in the attic that is installed in the attic horizontally. The condensation leaks out the unit into the overflow pan. I have had the drip pan replaced as it was cracked, the overflow line...
It sounds like to me that the leak is coming from inside the unit(air handler) possibly your evaporator coil is icing up and causing a build up of water just below where the 3/4" P.V.C. drain line connects. Instead of draining out the line, it is finding its way out of the unit else where. I have seen this many times. It sounds like you have done everything that I would have done, but take a look at the bottom of the evaporator pan and I bet that it also is starting to rust out.If the new overflow pan is not leaking, and the condensate line is leak free, it has to be leaking from the evap pan inside the unit.That's why you have the overflow pan in the 1st place to prevent ceiling damage as I am sure you know. I hope I have been of some help to you, please let me know what you find.
Sincerely, Shastalaker7
Nov 01, 2009 | Heating & Cooling
Ice builds up inside the freezer every few days at bottom
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Sep 30, 2009 | Maytag MZD2768G Side by Side Refrigerator
It is leaking water and the bottom of the refrigerator has water
Is water leaking OUTSIDE your refrigerator or INSIDE at the bottom of your refrigerator ? If it is inside your refrigerator the most common reason is a clogged defrost drain tube - The water collects from a defrost cycle and drains through a hole on the ceiling of your refrigerator into a cup that drains it through the tube down to the defrost pan at the bottom of your refrigerator on the back and evaporated by the compressor heat. Sometimes this tube gets clogged and water does not drain from the cup and overflows inside your refrigerator against the backwall.
Aug 16, 2009 | Kenmore Refrigerators
Water leaking from overflow tube
pour warm water and baking soda down drain and look for cracks in tube.
May 12, 2009 | GE Refrigerators
Water leaking from outside bottom
the waterline going in the freezer door may have a hole take the kickplate off while looking underneath use the water in door to see if any water is leaking from that tube
Apr 27, 2009 | GE Profile TPX24PBDCC Side by Side...
Siemens Lady 45 Dishwasher - Starup and Water problem
try unblocking the inlet hose under the machine.. My machine was overflowing inlet water into the tray under the machine setting off the above mentioned aquastopper switch. I removed side pannel, then one end of the inlet hose under the machine and dragged a wire with cloth tied to end through, removing a serious amount of built up scum. no more overflowing!!
Mar 13, 2009 | Dishwashers
There is a water leak inside the freezer
You need to remove the bottom two baskets, or more to make space. Using a hairdryer, defrost the back area. You should be able to locate a drain hole in the center below the freezer coils. This drain hole is connected on the outside to a drainpipe which has a p trap and often gets blocked up. You need to force water down the drain hole. You can use a turkey baster or similar type of plunger filled with water. Once you have cleared the blockage pour hot water till it runs freely. Hope this sorts your problem, don't forget to rate me.
Mar 11, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
184 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
