Question about Retail Supplies
XE-A207. Won't print while ringing up. But will when transaction over if you push receipt copy. It will print x/z readings
  • Retail Supplies Master
  • 1,660 Answers
The receipt is turned off.
Turn key to OP/XZ mode. Press receipt button. Turn key back to REG mode.
Posted on May 14, 2017
My shape XE-A207 cash register won't roll out the receipt paper when a sale is made. It is trying to print a receipt but the paper isn't rolling out.
Usually a broken feed gear in the printer. If you can hear the feed motor whirring but no paper movement, it probably needs a new printer.
Sep 07, 2015 | Retail Supplies
Is it possible to require clerk numbers before making a transaction ?
It is possible as long as you log-out after concluding every transaction
Feb 05, 2014 | Sharp XE-A207 Electronic Cash Register
How do I print a journal receipt only?
1 turn your key to the position between REG and Off
2 Press rcpt button once
3 turn back to REG
Jul 16, 2013 | Sharp XE-A404 PC Desktop
We just got a new xe-a102, we do not need to print receipts...how do you turn off that function?
To disable receipt printing:
  • Press the Rcpt/PO key in the OP X/Z position. This key toggles the receipt printing status ON andOFF.
  • To check the receipt printing status, turn the mode switch to the OP X/Z position or press the CL key in the REG mode.
  • When the function is in the OFF mode, the receipt off indicator “_” illuminates.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF
mode, press the RCPT/PO key. This will produce a receipt. If more than 50 items were entered, the receipt will be
issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF
function is in the “ON” status.
Oct 27, 2009 | Sharp XE-A404 PC Desktop
How do i get it to stop printing customer receipts
The following is the process to stop customer receipt printing. It will also describe how to print an individual receipt on demand. Best of luck and thank you for using Fixya! Kindly return to rate this solution.
Greg
Receipt ON/OFF function
You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable
receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and
OFF.
To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG
mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
"To issue a receipt when receipt ON/OFF function is set to OFF:
mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be
function is in the “ON” status."
Sep 24, 2009 | Sharp XE-A404 PC Desktop
Change on/off receipt function to off
The following is the method to turn the receipt printing on/off:
OFF.
All the best!
Greg
Aug 01, 2009 | Sharp XE-A404 PC Desktop
CAN'T PRINT A "REPRINT.......ANY RECEIPT"
You're welcome. Please come back and give this answer a rating of fixya. Good day :c)
Feb 16, 2009 | VeriFone OMNI 3200 (P092-101-10) Printer
Receipt not printing
I believe this might help, not exactly familiar with this exact model but here it goes.
When you use the printer to issue receipts, you can disable receipt printing in the REG mode to save paper
using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This
key toggles the receipt printing status ON and OFF.
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function being OFF
status, press the Rkey. This will produce a receipt. However, if more than 30 items were entered, the
receipt will be issued in a summary receipt.
Copy receipt
You can print a copy receipt by pressing the Rkey when the receipt ON/OFF function is in the “ON” status.
To realize this function, you must enable the function. Please refer to page 62 (Job code 63).
Nov 11, 2008 | Sharp XE-A404 PC Desktop
Retail Supplies Logo
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
