Question about Electrolux Refrigerators
I've lost power to front panel controls on Electrolux Icon Refrigerator. Everything functions fine.
tech master
  • 120 Answers
SOURCE: Sears Kenmore Elite Refrigerator model
need model number even though it says kenmore we need to know the model will tell us the maufacturer but start by checking voltage at the outlet to see if you have proper ground
Posted on Oct 17, 2008
  • 10865 Answers
SOURCE: No electrical power to ovens and control panel.
It appears that you have lost one half of your power. That is you no longer have 220 volts but do have 110, enouch to power the electronic ignition. I would check the circuit breaker first to see if it is sending power on both hot wires or just one.
Posted on Jul 17, 2009
SOURCE: power went out briefly. Refrigerator control
Press the Power Freeze and the Power Cool button at the same time. Hold for 10 seconds and the digital panel reset.
Posted on Aug 15, 2009
SOURCE: I have an electrolux edw5505eps dishwasher. The
check out my thread on a similar issue. If your power button doesn't light and delay button does not light? Is the LCD screen display anything? check out my post several really good check lists.
Posted on Nov 26, 2009
  • 452 Answers
SOURCE: Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Posted on Dec 30, 2009
My control panel is reading SY CE. A repairman is coming tomorrow. How long can we keep the food in the refrigerator/freezer before it goes bad?
If you have a freezer put any thing you can freeze in it but if you feel the food is getting warm don't keep it very long.Do you have a neighbor or a person you can bag up some things in and use theirs if there is room. Keep fridge closed as much as possible.
Jul 19, 2015 | Electrolux Refrigerators
I have control panel off wiring and circuit board look fine still cf code
Thank you for your post, friend!
From the information you have provided your Electrolux refrigerator is displaying an error code of "CF". "CF" appears to be a communication failure this could be a possible issue with your control panel or wiring harness. I understand that you have the board off and everything looks good so this could need to be further evaluated by an authorized technician. Hopefully this is helpful. -Matt
Feb 12, 2015 | Electrolux Refrigerators
How do I adjust freezer temperature on Electrolux refrigerator?
Hello friend, thanks for your inquiry!
I see that you would like to know how to adjust the temperature within your Electrolux refrigerator, EI23CS55GS1. To adjust the temperature you would use the control panel on the front of the freezer door. There should be a "-"or "+" near the freezer temperature control and that is how you would adjust the temperature within your refrigerator. Be sure to check and make sure that the control lock is not on or you will not be able to adjust the temperature. Any adjustments made within the refrigerator need at least 24 hours to stabilize. I hope this is has been helpful. -Matt
Oct 18, 2014 | Electrolux Refrigerators
Good afternoon friend, thanks for your inquiry!
From what you are describing it sounds like a possible issue with your control panel, UIB (User Interface Board), or control panel. The control panel and UIB would help to distribute any power being received into your refrigerator. The power cord would be the origin of where the power would enter into your refrigerator.
I would recommend putting the refrigerator into a different outlet to see if that would start up power or check to verify the household breaker has not been flipped. I hope this is helpful to some degree. -Matt
Oct 03, 2014 | Electrolux Refrigerators
Display panel on Electrolux wave touch French door refrigerator will not adjust temperature. Ice or water won't' dispense either.
Hello friend, thank you for your post!
Based off the information you are describing it sounds like your control panel is locked. Can you check to see if the control lock is lit up? If so, please hold down the control lock button for 3 seconds and it should allow you to operate the front panel. If not you could be experiencing a problem within your control panel and may need to have a professional come out to diagnose it. I hope this helps. -Matt
Sep 10, 2014 | Electrolux EI23BC56IS (226 cu ft) Bottom...
Our side by side electrolux refrigerator will not disperse cubed ice, only crushed. everything else works fine. Model number PRLS267ZAB8
Pull the ice drawer out and look for the small, metal "arm" that sticks out of the back of the outside of the drawer. Empty all the ice out and make sure this arm swivels freely. Sometimes it can get stuck.
Aug 29, 2010 | Electrolux Icon Professional Ice Maker...
The panel for the ice machine and water dispenser has shut off.
I have had the same probelm for over a year. It appears to be a problem in the touch pad w/ribbon connector which Electrolux refuse to accept responsibility for a faulty product. Model E230575DSS8
Apr 20, 2010 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Ref out of power.
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
Sep 02, 2009 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Refrigerators Logo
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
