Question about Teac Televison & Video
Teac tv when turned on the picture settings are set to 0 so the picture is all black and the volume is set to 30
Arpi
  • 326 Answers
SOURCE: Magnavox ms 3252s431 Bad picture and turns off by itself
Hello, Change horizontal driver buffer transistor's and capacitor's. 7461 7463 transistor's. Caps 2455 2405 near transistor's. Please leave your email address, I will try to find the service manual for you. Best regards, Arpi
Posted on Jul 29, 2007
  • 93 Answers
SOURCE: TEAC Television -CT-M809AV -no picture
Maybe it's something with NTSC/PAL settings, or SOURCE SELECT. Check troubleshooting in your manual.
Posted on Oct 11, 2007
chrispurs1
  • 372 Answers
SOURCE: Re: K displayed and Volume control
Hi.
Do this it will remove your set from factory mode.
  1. Unplug the AC power cord of TV set .
  2. While holding down the “VOL (–)” and “INPUT” keys on the set at once, plug in the AC power cord to turn on the set.
  3. The letter K should have disappeared from the screen.
Your set will now work correctly.
http://dysonmanuals.llc.nu/
Posted on May 25, 2008
  • 86 Answers
SOURCE: Samsung DLP tv w/ black picture will not power off.
If you are not able to bring up the TV's onscreen menu as well, it appears you have a problem with the TV's mainboard.  You didn't mention if the TV had any blinking error codes so if there aren't any lights flashing on the front, are there any on the sides or back to indicate the problem?  Not all TV's present error codes, but since the TV is maintaining power, it's worth a shot to look.  You could try a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If this still doesn't resolve the issue, service would be required so you would want to contact Samsung regardless of your warrant standing for service options.
Posted on Mar 26, 2009
  • 8457 Answers
SOURCE: polaroid tv screen goes black after 30 40 minutes,
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
Posted on Jul 05, 2010
Samsung tv calibration
You're asking about the picture settings to this TV; I assume, and posts this solution. Just set it to user mode; in terms of picture; set the Color to minimum (0); Contrast = 70 ~ 75%; Brightness to 30 ~ 40%. In this way, just set a picture in Black/White first. If you see that the contrast or brightness level should be adjusted to get a good B/W picture, do it according to your viewing taste. After set this, advance the color; and compare the skin tone of a news reader at the studio.
In most cases, this must be the perfect adjustment. If you wish to get more details to picture, advance the Sharpness control. Do not set it too more. Less than 30% will be sufficient. If the broadcasting system is NTSC, you have to adjust the Hue too.
Apr 18, 2014 | Televison & Video
I have a audiosonic kgr1 remote and need the set up instructions and teac tv codes
You're in luck - try each of these 4 digit codes for TEAC TV:
1627 1085 1152 1154 1165 1168 1171 1181 1183 1193 1283
Nov 30, 2009 | Televison & Video
No headphone jack on samsung tv,so i got a ,y adapter and plugged in to rca jacks,but volume is low
Headphone output is usually dependent on the source's volume setting and are not a good way to transfer signal between devices. RCA is the way to go as it is independent of the volume control. Many TV's have a setting for the audio output to select variable or fixed (independent of the TV volume setting). Look for it.
May 16, 2009 | Teac DRH300DAB Receiver
I own a samsung ln46a530 and need to configure it for the best picture.....any recomendatios?
If you haven't already bought a nice set of HDMI cables, go ahead and do so (just dont fall for the "gold plated" cables as they are a gimmick). Unfortunately, while we all want that HD quality, there seems to be some problems with the ln46a530 when switching from RCA to HDMI. On the bright side, they have been resolved in this forum post.
Best audio settings:
Mode: Custom
SRS TruSurround XT: On
Auto Volume: On
TV Speaker: On
(# of clicks):
Balance: 0
100Hz: 8 clicks right
300Hz: 8 left
1kHz: 4 left
3kHz: 3 right
10kHz: 5 right
For best picture:
Most accurate settings
(This with the mode at movie)
Backlight = 6
Contrast = 85
Brightness = 49
Sharpness = 0
Color = 50
Tint = G50/R50
DETAILED SETTINGS
Black Adjust = Off
Dynamic Contrast = Off
Gamma = 0
Color Space = Custom
Red: R33 - G0 - B0
Green: R18 - G52 - B0
Blue: R11 - G0 - B51
Yellow: R49 - G53 - B0
Cyan: R22 - G46 - B56
Magenta: R37 - G0 - B43
Flesh Tone = 0
Edge Enhancement = Off
Xycc = Off
WHITE BALANCE
R-Offset = 26
G-Offset = 25
B-Offset = 22
R-Gain = 30
G-Gain = 25
B-Gain = 25
PICTURE OPTIONS
Color Tone = Warm 2
Digital N/R = Off
HDMI Black Level = Low (actually it's disabled when playing Blu-ray)<-- set this according to your source! If you use a PC, or aPS3/Xbox360 with expanded RGB levels, you might need to set this tonormal!
Film Mode = off (disabled)
Blue Mode = Off
Energy Saving = Medium
Entertainment modes = Off
Hope this helps!!
Dec 01, 2008 | Samsung Televison & Video
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Sound but not picture, a black screen
Hi gp63
you will need to change the settings of the tv to ensure that it is on the right mode. ie. av1, av2, dvd, what ever the settings you have used for your tv.
good luck
smeags.
Dec 31, 2007 | Teac PLD2000 System
Unlock codes for TEAC PL-D2000
Comments:
To set Region code to 0 on a Teac PL-D2000 DVD System to enable play of any region
Ensure TV monitor is on so and set to display DVD.
1. Turn system completely off.
2. Turn on system.
3. Open tray.
4. Using remote press and hold the return button.
5. While holding the RETURN button, press and hold the DISPLAY button.
6. You will see something like this displayed on screen: VER 1006 TE 3210
7. Release DISPLAY and RETURN buttons simultaneously.
8. Press the ANGLE button. You will see WRITING REGION ID displayed.
You can now play DVDs from any region.
Dec 28, 2007 | Teac PLD2000 System
TV PROBLEM
I don't know your set in particular:
Genericaly, there are some models of sets that have a pre-set level for the sound. Check in to the menus of the set if there is a setting for the audio level at turn on.
Some manufactures designed their sets so that the sound is at about 30% up when the set is first turned on. This is annoying. They did that because they had people turn on the set and call their tech support that their set had no sound. It turned out that the volume setting was at "0"!
Jerry G.
Nov 21, 2007 | Philips 28PW6506 28" TV
Oct 11, 2007 | Sylvania 6419TE 19" TV
Televison & Video Logo
32 people viewed this question
Top Teac Televison & Video Experts
bengsoon Neo
JOHN TOPLISS
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
