Question about Coffee Makers & Espresso Machines
When dispensing coffee liquid also pools out in between silver dispenser cover and black coffee dispenser. seems left dispenser works full stream,right has less liquid coming out
reddevil6
  • 1673 Answers
SOURCE: Hoover 3010 FloorMate Plus not dispensing liquid
With the tank off, can you see if the rod in the handle is hitting the spot where the tank sits on, if not then there is a problem in the handle. If it is, then the reservior asm may be bad, it is what the tank sits on.
Posted on Jun 17, 2008
  • 99 Answers
SOURCE: Whirlpool Duet dispenser problem
this is joyce
You need to call who ever you bought it from and tell them the problem that you are having, I have the same set and I am not having that problem at all. I love my set, just be sure to use the he detergent, or you will have problems that the manufactr will not help with.
thanks,
Dont overload machine the clothes wont smell clean.
joyce
Posted on Feb 07, 2009
  • 423 Answers
SOURCE: After the dishwasher runs there is a lot of soap
With the LG LDF6810 model, this is not a common problem. Please try the following test, With and empty dishwasher, add a small to normal amount of dry dishwasher powder and run an (empty) load.
Check to see if any soap remains in the dispenser cup.
If any remains, here are three things to do: 1.) Upgrade your dishwasher detergent to a name brand powder (e.g.: Electrosol or Cascade)
2.) When you load the dishwasher, do not place large items in the front, near the door/soap dispenser.
3.) Before you load the dirty dishes for the next several loads, with your hand, turn both the upper and lower wash arms so they point at the door. Load as you normally do and push the racks fully in. Before you close the door, spin both the upper and lower arms and confirm that they spin freely and neither hits anything. if either does not spin freely, pull out the rack and arrange so the arms can spin freely.
I find that the only time I have left over detergent powder is when the wash arms do not spin freely.
This is a common problem on most every energy star/water conserving dishwashers.
Please report back what you find, OK?
Posted on May 21, 2010
heatman101
  • 43501 Answers
SOURCE: Does not brew the right amount of coffee. All
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
heatman101
  • 43501 Answers
SOURCE: My platinum series (B60) sometimes
heatman101
Fabric softener dispenser will not empty
Hello Mike Oswald - Fabric Softener is a very thick liquid that can clog up the siphoning mechanism. Try the following steps below.
  1. Remove the Dispenser
  2. Remove the Inset in the dispenser
  3. Clean out the dispenser and dispenser cover
The Fabric dispenser needs to have the hot and cold water at equal pressure for the fabric softener dispenser to operate properly.
1. Turn on the hot water fill then cold water fill at the washer. If the Wash Sense or temperature sensing is on it needs to be off.
  • If they seem to fill at the same pressure then you will need to contact a professioanl to move forward accurately.
  • If they seem not to fill at the same then you need to correct the pressure.
Mar 03, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Why are black particles being dispensed into the hot wqter from my Keurig coffee maker? How can this be corrected?
Hello, Irwin -
Those "small gritty black particles" are most likely coffee grounds which are so small they slip into the hot water and eventually the brewed coffee.
The grind size of your coffee may be too fine. Drip coffee method coffee makers, including the Keurig, require medium or medium-fine grind coffee.
Source of information:
Coffee Grind Size: Why It Matters and What You Should be Using, by Taylor Martin, December 22, 2015
CNET Best Products
https://www.cnet.com/how-to/coffee-grind-size-why-it-matters-and-what-you-should-be-using/
You may wish to check your coffee maker to determine if coffee grounds leaked into the space between the k-cup and the k-cup holder:
https://www.youtube.com/watch?v=jZrQhlQpLbs
Best wishes.
Mar 12, 2012 | Coffee Makers & Espresso Machines
Soap leaks from dispenser after use
sounds like a bad valve in handle, might be cheaper to just replace hadle buy the same one and just put in top that way you don;t have to climb under sink and loosen bottle
Jul 09, 2009 | American Standard Contemporary Kitchen...
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
One dispense spigot barely trickles
You need to take a paper clip and clean the little holes where the water comes out on the left side (It's like a screen). Also you should pull the silver thing that adjusts to allow taller cups underneath up and down several times. You should do the latter every week. It helps get rid of some of the coffee grounds that block the aforementioned little holes.
Oct 05, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
Bendix Washer/Dryer - softener dispenser not working
the softer dispenser is blocked, remove drawer wash it out with hot water ,clean out small hole in softer compartment close IRE bye
Aug 16, 2007 | Tricity Bendix WDR1040W Front Load Washer...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
