Question about Blade Saws
I need a 190mm x 24mm bore and a fine cit blade i e 40teeth
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: how do i get the old blade off on the 190mm pro
the blade bolt should be left hand thread, lower the guard plate and then push the spindle lock and remove blade.
Posted on Jul 21, 2010
  • 304 Answers
SOURCE: blade stops while cutting
If motor still runs it could be the gears have gone or that you do not have the correct blade spacer (if required ) fitted.
Posted on Dec 17, 2012
I have a Black and Decker KS555 circular saw and
It appears that you have adaptors for the blades that are the same thickness as the blades Place the adaptor in the centre and then put on the spindle and tighten up the plates onto the blade.
Sep 05, 2013 | Black & Decker Tools & Hardware - Others
Hi i need a parts diagram/exploded view of saw blade for a macallister 1800 circular saw with laser eye .i lent it to a friend and on its return the blade on the spindle spins freely . i saw someone e
MAke sure there is not two reducer washers on the machine, sometimes the old one gets stuck on the back flange and when you fit the new blade it does not clamp properly.
Jan 05, 2013 | Saws
Blade stops while cutting
Dec 15, 2012 | Saws
How do i fit reducing ring 16mm bore onto a30mm bore table saw blade, to use on a draper table saw
the reducer should fit right onto the shaft, if its the right size. Mic it to ensure. Then the blade should fit on no prob. I use a 30mm to 5/8" adapter on my own General 50-185 saw. Quality(sizing) of adapter is an issue.
Aug 02, 2012 | Saws
Need to replace a 185 mm blade with 15mm bore. All I can find is 16 mm bore blades. Does this mean buying a new saw?!
look for a bush, typically with a 30mm outer and any 30mm saw blade may then be used.
Nov 16, 2011 | Saws
I have a Homelite Trimmer Pro Series PBC 3600. I have replaced the carburetor and all fuel lines.The unit cranks runs fine at full throttle and at a fast idle, but I can"t idle it down enough to stop...
I have a Homelite Pro Series PBC 3600 and need to know what blade with work as replacement blade? I ask this because homelite has gone out of business as I have been told by Lowe's and other businesses here.
Aug 23, 2011 | Garden
My 60d finding ERR 01 with my tokina 12-24mm lenses. I try to clean the contact but after a few shoot the problem remain
I have the exact same problem, it's the aperture flex cable which have a design flaw. At 12mm the flex is stretched at maximum and over the years loses its flexibility and breaks. Mine works fine from 24 to 15mm. Below 15 the camera always reports err01. All flex cables in the tokina are welded -IMHO you need to take it to a professional.
Jun 20, 2011 | Tokina 12-24mm /f4.0 for Canon
Honda cb100 motor sezied can i rebore and fit larger piston and ifso what. Thanks
in adition to the above coment, which i must say is spot on, the posability of a used barel and piston if a new piston is not available could be worth considering, other things you may wish to check on that particular engine is camshaft seizure, in a uk bike it runs directly in the machined surface of the cylinder head, oil failure due to blocked oil filter has severe consequenses, located on the l/h side of the engine under a 22 or 24mm spaner head cap just below the gear change lever, this is a washable filter retained by a cap and spring, correct replacment is inperitive. are you located in UK? HOPE THIS HELPS YOU
Aug 02, 2010 | 1976 Honda CB 100
How do i get the old blade off on the 190mm pro sliding compound saw
Jul 21, 2010 | Saws
I'm using Tokina 12-24mm f4 on my Canon EOS 20D.
Most likely something bad has happened. It out of warranty, usually its 5 years. This is a pro job, getting to anything inside a lens is a very special job. There are a number of places to send it out. Check http://www.acecam.com/srindex.html and write to one or two of the places for estimates. It could be $150 or more plus shipping and taxes. A new one is about $400+, you could check around the many on-line camera stores for a used one. Could be a simple electronic part or the iris blades are bad.
Jun 29, 2009 | Tokina 12-24mm /f4.0 for Canon
Saws Logo
Top Blade Saws Experts
bozarthm
Level 1 Expert
Wayne Johnson
Are you a Blade Saw Expert? Answer questions, earn points and help others
