Question about Panasonic Microwave Ovens
Wont cook a sweet potatoe
My wife has 1250 genius sensor 1250 microwave that's 6 months old. Won't cook a sweet potato. I have an older Panasonic 1250 model, and it works just fine except door hinge failing and must open and close manually.
MicrowaveSvc
  • 9098 Answers
SOURCE: JVM1740SM1SS
Your membrane keypad has probably failed.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
It's at http://www.microwavedisplay.com/keypad_replacement.pdf
We have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Essentially you unplug the oven from the wall outlet, and remove the control panel assembly as per the instructions at the site linked above.
(Remove the grille from across the top, remove the top screw in the control panel frame, then lift up & out).
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille.
Then unplug the keypad from the circuit board, heat up the keypad from the front with a hair dryer, then peel the old keypad off.
You have to make sure all the old adhesive is off or the new keypad will not stick.
I use paint thinner or mineral spirits, then follow up with isopropyl alcohol to be sure the panel face is squeaky clean and dry.
Then peel the backing paper from the new keypad and carefully press the new keypad in place.
You need to be precise - you cannot apply it, peel it off, then reapply it.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Posted on Jun 23, 2008
SOURCE: Fire in Microwave Using Sensor Control for Potato
Please contact your home insurance to have the problem logged as a failure of the microwave. The insurance company will most likely help you with the smoke damage to the house and will contact the manufacturer to get their money back... there might be an issue with the manufacturing of these appliances.
Posted on Jun 27, 2008
  • 686 Answers
SOURCE: Frigidaire PLMV169DC (SS) 1000 Watt Microwave Oven/ Not working
REMOVE THE CABINET AND IT SHOULD BE CLOSE TO THE POWER INLET ON THE MOTHERBOARD IT LOOKS LIKE THE OLD GLASS TYE FUSE BUT MADE OF CERAMIC. GO TO www.repairclinic.com ENTER MODEL NUMBER, SCROLL ALL THE WAY DOWN N CLICK THE RED 100. FROM THERE LOOK FOR PART 634759 1055598 634750 1055589 1469078 ONE OR MORE OF THESE COULD BE THE CULPRIT START WITH THE LINE FUSE.
Posted on Apr 17, 2009
  • 202 Answers
SOURCE: Model jvm131h002 Stopped working. no power or
yes, at the back of the microwave there are 4 or 6 screws, take them out and then pull the cover follow the cable( the one you connect to the outlet) going to the inside of the microwave inside you will see the fuse change it with the same size, it is a slow burn fuse
Posted on Aug 05, 2009
ercupa190
  • 12223 Answers
SOURCE: microwave door wont stay closed
replace the door hooks and door release button.
if this is broken the switch will not close very well, and NOT start the microwave.
God bless you
Posted on Jul 20, 2012
While baking a sweet potato, the potato exploded and caught on fire. The microwave no longer works.a fire bro
I haven't heard of such a thing. You must have cooked it until there was no moisture left in the potato. That would also account for the failure of the oven. It would be the same as no load in the oven.
A thermal protect part is your current problem.
Apr 02, 2014 | GE SpaceMaker Microwave Ovens
Microwave won't restart after baking potatoes.
If your microwave is not a convection then the moisture most probably is somehow getting to the controls as potatoes has quite a bit.
Oct 27, 2017 | Emerson MWG9111SL Microwave Oven With...
GE MICROWAVE JVM1860CD NO POWER
It is time to replace the microwave oven, it is 11 years old and prices in microwaves has dropped considerably. To repair the old! magnetron would need to be replaced, "most expensive part" and other unknown problems would need to be addressed.
Apr 24, 2012 | GE Microwave Ovens
I have a Panasonic Genius 1250 watt Mircowave oven & when giving it a chance to cook 2 potatoes at the same time on the side dish sensor option. The whole oven including the outside shell got extremely...
Sometimes when cooking dry foods such as popcorn, potatoes, etc. there can be some reflection back to the magnetron, which will cause overheating.
Try it with about 1/2 cup of water on one corner of the cavity.
That load may be enough to keep it from reflecting microwaves back down the waveguide.
Oct 10, 2011 | Panasonic NN-T964SF Microwave Oven
Sweet potatoe caught fire in my microwve
the magnatron super heated the paper combined with what we in the industry call super combust your micro should be ok to use just keep it clean and if you use toweling wraP it around rather than cover
Apr 21, 2010 | Amana ACO1860 Microwave Oven
Shuts down on potato button only
Not much info to go on here. Are you putting in the number of potatoes vs.the cook time? Most microwave potato functions would not read "5 minutes." It would be read as a request to cook 500 hundred potatoes.
Oct 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Apr 17, 2009 | Frigidaire PLMV169DC Microwave Oven
I have a new microwave MSE 23 i bought it 1 month ago. It has been working fine maybe use it 6 times a week. I put jacket potatoes in tonight when i went to get them out they had not cooked but felt...
If your microwave oven is ONLY 1 month old and there is any question with its performance, it should still be under warranty from the manufacturer so I would bring it back to where you purchased it and have them provide a replacement of have them demonstrate that the one youi have is working to spec. Conversely, if you put large potatoes in the microwave, they havea lot of mass to them and will need to cook for quite a while.. Have you tried anything else in there of smaller proportions and those did not cook? You should be able to boil a cup of room temp water in a minute or two.. If that fails.. bring it back..
Hope that helps
Sep 04, 2008 | Microwave Ovens
Jan 04, 2008 | Amana ACO1860 Microwave Oven
Microwave Ovens Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
