Question about General Garden
I need instructions on how to connect the ignition wires to a Briggs and Stratton engine on a Swisher Trail Mower (manual start)
I have replaced the console and wiring harness on a Swisher Rough Cut Trail Cutter. It is manual start but has an ignition switch. I don't know where to attach the two (red and green) wires to the Briggs and Stratton engine. The owner's manual only shows a general outline of the engine, but now specific wiring contact points.
SOURCE: craftsman 19.5 briggs & stratton mower new
Check the voltage on the battery to see if it is 12 volts or higher. If not, charge battery.
Then check all starting-related electrical connections-- sounds like there is a dirty connection somewhere if the battery is charged.
Posted on May 03, 2009
SOURCE: can you point me to the wiring diagram for the above mower
The flywheel black (negative) and red (positive) wires are the magneto output. Red goes to ignition to charge the battery, and also burn the headlights -- so the red will go to the headlight switch as well, maybe through the ignition.
There should be an in-line fuse on the charging/headlight wire coming from the magneto.
There should be a safety switch under the seat which energizes the fuel cutoff solenoid on the bottom of the carburetor.
There are also interlock switches on blade engage mechanism, and the brake pedal, These prevent engine from starting if brake is not applied or if blades are engaged -- these would control current to the ignition module.
This is not complete, but it'll give you some clues -- good luck -- it's a ton of work.
Posted on May 08, 2009
  • 114 Answers
SOURCE: Need a wiring diagram for a 1969 Ford F250.
there should be a slot for each wire on back of ignition play with them till you get it right cant hurt anything
Posted on Jan 14, 2010
micromatikal
  • 2777 Answers
SOURCE: i need an owners manual for a brute riding lawn
This was very difficult to find, but I found it just for you! Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. To view the manual you will need adobe reader, which you can get for free from http://get.adobe.com/reader/ You probably already have it though, please try opening the file first and find out. Here is the manual / guide please give it a few minutes the file is quite large:
http://www.doitbestparts.com/MANUALS/BRUTE/7800583.PDF
Posted on Oct 12, 2010
  • 24 Answers
SOURCE: I need a wiring diagram
This wiring diagram is from a 15HP but it should be the same as your engine.
Posted on Jul 12, 2011
My Swisher 60" trail mower, how do I adjust the belt tension idler burning belts up real fast
look in the user manual and it should tell you how tight; looks like the belt is too loose and slipping allot to burn up..
Jun 06, 2015 | Swisher 60 in. 14.5 HP Briggs & Stratton...
Swisher 60" pull behind mower with 14.5 briggs engine. good spark and the starter will crank just fine. If I prime the carb with a little gas it will start imediately but wont continue. Any ideas..
Hi Andy, the carby will need to be removed and all jets cleaned out with compressed air. Basically its not getting enough fuel through the carby to keep running. Regards Phil.
Nov 28, 2012 | Swisher T14560 T - 60" Trailmower with 14...
Have a Yard Machine riding mower with 21hp Briggs Stratton engine OHV/IC V-Twin. when I turn on key nothing happens. How many switches control the start motor from the ignition and where are they located....
It depends on the model but most riders have the following;
1. Seat switch
2. Brake pedal switch
3. PTO switch
4. Neutral switch (if its a shift model)
All need to be closed in order to start engine.
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Need the belt diagram on swisher 66''trail mower 20 hp
Go to swisherinc.com. Look under customer support, support/manuals.
You should find what you are looking for there.
Oct 07, 2009 | Briggs & Stratton Garden
Craftsman 19.5 briggs & stratton mower new battery, new solenoid new brushes on starter. fuse & wiring good shape. when i attemp to start ignition all it does is click.
May 03, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
Top General Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a General Garden Expert? Answer questions, earn points and help others
