Question about Garden
Simplicity freedom F3500 will no self propell
3 Suggested Answers
  • 5124 Answers
SOURCE: Simplicity F3500-- how do I
To change the belt on the Simplicity F3500, unplug the vacuum and turn it upside down. There are two tabs (one on each side) behind the beater bar that hold the cover on the vacuum. Press these tabs inward and lift the bottom plate away from the unit.
Then remove the brushroll and the worn or broken belt from the pulley on the side of the brush roll and the drive shaft. Loop the new belt over the driveshaft and the brushroll. Replace the brushroll in the housing and turn it by hand. Make sure that the belt is seated on the driveshaft and pulley with no twists. Also check that all of the rotating parts will move.
Then put the bottom cover back on by aligning the back hinges and then pressing the plate down until both sides click.
For pictures of the cover removal process, look at page 15 in the manual. The direct link is http://www.simplicityvac.com/about-my-simplicity/manuals/FreedomManual_Update0803.pdf . Most Simplicity vacuum manuals are available at their support site: http://www.simplicityvac.com/about-my-simplicity/manuals/ .
I hope this helps.
Posted on Aug 11, 2011
SOURCE: simplicity freedom vacuum will not self propell ?
there is a seperate belt.one that turns the brush,one for propell..
Posted on Dec 14, 2015
Simplicity freedom vacuum will not self propell ?
Dec 13, 2015 | Simplicity Vacuums
Why is the bissell proheat clearview hard to push?
what do you mean exactly? mine is not hard to push but it may be your carpet. it is not a self propelled machine so it does require a little muscle.
Aug 11, 2014 | Bissell 1699 ProHeat Clear View Upright...
Bushings freedom vacuum
You need to replace the Brushroll. The bearing are pressed in. You can get your Brushroll here.
If you have any questions feel free to contact me.
Tim
TheVacCenter.com
Dec 12, 2012 | Boating
Simplicity F3500-- how do I get the bottom off to change the belt?
I hope this helps.
Aug 11, 2011 | Simplicity 7250 Deluxe Vacuum
Replacing pull cord
The easiest way to learn this is to watch one of the MANY videos on how to do it on Youtube. But if you're just replacing a broken rope and you know how to get the pulley off, then I recommend this one, for it's simplicity:
http://tinyurl.com/3s3jhhn
I hope this answers your question. Good luck.
James
May 30, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
I have a Simplicity 7 Series Commercial vacuum that does not pick up well when pushing the vacuum foreward. Picks up just fine when pulling it backwards. Have installed new belt, roller brushes, and brush...
Make sure the bottom plate is installed properly. If it is not seated well the brush roll may not be engaging fully with the carpet. Make sure the wheels on the bottom plate work properly.
Feb 10, 2011 | Simplicity Vacuums
Simplicity freedom vacuum has a burnt rubber smell
If the belt is continually wearing out I would think that the brush cylinder is not free to rotate. Take the belt off and ensure that the brush cylinder moves freely. If is does not, then you need to investigate why - probably something wound round it that has jammed it.
Apr 06, 2010 | Simplicity 7250 Deluxe Vacuum
Hi. I purchased a Simplicity Freedom about 2 years ago. I have had it in for various repairs several times. One persistant problem that the repairman cannot seem to fix is the dirt does not fall down into...
You can let the vacuum run alittle longer so the bag fills up with air, also make sure that the bag in on correctly and you have the right bag for the unit. Let me know if this helps.
Oct 12, 2009 | Simplicity Vacuums
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
